Fill and drain Transmission--->See photo
I have a 1997 S10 4 cyl with a 5 speed NV1500 transmission 2x4 is this the correct fill and drain plugs?
![]() Also this is the oil I going to use for refill. ![]() Am I on the right track? Last edited by redtruckagogogo : 08-12-2008 at 02:07 PM. |
SK NJ chapter VP
Location: New Fucking Jersey User is: OffLine ![]() ![]() ![]() |
Re: Fill and drain Transmission--->See photo
yes
The NV1500 calls out for Syncromesh, It's probably not a good idea to use gear oil
SK NJ chapter VP
true, synchromesh is better anyway
1/4milecrazy
Autozone says to refill with the LUCAS gear oil. Will I be OK with this? |
SK NJ chapter VP
autozone is a bunch of idiots, generally all the chain store employees are, i once went to a pep boys and asked for a rotor for a 93 s10, they said they didnt have it, i then asked for a rotor for a 86 monte carlo and it has been on my truck for a few months now.
Most GM transmissions dont use gear oil, they use ATF. and the best thing to replace it with is synchromesh. i plan on using it in mine when i change the fluid. the lucas will be too thick for the nv3500. although it may work and be fine i dont think it is a good idea. |
I have the NV 1500 transmission, should I take back the Lucas?
SK NJ chapter VP
yes
I'm slap happy, bitches!
gm part #12345349
or you can use synthetic atf, which is better lube for a stick anyways. |
I would stick with the syncromesh, its not worth taking the chance. Tranny rebuilds are no fun
I filled with syncromesh 3 qts. Shifts much better now. Had 98,000 on old oil.
Thanks for all the help. |
is the royal purple syncromax any good? i just put in penzoil syncromesh(i work at advance and i do know some things) but RP is 15.99 a quart through us so i just bought the cheap stuff. but would it shift better or what
