Losing trans fluid, but no leaks - S-10 Forum
post #1 of 14 Old 02-15-2009, 10:59 PM Thread Starter
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
My cousin has an 02 Blazer 4wd w/ 4l60e. Since Fall of last year he has had to put 7 qts. of trans fluid in it. He told me(he's pretty mechanically inclined) are no leaks coming from anywhere. The fluid is good and red still. Anyone have any idea what is wrong with it?
ℐustin
post #2 of 14 Old 02-16-2009, 05:28 AM
sewerrat's Avatar
User is: sewerrat is offline
Re: Losing trans fluid, but no leaks
Check if it leaked into the transfer case. It had to have gone somewhere with that much missing fluid. I have this problem with my old 80 K10 4x4.
sewerrat is offline
post #3 of 14 Old 02-16-2009, 05:48 AM
customchevys's Avatar
User is: customchevys is offline
yea thats pretty crazy having to put 7 quarts in and not seeing any leaks. Like Sewrrat said has to be going somewhere.
post #4 of 14 Old 02-16-2009, 08:55 AM
Killing Time
Petro's Avatar
User is: Petro is offline
Is any of it on the underbody?? maybe coming out of the tailshaft and splattering??? could be why you don't see leaks on the ground... but that is a lot of fluid
Petro is offline
post #5 of 14 Old 02-16-2009, 09:35 AM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
this might sound stupid, but does the blazer auto have a vacuum operated shift modulator? ive seen many times on the older ford explorers that they would go bad, and pull trans fluid thru the vacuum line and out the exhaust..... if so, you would usually have a film of atf on the tailgate
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #6 of 14 Old 02-16-2009, 02:06 PM
User is: beedle4 is offline
Yep do is ac/heat controls work?
beedle4 is offline
post #7 of 14 Old 02-16-2009, 02:18 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
exactly what i was gonna say. it also might be leaking into the transfer case
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #8 of 14 Old 02-16-2009, 03:44 PM Thread Starter
ZQ8 Blazer's Avatar
I myself haven't looked at it, I just thought I'd see what you guys thought before I put it on the lift and everything.
He didn't see anything on the underbody.
I don't know if it has an vacuum operated automatic shift modulator. I don't think so because there aren't any vacuum lines going to the trans.
a/c and heat work fine.
ℐustin
post #9 of 14 Old 02-17-2009, 12:06 AM
mxthor3's Avatar
User is: mxthor3 is offline
Tell him to crack open the fill plug on the t-case and watch out..
I bet it's the shaft seal inbetween the tranny and the tcase...
There's no where else for the fluid to go.
mxthor3 is offline
post #10 of 14 Old 02-17-2009, 12:30 AM
Raven's Avatar
I bet it's the shaft seal in between the tranny and the tcase...
yes...only other viable option. or the tranny fairy is stealing it.
1999 S10 4.3L Zr2
Raven is offline
post #11 of 14 Old 02-17-2009, 12:44 AM Thread Starter
ZQ8 Blazer's Avatar
ok thanks guys, that sounds like the problem
ℐustin
post #12 of 14 Old 03-18-2009, 09:46 AM
halfbreed's Avatar
User is: halfbreed is offline
Hope I'm not being stupid but could he still have the cooler lines going to the radiator and if they are, has He checked the radiator to see if it's got any tranny fluid in it. I have seen it happen on 350 and 400 tranny's. 7 quarts is a lot of fluid.
post #13 of 14 Old 03-18-2009, 11:59 AM
Raven's Avatar
it could happen....but he would be having serious problems then if he had that much atf in the cooling system
1999 S10 4.3L Zr2
Raven is offline
post #14 of 14 Old 03-19-2009, 04:18 PM
rollin' on 33's
t01blaze's Avatar
User is: t01blaze is offline
check your radiator. the atf oil cooler sometimes ruptures and atf goes into the cooling system since atf is under more pressure then coolant.
if its not in the transercase the radiator is the only other internal leak possible.
t01blaze is offline
