Diesel Fan
this is for all of you ext cab guys who want an one piece driveshaft or for you standard cab guys who want to switch to aluminum. While i was in the process of building my truck i want to ditch the 2 piece shaft and put in a single piece steel. While i was thinking about this i found out that newer 2500 chevy pickups come with 4" aluminum driveshafts. for $50 i went and took one out of one in a junkyard. The driveshaft is about 68 1/2" long and will have to be cut down for almost everbody. I had to take 4" off mine. I just wanted to let everyone know that if you want to change to a single piece or upgrade you can pull one out of this truck and have it shortened for a few bucks. The rear U joint fits both the 8.5 and 7.5, the only thing you will have to do is have the tranny yokes changed. These shafts are strong with all welded joints (some have crimped ends)
Just wanted to let everyone know. Pm me if you have any questions. Last edited by zerogravity58 : 08-07-2005 at 02:00 AM. |
Re: aluminum driveshaft/ single piece
yeah, thats the easy part. but if your any kind of lowered, and who isn't. the shaft is going to hit the floor.
Diesel Fan
Im lowered 3". You do have to clearance the floor alittle. That is with all ext cabs when you switch to a single piece shaft.
the youngest has been
good info, now i just have to find a newer truck with an aluminum driveshaft |
WillydaKid
will the front of the driveshaft fit into the transmission tailshaft of the 2.2 5-speed?
\X/
pics? what gen truck?
Diesel Fan
i dont have any pics off hand but it was put in a ext cab 92 s10.
the reason why gm used a 2 piece drive shaft was for vibration corectness, if you switch to a one piece, you will most likely devolope a noice, there was a tsb on it for the ext cab extremes which originaly came with a 1 piece shaft.
Diesel Fan
no you wont develop any noise as long as you shim the rearend to get the right pinion angle. Reason GM used a 2 piece is because a single hits the floor.
It WAS a Blazer
So how much is "a few bucks" to have it shortened, and can't shortening it throw it out of balance?
Diesel Fan
no if they shorten it and its out they can rebalcne them. it cost me like $125 to have it shortened with new U joints.
Diesel Fan
i probally dont have $200 in whole driveshaft. Its 5" shaft and im running it at the strip with no problems in my truck. If you have a ext cab truck you do need to clearance the floor...I cut a section out of floor in the ext cab part of the truck. Like a 5x12 piece. Im going to make something to go over it eventually. Other then that it fits fine. If you need a driveshaft loop tho you need to get one custom made. None of the ones i have found fit around the driveshaft.
I like COOTER
NO 2wd 2nd GEN EX CAB had a 1 pc driveshaft from the factory the frame isnt designed to accept an xtreme because of the carrier bearing cross member no granted a stock truck CAN run a 1pc driveshaft without it hitting the carrier bearing x-member but if your reall think about it GM designed the S10 as a truck 1st and foremost and said truck is designed to haul stuff and if you haul alot of stuff in the bed it will lower the rear of the truck and cause BAD things to happen if there was a 1 pc driveshaft in there with a carrier bearing x-member in the way all 2wd X-cabs have the same frame whether ist an xtreme, ZQ8 or regular suspension with means that even tho the xtreme isnt rated to carry as much weight in the bed as a Z85 truck the frame itself is designed the exact same way no matter what suspension is attached to it and all 2nd gen ex cab frames have a carrier bearing x-member which is why it makes it all but impossible for any 2wd ex cab to have a 1 pc driveshaft from the factory especially just xtremes |
IYAOYAS
where did you buy the yoke parts from?
Diesel Fan
i bought mine at a local shop....
big pimpin'
so if was just doin this 02 as a sport truck a one piece would work cuz im not putin a load in it just a box cover,and what year of full size is it?
Diesel Fan
its newer fullsizes that have them like 2000 and up 2500's....they might go back older then that but im not sure. You can do it with no problems but it could hit the floor in the ext cab area....i cut my floor and welded a piece of metale the extend the tranny tunnel...i will get pics of it sometime...
The Anti-Hick
If you're a hard core racer, you'll break them fast. I've seen brand new 5" ones snapped in two on mildly powerful cars. If you're racing, stay with steel, or go with carbon fiber.
