Doing a 4l60e transmission flush by yourself?? - S-10 Forum
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 09-06-2007, 07:11 PM   #1
S10 TIRE/WHEEL MASTER
NORCAL SS's Avatar
guys if you can chime in and tell me if im right here.
1) Drop the pan put new filter in and close it up and add 3 quarts.
2) I think the return goes to the top of the radiator and supply to tranny goes out from the bottom. So in that case disconnect the supply line going out to the radiator and get a tube. One tube goes out from the radiator to to a 5 gallon bucket, and other tube attaches to the line feeding into the tranny and that tube would be in a 5 gallon bucket filled with fresh oil.
3) start the truck up and leave it in park and watch the empty bucket fill up and at the same time the bucket with clean fluid will get sucked into the tranny.
4 Once the empty bucket fills up and you see clean fluid come out the tranny it should be flushed which will take im guessing 15-20 quearts to be safe you can turn the truck off.
So am i wrong here guys?? Or will i have to manually fill because ive done this before and i just want to be sure 4l60e will suck the fluid in and then push it thru the radiator out the exit side so i can clean everything in the entire system even old fluid in the radiator. Prob going to use amsoil or mobil 1. Truck has 45K miles.
Old 09-06-2007, 08:19 PM   #2
goin broke but n style
S15vortecpwr's Avatar
Re: Doing a 4l60e transmission flush by yourself??
I am not sure which line is which. I bottom line is the return line on my truck. That is where I have hooked up my tranny cooler. Fluid goes thru the rad and then thru my front mounted coller then back to the tranny.
The flush thing sounds right to me. I have read several post on here about doing it that way.
I use the store brand ATF and change it every 30,000 or so miles. I have never had any trouble using store brand ATF.
Old 09-09-2007, 10:45 AM   #3
Blown ex ***
Jess's Avatar
put 4 quarts in the pan, 5 if its a deep pan. disconnect the upper line on the radiator, put a fitting & hose on the radiator to a bucket. start it and let it run till you see about 4-5 in the bucket. shut it off and add 4-5 in the filler tube. repeat till your happen with the color. put it back together and check the level. make sure there is fluid on the stick with the engine off, before starting it up.
Old 09-09-2007, 10:53 AM   #4
NORCAL SS's Avatar
to the upper part of the radiator the return to the tranny??? then id hook up another hose to the line that gos out from the radiator to the tranny and put that line inside a bucket filled with new oil because the pump will suck the tranny fluid thru right?? That way i dont have to keep filling the dipstick up the pump in the tranny should suck the fluid from a new bucket pretty easy. Then I could just sit there and watch it till i like the color
Old 09-09-2007, 11:43 AM   #5
Blown ex ***
Jess's Avatar
i don't know if it would suck the fluid in. never tried it, its pretty easy the way i do it.
Old 09-09-2007, 11:44 AM   #6
Blown ex ***
Jess's Avatar
btw, if ya spill fluid. just use a garden hose and rinse it off.
Old 03-01-2008, 01:30 PM   #7
did it work the way you get planing to do it? with 2 buckets?
