how many u-joints on extended cab? - S-10 Forum
post #1 of 26 Old 02-01-2005, 04:33 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
User is: projo198 is offline
Send a message via AIM to projo198
I have an extended cab 2001, my u-joints are grinding and I am going to replace them. How many U-joints do I need to buy? Thanks.
projo198 is offline
post #2 of 26 Old 02-01-2005, 05:39 PM
eugenen's Avatar
User is: eugenen is offline
Re: how many u-joints on extended cab?
Should be 3 if its a 2wd, my 2000 has 3
I had to by 5 to get three decent ones though, first three I bought two wer made in the US and the other one china even though they were the same brand. First of the chinese ones broke taking it out of the cardboard box so I returned it and got another and it broke when installing it so I went to a different store of the same chain and asked the guy to look at the bottom of the boxes for a US made one.
I made sure to get them with grease fittings so they will last longer too (unless I get lazy and don't grease them)
I assume U know U have to melt the nylon out from the factory ones.
eugenen is offline
post #3 of 26 Old 02-01-2005, 05:43 PM
Yes that Sh Sh Shit
el camino ss's Avatar
User is: el camino ss is offline
Send a message via AIM to el camino ss
i keep hearing about 5 u joints but in my mind i am think of 4 the most and hopefully they are all the same part number
Will work for more parts
03 Sonoma used to be a Zq8 but now its Bagged and sh sh sh shit!!!
Sorry, your signature image was too large. Please click here to view the specifications before adding another picture.
post #4 of 26 Old 02-01-2005, 05:59 PM
eugenen's Avatar
Where would they put 5? You have right behind the transmission, one just behind the center bearing and one at the diff. Any more and you would have to have more center supports to keep the drive shaft from flopping around
eugenen is offline
post #5 of 26 Old 02-01-2005, 06:32 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
Do you mean to lube them or replace them? Their supposed to be lubricated for the life of the joint, I think thats kind of stupid not to just put points on them like the older ones...
projo198 is offline
post #6 of 26 Old 02-01-2005, 06:35 PM
Yes that Sh Sh Shit
whose got part numbers and a definate answer to this?
post #7 of 26 Old 02-01-2005, 06:37 PM
specializing in 98-up s10
s10warehouse's Avatar
User is: s10warehouse is offline
97-up 2.2 ext cab is 3 u-joints if you have a v6 thats 97-up yes their is 5 and dont try to replace them your self take the shaft to some one that does it
95Camaro z28385ci.6spd 17K org.miles,k&n intake, 58mm tb,30lb accel injectors,msd 6al,bilstein coil overs,4 piston bembro brakes ,fikse rims front 17x9.5 275/40/17,rear 17x11.5 315/35/17bfg drags 4-sale 9k obo http://www.s10forum.com/gallery/view...Name=album2377
post #8 of 26 Old 02-01-2005, 06:46 PM
Yes that Sh Sh Shit
told you there was 5 thanks s10warehouse for clearing that up now anybody have part numbers?
post #9 of 26 Old 02-01-2005, 06:47 PM
eugenen's Avatar
No I mean the nylon they use to hold the caps on instead of the clips like the replacement ones. You have to melt that to replace the joints, then the replacement ones have the clips that hold them in place. You have to get plenty of heat too, the little 1lb propane torches just don't quite give off enough.
The lubed for life stuff is only if you never get them dirty or wet get a bit of dirt past the seal and the life is over, I prefer the greasable type so I just grease them each time I change the oil to keep good clean grease in them.
eugenen is offline
post #10 of 26 Old 02-01-2005, 06:47 PM
Yes that Sh Sh Shit
95 Camaro z28 385 ci. 6 spd t-tops black leather 16,860 org. miles, coil overs 4 piston bembro brakes front+full list mods Fiske rims 17x11.5 rear with 315/35/17 bfg drag radials 17x9.5 front with 275/40/17 for sale 10k obo
thats alot of car for the money good luck selling that
post #11 of 26 Old 02-01-2005, 07:06 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
I'm poor so I do all my own work...LOL..I take it to the Auto Craft center on post, they help out a lot, you just have to do the wrenchwork.
projo198 is offline
post #12 of 26 Old 02-01-2005, 07:15 PM
if you have the 5 of them in your v6 thier a pain to change with out a press dont try and beat them in and out or you will need a new drive shaft most people f-up the yokes beating them out
post #13 of 26 Old 02-01-2005, 07:38 PM
eugenen's Avatar
I'm not poor but still prefer to do my own work.
I usually don't recommend HF stuff, but they have a U joint press for $35. You will only need it for the factory joints, once they are replaced the ones with the clips are much easier and you can press them in and out easily.
eugenen is offline
post #14 of 26 Old 02-01-2005, 09:58 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
Okay, I bought three. I'm gonna put it ion the life tommorrow and check it all out, I just hope it is my u-joints and not something worse like my tranny. Thanks for the help.
projo198 is offline
post #15 of 26 Old 02-02-2005, 10:03 AM
Nice Jorb
cavymeister's Avatar
User is: cavymeister is offline
Send a message via AIM to cavymeister
If it is the nylon pins like my 03, you don't need a press. heat the end of the U joint up with a torch. I've always used a little propane torch (kinda like the ones for plumbing) without a problem. Just do it outside so you don't have to clean up the melted nylon mess.
post #16 of 26 Old 02-02-2005, 03:00 PM
Sold
Twin-10s's Avatar
User is: Twin-10s is offline
there is not 5 u joints in any s-series truck.
there are 2 double cardin joints. there are not replaceable, but are rebuildable. take it to a shop if u have the double cardin joints.