Diesel Fan
ive been running this for awhile now...its went 11.2's at 122 with no problems with wheel hop and all last season...
ol' bodybuilder
Sounded like a good idea. Last edited by developed : 03-10-2006 at 08:11 PM. |
Diesel Fan
when you put in a single piece you cut out the carrier bearing crossmember. You no longer need it with a single piece driveshaft. The reason they dont run a single piece is because it hits the floor for one and two when you load the bed up alot it would throw the pinion angle way off on a factory truck. I corrected this by adding 4 degress shim to the rear to correct the pinion angle.
ol' bodybuilder
(should have stated this in the first post buddy)Tell me if I'm reading this correctly. If you shim/tilt up the axle 4 degrees, you don't need to cut the floor? What did you use for the 4 degree shim? |
The Anti-Hick
Not fast (yet) or heavy enough. |
#24 |
Diesel Fan
its going to go 10' on the driveshaft this year. actually i shimmed the rearend down 4 degrees to correct for the pinion angle for when i launch.
#25 |
The Anti-Hick
I had two buddies in early 80's Trans Ams with custom aluminum driveshafts (4") snap them in two the first time they launched on them at Norwalk in OH. Be careful.
#26 |
Im from the detroit Michigan area and i had a 2 piece shaft snap on my dumba$$ so here i am with 2 options:1. I can have the double cardan joint eliminated and keep a two piece and I am actually gonna have the spring perches rewelded onto the rearend instead of using shims 2.I can have the 1 piece 4" aluminum 1996 chevy fullsize driveshaft made to fit(which doesnt fit presently) the guy told me the end caps off of it will actually fit into 5" aluminum tubing. I like the idea of the 5" one piece and i already clearanced the floor for the 4". But i have had problems with the midshift bearing in 2 different s10's ive owned. So i was wondering if the was a better midshift bearing out there? Also i was wondering if it affects the frame negatively when you cut out the carrier bearing cross member?
#27 |
Diesel Fan
actually thats a misprint i never noticed i have a 5" aluminum driveshaft from a 2500....there isnt really another carrier bearing the whole 2 peice driveshaft is a crappy design to start with. The fullsize driveshafts will be like 8" longer then you will need but anyplace can shorten it.
#28 |
Well after saving a little money and waiting a little bit, and then finally talking to a drive shaft shop/guy that isnt going to bullshit me. There is a drive shaft shop called CCI out about 30 minutes from detroit,MI. The whole operation is owned by a guy named mike and its a family operation. Well anyways unlike some of the local rear end guys and suspension guys when i told him of my problem....he came right out into the parking lot with me and crawled under my truck with me and took a look. So long story short he told me he can build me a 5 inch one piece aluminum or rebuild the back half of a two piece, either way I will NOT be able to break it. Well i told him that i was told a one piece is better/stronger he told me with alot of driveshafts he builds the cars are too fast to have a one piece...(not to sure what that means) so he makes them a two piece. If i used the one piece id have to clearance the floor more and remove the crossmember...he also told me that if I bottom out or hit that aluminum on anything even once it would be done. So with all that said he said he can build me a two piece to outlast my truck that will never give me a problem. Also from what i am told by local guys is CCI is the shit. Mike told me that that build hundreds of 2 piece s10 driveshafts more than anyone else in MI. So in all this I am not saying one way is better but I am getting it done this week. If i have any regerets or problems ill post and let ya know.
#29 |
Diesel Fan
This is true you do have to clearance the floor as stated above...plus if you hit the aluminum and dent it then you are pretty much done..Im running a single piece 5" and my truck is lowered 4" all the way around and i havent had any problems with it. With a single piece over a 2 piece there is less drivetrain loss. I dont understand how a car is to fast for a single piece driveshaft?
#30 |
ol' bodybuilder
#31 |
like i said im not saying which way anyone should go i just said the way i was gonna go. As far as being too fast for a one piece ill have him explaing to me and get back to you guys...either way this guy does nothing but driveshafts day in and day out and hes been noting but helpful ...so all the mechanics and shop guys around me say they are The shop to go to. So i guess well have to see i'll be the test subject |
#32 |
No update on this?
I think what the driveshaft shop might have been refering to, in going too fast for a one piece shaft, is because of the longer length and the lower u-joint angle, the shaft would be allowed to vibrate more. |
#33 |
ol' bodybuilder
#34 |
#35 |
Drag Truck In Making
Location: Westwego, LA outside of New Orleans User is: OffLine |
Hey. I don't know if its been stated or not, but they're not just on 2500. I had a 97 Long bed 1500 with a 4.3L and the 4L60E trans. It had a long thick aluminum diveshaft. Quite light. I might source out one for my 02 xcab sonoma, but Im more interested in a posi unit with some 3.55 or 3.73's.
