95 chevy s10 problems with clutch disengaging - S-10 Forum
post #1 of 21 Old 05-23-2013, 10:41 PM Thread Starter
4 Year Intermediate Tech
greasemonkeys10's Avatar
User is: greasemonkeys10 is offline
Alright so the trans is a nv3500 and I just got done doing a new clutch, when I put the slave cylinder back in I forgot to line the slave pushrod up into the clutch fork dimple. I tested the pedal and it got really hard suddenly and the clutch pedal bushing went boom. Just the plastic piece. I pulled the slave back out and the pushrod was wedged behind the fork. I put it back in the dimple and bought a new bushing and installed the master cylinder rod back on the pedal, I soon got the pedal pressure back. So here's the problem, when I push it to the floor and slowly test reverse it will grind. It feels like its moving at idle speed. But if I shut it off put it in reverse and start it it doesn't bog the motor. When I pull it out of reverse while running and try to go back in its once again moving at engine speed. Is the slave damaged? Or will a bleed of the system work? Nothing was disconnected from the slave or master during the clutch install. It didn't bend the slave or master pushrod just the bushing clip broke. What do you guys think it is? Has the external slave btw on the pass side
1985 2.8L V6 S10 completely restored with 65,000 miles on body, frame, and rear axle. Weber 38 DGES Powered
Newest addition:
1995 Chevy S10 ext cab 4.3 Z COMPLETE 2000+ miles and counting.
post #2 of 21 Old 05-23-2013, 10:45 PM
AWD V8's Avatar
User is: AWD V8 is offline
Re: 95 chevy s10 problems with clutch disengaging
You need to try another method of bleeding.
The slave must be detached with the line still connected and tipped up so the bleeder is the highest point for the air.
I would also be best to reverse bleed, but try just the slave cylinder tilt first.
AWD V8 is offline
post #3 of 21 Old 05-23-2013, 10:57 PM Thread Starter
So every time you do a clutch you bleed it even though it was never disconnected? Is it just to take up the new slack from the added clutch? Il try the tilt method this weekend.
Newest addition:
post #4 of 21 Old 05-23-2013, 11:35 PM
AWD V8's Avatar
Ah, I assumed you opened the line.
Was the old clutch releasing OK?
What brand is the new clutch? Not real likely the new clutch is bad but I've had a few in my time.
AWD V8 is offline
post #5 of 21 Old 05-23-2013, 11:48 PM Thread Starter
Oh yeah old one released great. Replaced it with the same valeo clutch and pressure plate that was on it and had the flywheel resurfaced. When I put the slave back in and bolted it up the pushrod wasn't in the fork it was laying their. When I pushed the pedal it got super hard and jammed the slave rod way in their . Maybe it's damaged from over extension. Bleeding it might fix it I hope. When I could shift it after work today the clutch worked great. Lots of bite to it.
Newest addition:
post #6 of 21 Old 05-24-2013, 12:14 AM
AWD V8's Avatar
I don't think your incident with the push rod damaged anything.
Causes of a clutch not releasing are;
- Air in the system. Right now I wouldn't suspect anything here, but I wouldn't rule it out completely.
- Transmission input shaft tight in bushing. If the shaft is tight in the bushing in the flywheel the shaft will continue to spin even with the clutch depressed.
- A warped clutch disc. If during the install the transmission was allowed to hang down the transmission input shaft can twist the clutch disc and once finally installed the clutch disc will always drag on the flywheel and clutch cover.
- And the clutch itself can be made poor. I've used Valeo before without problems.
I'd try bleeding it to remove that as a possibility, then consider the other causes.
I once wnet through 5 clutches on a Jeep before I changed brands and then it worked.
AWD V8 is offline
post #7 of 21 Old 05-24-2013, 01:00 AM Thread Starter
Uh oh I just remembered something. When I put up the trans I remember after I got the splines in I carefully used the bell bolts to help pull up the trans the rest of the way which was not a very long distance. The dowels on the block were almost barely through the bellhousing.
Newest addition:
post #8 of 21 Old 05-24-2013, 01:08 AM Thread Starter
I think it's probably tight in the pilot. I didn't really know how far to go with the bushing so I put it at the same depth as the old one
Newest addition:
post #9 of 21 Old 05-24-2013, 08:01 AM Thread Starter
Thanks for helping out v8, i think I know what it is. I'm new to the nv3500, this time il take off the pressure plate and clutch disk and test fit the trans before I do final assembly. I bet if I knock the pilot bushing back a 1/4" it will slide right up. Ugh rookie mistake. Going to cost me a lot of labor but at least I didn't get the exhaust welded up so it should only take a day or 2 il post back the results after its done.
