4l60e Problems and Solutions - Page 6 - S-10 Forum
post #251 of 377 Old 01-23-2012, 07:56 PM
User is: slugger94 is offline
Re: 4l60e Problems and Solutions
Originally Posted by Ed98 View Post
Did you read through that link in post 242? It lists 30 complaints and their causes.
i checked the codes on my truck and i had a O2 sensor tht is malfunctioning with is due to i need to put a gasket on it and the other caode was for heater curcuit malfunction cause my heat dont work...nothing about the trans and it still does it... still in need of help...
post #252 of 377 Old 01-30-2012, 02:52 AM
User is: jennifer.clifford is offline
The 4L60-E is an automatic shift, four-speed overdrive, longitudinally positioned transmission. It has been considered to be the best rendition of the finest overdrive automatic transmission ever produced. The 4L60-E is found in nearly every GM rear-wheel-drive application, including the C/K Truck, Sonoma, Jimmy, Tahoe, Yukon, Astro, Safari, Suburban, Bravada, Firebird, Camaro and Corvette
Before the Late 4L60-E transmission, there was the Turbo 700R, which was introduced in 1982.
post #253 of 377 Old 01-31-2012, 02:51 AM
User is: jeohkrun is offline
Free informatiion is provided to assist you in trouble shooting your 4L60E problems. Data on transmission specification is provided along with maintenance data. Inaddition we provide a large inventory selection for 4L60E electronic controlled automatic transmission overhaul kits, parts including steels, kits, solenoids, filters, solenoids. This wide selection of parts are used in the GM 4L60E automatic transmission in GM Chevy Camaro, Corvette, S10 pickup trucks and blazers, Tahoe, Astro Van, Suburban, Pontiac Firebird, in C and K Series Pickups, GMC Sonoma, Jimmy, Yukon Safari and Oldsmobile Bravada. In addition to these master overhaul kits we also supply torque converters, fluids, problem prevention kits and in most cases we can supply good take out hard parts and save you some money!
jeohkrun is offline
post #254 of 377 Old 01-31-2012, 03:43 AM
Ford guy stuck w/ chebby
n8rsk8r's Avatar
User is: n8rsk8r is offline
Originally Posted by KC10Chief View Post
I have symptoms 2 AND 6!
This is actually in my 1997 GMC Safari van but the transmission and engine are the same as the S-10. You guys are always helpful with my S-10 issues so I figured I'd ask! This started suddenly. I was driving last night and everything was perfectly fine. Went out this morning to drive and it wouldn't go into gear at all at first. It was cold too. About 15 degrees. It had been down into the single digits overnight. Any thoughts on what this could be? After it warmed up a bit, I could get it into gear but was having symptoms 2 and 6. Thanks for any ideas!
sounds like what my last trans, the one I just took out's problem. I had to let the fluid warm up before it would do anything.
No movement what so ever is blown pump. If you have a 13vane.. those are actually prone to exploding.
I might be able to tear the trans down soon.. When I do I will update with all the problems. The teardown can take some time, A LOT of parts.. but if you are looking to rebuild.. I will have my rebuild video done relatively soon.
1999 2WD Automatic S10 standard cab.
I have nearly rebuilt this damn truck 100%!!
n8rsk8r is offline
post #255 of 377 Old 01-31-2012, 03:57 AM
n8rsk8r's Avatar
Originally Posted by blackbeautychevy View Post
i have a 96 chev with a 4l60e, i recently removed the computer from it. i installed the transgo shift kit TRG-4L60E-3, it slipped from 1st to second when more than half throttle, and a 2 second nutrel pause between 2nd to third. 4th gear is lost somewere, just recently when i down shift or release the gas i have no hookup. it goes into "nutrel" but upon applying gas it re-engages. when foot off gas i can shift threw any forward gear and not feel it shift or have holdback from down shifting. any thoughts?
Stick shift, full manual control, converts back to automatic. For transplant or use with no electrical, includes 46-MOD (vacuum controlled line pressure).
you would use this kit if you wanted to basically convert the 4L60E to a manual shifted trans that is vacuum pressure controlled NOT electrical.
