Help
So i just got this 97 s-10 and it is stuck in 4th gear you can move the gear shifter to all other gears but its loose feeling its not taking the trans outta gear...do you think the linkage broke or something if so how can i fix is it easy btw its a 97 6cylinder.
Re: Help
Come on no one....lets hear what it is...
Re: Help
If it was a T5 I could tell you. I don't know what transmission you have, so I can't help.
Re: Help
I dont know what it is, It is a 1997 s-10, the vortec v-6, and its a 5 speed. Any information would be helpful
Re: Help
come on people i want to fix this and drive it i can wait.
Re: Help
If it was a T5 then you would probably have a broken roll pin on the shift linkage or the end of the shifter might be broke off. The shifter has 4 bolts that hold it on the top of the transmission. You can remove these bolts and take the shifter out to inspect it. The roll pin goes through the steel block that the shifter ball fits in. It connects the block to the shaft.
Re: Help
That block is broke what can i do about that...is it a new tranny kind of thing or what...can i weld it you think....
Re: Help
You need to find out what transmission you have. If it's a T5 I have a bunch of those blocks. If it's something else then you probably need to go to the GM dealer and see if you can get a new one. I don't think I'd try to weld it. They are heat threated steel.
Re: Help
http://en.wikipedia.org/wiki/Chevrol...gree_V6_engine
Venture series transmissions were found in 93 and newer. If you say, "T5" the truck transmissions are entirely different from the ones in cars so be sure to specify to a shop. And by block do you mean the casing? If any part inside or outside of the casing is cracked or broken I would def. put my money in a new transmission not welding up the one you got unless it is VERY minor. |
Re: Help
No its the part the the shifter and the trans connect too...is that replacable i have it out of fourth but i cant drive it cause that plate is off and it will shoot tran fluid in my face lol.....but i dont know what to get or even if its replacable.
Re: Help
Got pictures?
Re: Help
Re: Help
Re: Help
That looks bad. This is a transmission that I'm not familiar with, so I'm not going to be any help to you. If it was a T5 then I could help, but it's not. Sorry.
Re: Help
if it is an UNMODIFIED drivetrain then this trans should be the NV3500 if i have been reading right for this year.the last year for the T5 was 94 I think but it might have been 95 as well i am still learning bout the 2nd gen trucks. dont really know what to tell you to help with this problem other then replacing the transmission. inwhich if i were you i would go ahead and switch it to a T5
Re: Help
The T5 was a stock option only for the 94-95 2.2 litre 4 cyl. All the 4.3 V6's in the 2nd gen truck were NV3500. Those picks look a lot like my NV1500 which I understand is just a weaker version of the NV3500.
Ken T. |
