How to bleed clutch on 95 s10? - S-10 Forum
post #1 of 4 Old 07-03-2011, 04:10 PM Thread Starter
Tokey The Bear Says SMOKE
User is: Mandoof is offline
Send a message via AIM to Mandoof
Question How to bleed clutch on 95 s10?
My friend has a 95 s10 2.2 4cyl with I think a t5 transmission cause it doesn't look like the nv1500 i had in my 98.Anyways,the haynes repair manual(people say is crappy)says gain access to the release cylinder which is located on the left side of the clutch housing,remove dust cap on the bleeder valve and so on.I know how to bleed a clutch i just cant find the bleeder on this thing.you have the master cylinder then the hydraulic clutch line going to the release cylinder where its fastened to the transmission with two bolts.This book doesn't even show you the difference between the t5 and nv1500.i wish it was like the nv1500 where the bleeder sticks out of the bell housing and has a push connect for the clutch line.Please Help
Mandoof is offline
post #2 of 4 Old 07-06-2011, 03:42 AM
User is: max1million is offline
Re: How to bleed clutch on 95 s10?
Don't recall a bleeder on mine either and have read some came as sealed master to slave complete assembly. Dismount the slave, tip hose end up, shove the rod/piston all the way back in, might get lucky. Remount, be careful not to blow piston out when not mounted.
It has a single cab, cause one cab is enough.
post #3 of 4 Old 07-07-2011, 08:13 PM
User is: jkill54 is offline
there is a small plastic protrusion on top of the slave cylinder, I has an allen screw in it. that is the bleeder. you will still have pump the clutch peddle forever but it will com up.
jkill54 is offline
post #4 of 4 Old 07-08-2011, 04:10 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Both Maxmil and Mandood are pretty close. You have to remove the slave, unscrew the allen a little, then push the slave rod all the way in the slave while holding the cylinder vertical with the hose end up - you have to hold it at the same time - once the rod is in all the way (you'll see the air escaping) close the allen bolt bleeder thing. Reinstall the slave. Now pump the CRAPSKI out of the clutch pedal. Of course - make sure you have juice in the master cylinder. This is the ONLY way I could get mine to work in a reasonable amount of time. The design for the slave SUX!!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