#36 |
Chevy and GMC 's rule all
So wat do O do when swapping out an 4wd auto tranny for a 2wd auto tranny? I have a 2 piece driveshaft? do I have to have a 1 piece or can I still use my 2 piece? yes I have extended cab but I cannot find a 4x4 auto 700r4 4l60 tranny anywhere so I have to deal with a 2wd swap! anyone know what shaft I need for this? any info appreciated!
#37 |
ol' bodybuilder
Do you know what the angle is on drop blocks for extended cabs - I don't believe it's 4 degrees? I'm doing 3" dropped springs and a 1" block. Would it be better to get regular cab blocks (no angle cut) and 4 degree shims? Or - would it be better to get the extended cab blocks and make up the difference with a shim to achieve a total of 4 degree angle? Thanks |
#38 |
\X/
I measured my 2nd gen extended cab and there is no way to fit a one piece without radically cutting the cab up. I'm only lowered about 3 inches and it looks too close for me. What would be nice is to bolt on some sort of extension to the back of the tranny to get the first u-joint past the low spot. Maybe like an external overdrive for the older trannies or even a gutted transfer case....
#39 |
Diesel Fan
for a 2 wheel drive there isnt really anything you can bolt on. This is one reason the truck did not come with a 2 piece driveshaft due to the clearance issues. The only way it will fit is to cut the a piece of floor out of the extended cab and add a cover. I cut out about a 12" piece and bent up a piece of metal to cover the hole up. You could also get a custom 2-1/2 or 3" steel driveshaft for around $300.
#40 |
Any clearance problems with a regular cab/long bed? I'm assuming the 2-piece driveshaft is the same set-up as the ex-cab. Same frame under ex-cab/short bed as reg cab/long bed, right?
#41 |
Diesel Fan
im not sure about the long beds but if i had to guess i would say that the driveshaft would clear in the reg cab long bed trucks.
#42 |
\X/
Does a one piece work or not on a 2nd gen x-cab lowered? I measured mine and don't think so.... but i do have a the tranny spacer in right now also. also this tells me it's possible: http://www.s10forum.com/forum/f13/da...arning-201468/ |
#43 |
\X/
I was measuring the max travel i would get from axle to frame... but the max travel I can possibly get right now is much less due to one of the cross members I DO think a one piece will fit on a 2nd gen lowered with some trimming of a brace underneath the cab and possibly removing the carrier barring crossmember |
#44 |
Diesel Fan
you would have to remove the carrier bearing cross member and probally cut a whole in the floor of the xtended cab and lengthen the tranny tunnel. Thats what i did with mine and it clears with no problems.
#45 |
\X/
what about if i used a 4" or 3" shaft? check this: http://www.s10forum.com/forum/f13/da...arning-201468/ |
#46 |
ok i dont know if someone has said this or if my truck is just different cause it was a govt truck. but my 99 s10 ext cab 4x4 has a single piece aluminum shaft. i dont know if it will work but just a thought.
never mind being a 4x4 there is a transferr case and thhus it would be to short Last edited by DEADMANWALKING : 03-15-2007 at 02:40 PM. |
#47 |
\X/
I started a new thread on my install:
http://www.s10forum.com/forum/f13/al...ed-cab-285745/ |
#48 |
IT HAS THE 4" ALUMINUM DRIVESHAFT. I've had difficulty finding ANY parts catalog info on this driveshaft for my stock SL Original owner says it came from the factory. He had no clue. I saw one blurb on a net site yesterday that talked about the 1997 S10 SS with "the unusual 4" aluminum driveshaft" but none of the SS "boyz" in the forums ever mentioned it when arguing about SS specs. I was unable to join in. WHO KNOWS THE STORY ON THIS ? Thanks, folks. Bill O |
#49 |
constant velocity joint. that is the issue, big time vibration and noise.
common problem with lowered s-10. single piece shaft was the ansewer. l was told re on the original will have u returning. local guy takes the original, cuts it , welds it making it one piece. i should get the car back this wednesday. i will post pics. i was only 9000km from warranty. cost all done around 850 cdn |
#50 |
Weres The Paint?
ya ive got a 3/5 lower and i was hawling my bike in the back over the weakend and broke my drive shaft were it goes into the reaar end. ive been looking all day for one and everyones is telling me thats its hard to find cause they only made that drive shaft for a 98 ex cab 4.3lt. can anyhow help me out or give me some suggestions what to do.? i have NO WHEELS. thanks
