Do nv3500 4.3l 5spd have pilot bearings?
exactly title. I've never seen them but i keep going through slave cylinders and i wonder if its cause i do not have a pilot
I need a new truck!
Re: Do nv3500 4.3l 5spd have pilot bearings?
im pretty sure all 5 or 6 speeds do, the one on my last truck was going bad i think.
the youngest has been
Every Manual Trans Has A Pilot Bearing Or Bushing
V8 AWD member
I could see the vibration from the clutch locking off-center doing all kinds of damage. You absolutley need a pilot bushing.
could be a good reason why i'm blowing slave cylinders, 500lbs of torque twists the input and starts rubbing on the slave
Xtreme Measures
where did u get one, i think i will head to the dealership for this one
Xtreme Measures
any parts store will ahve it
Buick drivin 4by draggin
Location: Green Hills/Nashville User is: OffLine ![]() |
Yea, If you dont have one at all, Im surprised that thing lasted 2 miles
it lasted for over 12k miles, and 3k of that at over 500lbs of torque when boosted..
I bought one today but its just a bushing, did u guys get a needle bearing unit or a solid steel bushing? |
get a BRASS pilot BUSHING and call it a day |
V8 AWD member
Theres also an adapter which GM calls an insert you will need if converting from a A/T engine.
V8 AWD member
Funny thing on this subject though is I had a guy bring me his 2.5 S10 that he uses to pull all kinds of junk to the iron metal place to me to change the clutch about 2 months ago. He said it had just had a new clutch put in about a year before. Well I pulled the transmission and it lookied like someone had shaved their cat in side the bellhousing hairlike strands everywhere. The whole front of the disc was exposed to the rivets. It had an insert but no pilot bushing at all. I'm guessing the prior mechanic pulled it and forgot to replace it.
Xtreme Measures
My pilot bearing is oil impregnated bronze. I dont think roller bearings are a great idea in that environment. Its too dirty and dusy with the clutch dust getting in there.
a pilot BUSHING is a solid chunk of brass or bronze a pilot BEARING is a unit that has needle bearings in it. its an actual bearing where the two half's can spin seperatly |
Xtreme Measures
The oil impregnated bronze heats up and oil seeps out of the metal. |
ok well i went down to my local race shop and ordered a Ram Pilot bearing, which is roller bearings, for 18 bucks i get a good name so i threw the crappy bushing out
Xtreme Measures
w/e works man there all going to eventually wear out. good luck. How'd you get the old one out? Mine was a pain in the ass to get out. I had to machine a puller.
i never had one in there... ever, i've only had the truck for a little over a year...explains why the last owner went threw 2 transmissions.
i bought a moroso SBC one today, they never ordered my ram but swapped it out for a needle bearing moroso. |
