Adjusting 4L60E tranny TV Cable?? - S-10 Forum
post #1 of 7 Old 09-04-2007, 03:05 PM Thread Starter
I Like Fire....HaHaHa
JACKEL's Avatar
User is: JACKEL is offline
Can it be adjusted and how?
JACKEL is offline
post #2 of 7 Old 09-04-2007, 09:52 PM
goin broke but n style
S15vortecpwr's Avatar
Re: Adjusting 4L60E tranny TV Cable??
no, it doesn't have one,
I have not seen a 4l60e with one. A 700R4 does.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #3 of 7 Old 09-04-2007, 10:10 PM
import killer
syclonekid43's Avatar
User is: syclonekid43 is offline
Send a message via AIM to syclonekid43 Send a message via Yahoo to syclonekid43
unless he has a 4l60.
on my 92 when i hooked up the scan tool. it shows a 700r4/4l60
91' syclone (0465)
88' tuneport gta
93' 4dr jimmy
93' blazer
88' s-10 blazer (2 wd)
01' raptor
97' mxz 670 yamaha ysr 50 with a 125 cc 6-speed
THE SURGEON GENERAL WARNING NEVER SAID ANYTHING ABOUT SMOKING A FORD
post #4 of 7 Old 09-05-2007, 02:00 AM
Mikz86TA's Avatar
User is: Mikz86TA is offline
If it is a non electronic 700R4...as in a 4L60E it shouldnt have it. If its a 700R4 or 4L60, then it does. The TV cable should only be adjusted to its set position and is not used to adjust shifting and such. If you do use it to adjust your shifts, you are not going to do any good. It will shorten the trannys life. Now, to reset it correctly, find the TV adjuster at the throttle lever on the Carb, TBI or TB unit. This one pulls out as throttle is increased and is usually attached to the bottom. After you find it, look at where it its mounted to the bracket. There is a round or d-shaped button. Press it in and push the cable sleeving toward the firewall/ away from the throttle plate. Once all the way back, rotate the throttle to wide open (WOT). The TV cable sleeve will 'ratchet' out to the correct set position. Pending its the original and proper cable. The TV adjust the line pressure in the tranny according to the throttles position. More throttle the higher the pressure. The Governor is also responsible for line pressure in relation to road speed....but its main function is shift points. I wont get into the Governor and how it works in detail, but if you would like to know just ask. The springs and weights on the Governor are responsible for the shift RPMs. Hope this helps =)
2003 S-10 ZQ8 - 262/M5 1986 Pontiac Trans Am - 355/A4
The S10 Project : http://www.s10planet.com/forum/showthread.php?t=15987
The Trans Am Project : http://www.s10planet.com/forum/showthread.php?t=15435
Mikz86TA is offline
post #5 of 7 Old 09-05-2007, 07:17 AM Thread Starter
JACKEL's Avatar
You are correct, A little more research yesterday revealed I don't have a TV cable.
So, the question is, is there a way of adjusting the cable to the lever on the side of the tranny that coincides with the shifter on the column. It seems to be an 1/8" too long. I can drop the shifter into 1st, but the tranny doesn't get into first. I climb under the truck and have to flip the lever just another 1/8" for it to click fully into first. So, I think the cable is just a hair too long for some reason.
Anyway of adjusting it?
JACKEL is offline
post #6 of 7 Old 09-05-2007, 07:25 AM
11 second station wagon
The Stunningman's Avatar
User is: The Stunningman is offline
most 95 up use a adjustable shift cable which will move just like a tV cable adjuster. Chock the wheels, Climb under your truck and push in the cable adjustment button and adust it to first.... then make sure it still goes all the way in park.
post #7 of 7 Old 09-05-2007, 08:15 AM Thread Starter
JACKEL's Avatar
Man, I've tried that same routine for each gear and when I'm done, I can put it into park but still can't get it into first. Again, getting under there and flipping the lever that last 1/8" needed for it click into first manually at the trans. Its like no matter what I do, I can't get the bitch into 1st manually on the column.
JACKEL is offline
