Air bubbles in trans fluid?? - S-10 Forum
post #1 of 5 Old 05-21-2002, 06:56 PM Thread Starter
User is: VegasGMC is offline
When I check the fluid the end of the dip stick had bubbles on it, almost like foam. Trans works fine except the converter constantly cycles in third. Fluid isnt burned and Ive always used synthetic and no leaks. Im wondering if its a cracled valve body. Been hearing about alot of those in the 4L60E's. I dont trust any shops here especially the idiots at the dealership.
1993 S15 2 door 4x4, Vortec 4.3 with MSD ignition and Blaster coil, Accel 8.8 wires, Autolite plugs, homemade intake with K&N filter, filter box opened up, 18" 2 speed Mustang fan, ADS Superchip, timing advanced 4 degrees, 180a alt. Now have a '06 Xterra. Moms driving the Jimmy.
VegasGMC is offline
post #2 of 5 Old 05-22-2002, 03:05 AM
ZQ8 2001
DoubleDown's Avatar
User is: DoubleDown is offline
i recommend Dudley's transmission on Highland. guy named Todd runs the place, does great work IMO.
2001 Black ZQ8
post #3 of 5 Old 05-24-2002, 10:03 PM
SS Member
User is: 97-S10-SS is offline
I 2nd that they built my trans for my race car!!!!
97 S10 SS White,Cowl Induction Hood,Edelbrock TES headers,Airaid Intake W/K&N Filter, Caspers TPS-TEC,MSD 6AL,March Pullies,B&M Shift Improver,Flowmaster, Maf Screen Removed.
post #4 of 5 Old 05-25-2002, 12:58 AM Thread Starter
I made the mistake of letting Pep Boys change my filter the last time. They ended up stripping my manifold and donut bolts. I bet the idiot didnt get the filter in right and thats where its pulling in air. Thanks
VegasGMC is offline
post #5 of 5 Old 05-26-2002, 05:46 AM
User is: rick is offline
Filter
Make sure that the old rubber gasket comes out with the filter!If you mount the new filter with the old gasket still stuck in the hole,the new filter will suck air!Look into it soon,this can cause you serious problems.
rick is offline