Twin-10s is offline
post #17 of 26 Old 02-02-2005, 03:34 PM
call them what you want but their is 3 in some and 5 in the other i am lots of other people call tehm u-joints becasue thats what they are
post #18 of 26 Old 02-02-2005, 04:30 PM
eugenen's Avatar
Ahh, thats why people say there are 5, those double joints look a lot like U joints so I guess it is easy to call them that.
That nylon isn't just pins, the pins you see are where the holes are that they squirt them in. You can do them with a little torch it just takes a while to get it up hot enough for them to melt.
eugenen is offline
post #19 of 26 Old 02-02-2005, 06:42 PM
Sold
Twin-10s's Avatar
yes they do look like u joints, but there is more to them than a reg. u joint.
there is a ball and spring between the 2. that needs to be held together while assembling them. takes special tools to rebuild them.
Twin-10s is offline
post #20 of 26 Old 02-03-2005, 07:13 AM
Nice Jorb
http://www.pavementsucks.com/tech/doublecardan.php
BTW part of each double cardan joint is two universal joints. On my 03 ext cab, I've got 5 U joints.
Saying it's not a u joint cause it's part of a cardan joint is wrong. It's still a U joint.
post #21 of 26 Old 02-03-2005, 05:46 PM
User is: Mike8756 is offline
The reason the double-cardan u-joints wear out on the S-10 extended cabs is because the driveshaft needs to be aligned. Check out this link:
http://www.jagsthatrun.com/Pages/Par...aft-Align.html
Also, heating a u-joint to melt the nylon retainer can cause the cap of the u-joint to shoot out like a bullet because of the high-pressure that builds up from the grease and oil being vaporized inside the u-joint. I don't recommend heating the u-joint -- it can be dangerous.
Mike8756 is offline
post #22 of 26 Old 02-03-2005, 08:32 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
[QUOTE=Mike8756]The reason the double-cardan u-joints wear out on the S-10 extended cabs is because the driveshaft needs to be aligned. Check out this link:
Funny you should post that page, I just came acrossed it while trying to fix this problem. Anyway, I replaced all THREE of my u-joints last night and it didn't fix the problem. A lot of people have mentioned the double cardan joint. I saw the picture but don't remember seeing one on my truck, and I pulled the whole shaft out. All I have is the joint at the transmission, a second by the carrier bearing and the last at the dif. I guess I'll try switching out the carrier bearing next, it is only 25 bucks. Yes, the old u-joints were a pain in the ass, we had to melt AND press them but they came out alright. If anybody has any more info on these cardan joints please share, thanks for the help guys.
projo198 is offline
post #23 of 26 Old 02-04-2005, 07:10 AM
Nice Jorb
If you only have three U joints, then you don't have the double cardan joints. While it's in the truck look at the angles and see if it's out of alignment. With my 3/3 drop, I noticed it was pretty rough. The angle from the diff yoke and the rear driveshaft was fixed by the angled blocks, the angle from the carrier bearing and the rear driveshaft was fixed by lifting the bearing, and the angle from the trans yoke and the front drive shaft should be fixed by the trans mount spacer (haven't done it yet, I'll be doing that part tomorrow). That has helped out a lot of my vibrations.
Did you match mark the drive shaft before you took it apart? If it's put back on backwards, or a 1/4 turn off on the differential, it could also add vibration.
post #24 of 26 Old 02-04-2005, 07:37 PM Thread Starter
SHENANIGANS!!!
projo198's Avatar
[QUOTE=Did you match mark the drive shaft before you took it apart? If it's put back on backwards, or a 1/4 turn off on the differential, it could also add vibration.[/QUOTE]
Yeah, it went back the same way it came out. It grinds mainly at speeds over 35-40, especially on the highway. It isn't constant, it mainly happens as I let off the accelerator, but before I take my foot off completely. I did notice today that it stops when I air up. I can't think of anything else it could be now but the carrier, but I don't know. I was thinking, does this happen at all if the splines of the shaft bottom out when I air up and down? Let me know how those spacers work out for you, thanks.
projo198 is offline
post #25 of 26 Old 02-04-2005, 08:19 PM
yoj
yoj's Avatar
User is: yoj is offline
do you have a Manual?
Starting around 1995, the extended cab 2wd V6 trucks with automatic transmissions came with the constant velocity “double-cardan” style U-joints (shown above), to reduce driveline vibrations on extended cab trucks.
2003 X Xtreme
yoj is offline
post #26 of 26 Old 02-04-2005, 09:28 PM
Mike1234's Avatar
User is: Mike1234 is offline
If you have a '95 or later extended cab or long bed with the 4.3L you have 5 u-joints. If you have the 4 cyl engine then there are 3 (I think some might have the double cardans as well, edit: I guess not I just reread S10warehouse's reply).
All 5 u-joints and both double cardan joints need to be greased if you don't do this they are going to fail. Once the sealed factory u-joints fail replace them with greasable u-joints and they should last as long as your truck if you keep them greased and your driveline angles aren't bad.
Have you ever looked under your truck??? (I might be wrong, but it looks like you have the 4.3L, I thought I could see a y-pipe in one of your pics). On each side of the double cardan joint is a u-joint.
The double cardan joints are replacable too. You will get charged an arm and a leg at the dealer though.
You don't need special tools. Just a puller and a press to get the ball off if it needs to be replaced (unless those are special). When I rebuilt mine the balls where still in good shape, but the pieces that make the cone the ball sits in had shattered, so I just replaced those and the spring and seal.
1995 Extended Cab S10, 4.3L TBI, 4L60E
Flat Black, M3 Mirrors
Magnaflow Muffler
5/4.5 drop
15x8" Eagle Alloy 63 Series
215/60R15 up front, 245/60R15 out back
Mike1234 is offline