So basically you are turning a 4L60E into a 700R4 transmission.. only making it have the ability to manually shift..
tell me you went this route and didn't install this thinking you could still use it as it had been before.. if someone sold you this as a "fix" they need to be drop kicked in the dink..
n8rsk8r is offline
post #256 of 377 Old 01-31-2012, 04:02 AM
n8rsk8r's Avatar
slugger..
that bad o2 could mean the cat is bad.. you have to make sure of the code.. if it says o2 threshold is below.. blah blah blah.. it is more than likely your cat that is bad.. but after only 26k.. not sure..
as far as your trans is concerned.. sounds like it is doing what it does.. or should.
you want it to shift back and forth if it needs.. could you just be a bit paranoid in the shifting? I tell you what, I still have not totally tromped on my trans yet. I NOW have 501.3miles on it. I did however test it's mojo on the highway on ramp until those fun loving drivers going UNDER the speed limit stopped my testing
Get that other stuff fixed and get back to us.. hell post up if you need help with that stuff too.
n8rsk8r is offline
post #257 of 377 Old 01-31-2012, 11:25 AM
User is: sclarke is offline
im trying to find a trans for my 94 s10 4x4 but everything i find says it is for engine code w,i have engine code z, will these not interchange? 4.3,4l60e
sclarke is offline
post #258 of 377 Old 01-31-2012, 02:01 PM
n8rsk8r's Avatar
what are the differences in the vin #?
n8rsk8r is offline
post #259 of 377 Old 02-01-2012, 02:00 AM
User is: RedNecksRus is offline
1998 chevy s10 2.2 4l60e, zn4 option which means 99 drivetrain so i understand anyway lol... what year trans will interchange if any?? I know they changed the electronics around a good bit with different years but any help would be greatly apprecieted...
post #260 of 377 Old 02-01-2012, 02:23 AM
n8rsk8r's Avatar
In 2001 the valve body gasket changed. There is a spot on the valve body that is different also. I will try to find a picture of that.
found this on the webbings..
95 4l60e is a year all on its own with no direct interchange. you cant use the 93-94 because they did not use the pwm solenoid. 96 was the start of the removable bell housing and 6 bolt tail on the 4.3 models. 95 also uses 10-15 ohm shift solenoids VS 20-31 ohm 96 -up
n8rsk8r is offline
post #261 of 377 Old 02-01-2012, 02:28 AM
n8rsk8r's Avatar
honestly, any of you guys wondering about the transmission should buy that dvd. It will tell you years, differences, all kinds of useful information.. common problems..
look on youtube for them also. You can see a portion of it from that alone.
n8rsk8r is offline
post #262 of 377 Old 02-01-2012, 05:14 PM
n8rsk8r's Avatar
http://www.bulkpart.com/Merchant2/gr...00R4-4L60E.pdf
n8rsk8r is offline
post #263 of 377 Old 02-01-2012, 10:25 PM
n8rsk8r's Avatar
This is AWESOME! Info. This is a breakdown of all the changes that took place, actually starts at the 700R4 and comes current:
http://www.novak-adapt.com/knowledge/4l60e.htm
n8rsk8r is offline
post #264 of 377 Old 02-13-2012, 09:05 AM
iFail
User is: Squeegee is offline
Send a message via AIM to Squeegee Send a message via MSN to Squeegee
When checking for power to the trans control solenloid and 3-2 shift solenoid is removal of the trans pan require?
www.thearcadeforum.com
Originally Posted by 99 BUCKET
NO! there is no bitch outta your league. Go kick her in the twat, Spit some chew on her and roll out.
Originally Posted by 1fast4by View Post
FK that. Im not a pussy, I have two guns, attached to my sholders.. click click, bang bang, facial death.