Newest addition:
post #10 of 21 Old 05-27-2013, 10:47 AM Thread Starter
Update, I pulled the trans and carefully removed the pressure plate and clutch. Pressed out the pilot with a couple pieces of soft white bread and started looking. The only thing I noticed is a light scuffing on the input shaft and the pilot that come with the kit was made of iron and steel. Pressed the brass bushing I took out in its place and put the trans back up. Sure enough it slid in like butter. So much so that it wedged my fingers. Pretty sure it's going to work this time around.
Newest addition:
post #11 of 21 Old 05-27-2013, 11:41 AM
Registered Hoosier
Hoosier Rick's Avatar
I have had the same problem with resurfaced flywheels. I depends on how much is removed from them. In effect, it moves the flywheel and clutch away from the slave cylinder. When the clutch pedal is depressed all the way, the arm is too far away to release the clutch fully. Since I started either reusuing the flywheel as is, or replacing it with new, I have not had a problem. I fixed some by lengthening the push rod
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #12 of 21 Old 05-27-2013, 02:40 PM Thread Starter
well i got some bad news but i think i know what it is. the slave isnt working like its supposed to. doesnt extend very far anymore after i over extended it going to try a new slave
Newest addition:
post #13 of 21 Old 05-27-2013, 02:54 PM Thread Starter
Can someone tell me how to remove the quik connect line at the end? has a small pin in it too, nothing to open like a nut.
Newest addition:
post #14 of 21 Old 05-27-2013, 10:07 PM Thread Starter
Alright I got a new slave bench bled it before install but I noticed something when I had my brother pumping the clutch. The master cylinder was pushing fluid up through the bottom when pressed. It made the fluid kind of jump up like a little spike. Also noticed that the master was not providing enough push to break the bands on the slave that hold it down before install. So I think I trashed the master when I tried to force the pedal. I also found debris floating in the master and it looks like it may have leaked at one time because of the rust stains and flaked paint right under the master. I guess my little incident put it six feet under. Il try a new master cylinder after I get paid. Il repost lster after I replace it. If that doesn't fix it then its probably going to need a flywheel shim.
Newest addition:
post #15 of 21 Old 05-28-2013, 11:01 AM Thread Starter
Well tried messing with it again this morning and finally got things working. I disconnected the master from the firewall and held it 45 degrees with a zip tie. I then disconnected the slave and held it 45 degrees and pumped the slave pushrod and heard a huge gurgle pop sound from up top. I pumped it about 15 times. Put everything back together accept for the cruise control box (don't use it so why have it in their) and pumped the clutch pedal about 50 times. Topped of fluid and started. At first it didn't want to go into gear like before. So I pumped the pedal 5 times and presto. I can now fully disengage the clutch, and the trans spin down time is about 6 seconds or less. Ran it hot to see if anything was going to bind, but nothing did. Sweet, I didn't think getting air out of this system was that much of a pain. Thanks for the trouble shooting. Learned a lot about this manual trans system. This 95 is my first 5 speed s10. Can't believe I got it for 1200.
Newest addition:
post #16 of 21 Old 05-28-2013, 11:04 AM Thread Starter
Here's my 95 ext cab chevy.
Newest addition:
post #17 of 21 Old 06-03-2013, 10:27 AM Thread Starter
Well thought I fixed it but turns out it was a fluke. Drove all the way to town no problems until I started hitting lights. Trans would not go into 1st at all just like if the clutch wasn't fully disengaging so I tried dropping it in second. Bam threw the stick right out of gear. Tried third, it went in and I was able to get going. It did this to me at every place I had to stop at. Now when I push the pedal I hear a click somewhere under the hood
Newest addition:
post #18 of 21 Old 06-03-2013, 10:31 AM Thread Starter
Just tried a test here in the parking lot. If I mash the clutch pedal with it running to the point my foot hurts and it digs into the carpet I can get it to allow me into first with slight resistance. Ugh this drive home is not going to be fun at all.
Newest addition:
post #19 of 21 Old 06-04-2013, 08:43 AM Thread Starter
Well found what it was, the clutch pedal pin that attaches the mc pushrod to the pedal keeps sliding out of place. Is their something else that needs to go on the pin besides the plastic bushing? Is their a cotter pin somewhere on it or locking washer? I didn't find anything on the floor when it grenaded except for the plastic clip.
Newest addition:
post #20 of 21 Old 06-04-2013, 08:57 AM
User is: bigboy25 is offline
hey grease monkey need to ask u some questions about ur clutch
bigboy25 is offline
post #21 of 21 Old 06-04-2013, 06:15 PM Thread Starter
I can try and help what's up
Newest addition:
