Hard plastic clutch hydraulic hose repair - S-10 Forum
post #1 of 12 Old 09-12-2010, 07:46 PM Thread Starter
theholycow's Avatar
User is: theholycow is offline
Question Hard plastic clutch hydraulic hose repair
How would I repair the hard plastic hydraulic clutch hose that goes from the master to the slave in a 1994 S10 2.2? I've accidentally damaged it. I have enough slack to splice it (with what product?), or I could just replace it...but I can't find anyone selling it and I can't see how it would come off and be put back on.
1994 S10 regular cab 2wd 2.2 (what's left of it anyway - want any parts?)
1980 Buick LeSabre Limited 4.1 5MT
2002 GMC Sierra 1500 4x4
post #2 of 12 Old 09-13-2010, 11:45 AM Thread Starter
theholycow's Avatar
Re: Hard plastic clutch hydraulic hose repair
Nevermind, found a relevant thread...
http://www.s10forum.com/forum/f143/c...cement-364171/
post #3 of 12 Old 09-14-2010, 04:53 AM
i saw what you did there!
fast68chevy's Avatar
new line
dealer junkyard or maybe a parts store iif even available
post #4 of 12 Old 09-14-2010, 09:52 AM Thread Starter
theholycow's Avatar
New lines are not sold anywhere. Some parts stores, and reportedly dealers, can get a complete pre-bled master, line, and slave set.
Also, the line can't be disconnected and reconnected in any sane way.
If I fail at repairing it, I'm going to use what I learned in the thread I linked above to see about getting a hose made by a hydraulic hose shop. If that fails then a junkyard visit is in my future.
This is the plastic tubing:
This is how it attaches to the master and slave:
Zoom in for a closer look at http://picasaweb.google.com/Perforat...21878024010770
post #5 of 12 Old 09-14-2010, 01:22 PM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
temp fix...
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #6 of 12 Old 09-14-2010, 04:17 PM Thread Starter
theholycow's Avatar
Agreed. I won't find an appropriate compression fitting, which is a better fix, but I should be able to find that style of fitting.
post #7 of 12 Old 09-14-2010, 04:36 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
The line will unhook from the slave and master. It is attached with roll pins. Tap the roll pins out, then pull the line off.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #8 of 12 Old 09-14-2010, 04:59 PM
NotaDime's Avatar
a Buick LeSabre with a clutch huh? interesting...
NotaDime is offline
post #9 of 12 Old 09-14-2010, 05:01 PM
NotaDime's Avatar
oh and.... MOEW! lol
NotaDime is offline
post #10 of 12 Old 09-14-2010, 08:18 PM Thread Starter
theholycow's Avatar
You've discovered my dark secret!
I am totally unqualified to do such an undertaking, but I went ahead and did it anyway...I learned a lot. I finally got it running a few days ago and ten minutes later I found out that I forgot to route the clutch hose properly.
In the other thread that I linked in my first reply here I learned about those roll pins. The trouble is, nobody sells the hose.
I could take it and its fittings to someone who makes hoses, if I knew where to get that done (I have a couple ideas). I could buy some expensive, rare, takes-months-to-deliver fittings to DIY. Or I could try to fix it here.
The car came out far less hacky than I expected so I can tolerate a little bit of hackage here.
Good news: I found a compression fitting that will work.
The ones in parts stores now have a small tube that fits the inside diameter as well as having the sleeve that fits the outside diameter. They are designed for metal fuel/brake line and won't work with this thick-walled plastic tube. A year ago the ones in parts stores did not have the inside diameter tube...I know because I bought one to fix my fuel line back then.
Anyway, a hardware store had the old style, which will work for this. They also had separate brass tube inserts that fit the inside diameter. I bought them to reinforce it and prevent it from being crushed in the compression fitting.
I'm pretty confident in this. One person in the other thread did it with a compression fitting two years ago and it's been fine. Mine runs higher pressure (stiffer clutch) but ought to be fine.
post #11 of 12 Old 03-17-2011, 11:30 PM
User is: armandjones82 is offline
I think that the resources above are seem to be good. I also found this kind of repair in order to fix up all the things that are supposed to be fixed on your vehicle when it comes to hydraulic hose. I don't know if this would help out but try to red it to really fix it all up.
post #12 of 12 Old 11-08-2013, 10:03 AM Thread Starter
theholycow's Avatar
Now 3 years and 55,000 miles later, I never expected any part of my project to last this long but almost all of it has -- including the temporary hack of splicing the hard plastic hydraulic clutch hose with compression fittings from the plumbing section at the hardware store.