Squeegee is offline
post #265 of 377 Old 02-22-2012, 09:05 PM
User is: mtb87 is offline
I have a 98 pickup 2.2 with a 4l60-e. Is there any way to make it so it wont shift in to overdrive? Like a tow/haul switch some bigger trucks come with? thanks
mtb87 is offline
post #266 of 377 Old 04-22-2012, 03:50 PM
User is: yourlittlebuddy is offline
Originally Posted by 3.4blazerdude View Post
what about a 2-3 clunk/ bang under light load, but other gears shift fine.
what about domt shift in to 3rd unless you smash the gas then let off, dont slip 1 and 2 are good. it happen overnight
post #267 of 377 Old 04-22-2012, 03:55 PM
Registered Hoosier
Hoosier Rick's Avatar
That's easy. When towing, just put the shifter in "D" instead of "OD"
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #268 of 377 Old 05-10-2012, 01:02 AM
McBride73's Avatar
User is: McBride73 is offline
Originally Posted by kette89 View Post
27. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
ugh, another component to replace. oh well, it comes with owning an older truck(1987 with roughly 240K kms/150K miles)
1987 2dr jimmy 4x4 recovery in progress, new fuel filter, starter, alternator, shocks, EGR valve & solenoid, drivers half-shaft, BJ, fuel pump(shop bill of $321)wrote off, new DD; 1993 Dodge dakota sport 4x4
post #269 of 377 Old 05-12-2012, 06:27 PM
User is: oneguyfix is offline
Question Re: 4l60e Problems and Solutions
Sorry but not sure how to post. I have a 2003 Chevy S-10, Automatic, 6 cylinder, 4.3 engine. I got the engine hot and bent a valve. I replaced the head gasket and valve. My truck ran great for a day but the next day, it wouldn't shift gears right (I had to take my foot off the gas pedal inorder to shift), it felt like it was accelerating on its own and not much power. Service engine code came up re: the crankshaft sensor so I replaced it, the heat sensor and pigtail and finally the distributor cap and I am still having problems. I thought maybe I needed to adjust the advance on the timing but still having the same problems. It feels like the overdrive is not kicking it. The rpm dial just skyrockets if I try to accelerate. Very frustrated. I drive 40 to get to work and don't want to damage the engine. Any advice would be greatly appreciated. Please Please help! I took the day off to look at the engine and try to figure it out. Thank you very much. Rick
post #270 of 377 Old 06-13-2012, 05:01 PM
User is: Prater is offline
I have a 2000' 2.2 s10 automatic and it just started shifting itself out of drive down to 3rd gear after 60 miles or so. I can shut the key off and restart the truck and it's fine for another 60 miles or so. Any ideas...
Prater is offline
post #271 of 377 Old 06-20-2012, 07:44 AM
Headknocker
99street10's Avatar
User is: 99street10 is offline
Send a message via AIM to 99street10
Hey guys 99 s10 2.2L Auto 110,XXX miles.
I had the trans rebuilt (2.5 years ago with 89,XXX miles on it- sunshell died)
Well, I no longer have a warranty and my truck is acting up again.
If I come to a complete stop and press the gas there is a delay before it starts moving. However if I let off the brake and let the truck roll for a second or two and ease into the throttle the problem is not there. This doesn't happen all the time like every other time I drive it. I checked the fluid and it looked and smelled fine.
Any advice is appreciated!
Also, been away from s10forum for awhile... nice to be back trolling the threads.
Money Comes and Money Goes, but Rat Fink is forever
For Sale/Trade
COMP Cam and Lifter Kit(sbc)
Wanted to Buy/Trade For
Performance Pullies, Header
(All parts wanted are for 99' 2.2L)
post #272 of 377 Old 06-20-2012, 04:24 PM
Headknocker
99street10's Avatar
someone please tell me i'm not the only one with this problem!
For Sale/Trade
post #273 of 377 Old 07-01-2012, 04:22 PM
70shorty's Avatar
User is: 70shorty is offline
Hey,, been awhile,, I seem to have the problems stated in #22,, won't go into 4th or third, but will have drive in second and first. I have to manually shift from second into third then into OD.Then everything works fine until I come to a stop then have to down shift manually. It all starts over again. WTH??vss acting up?
70shorty is offline
post #274 of 377 Old 07-01-2012, 10:44 PM
User is: wolfygmc is offline
#5 seems like what i have. this is the 3rd trans i put in and i replaced the lines, radiator, and filter. but when i put it in drive it wont leave 1st gear and u have to over rev the engine to make it go but when stoped in drive the hole truck shakes. idk whats wrong. i have a 1994 gmc jimmy. auto, 4x4, 4door.
wolfygmc is offline
post #275 of 377 Old 07-02-2012, 10:12 AM
User is: gornati is offline
i dont know if my issue is a transmission issue or what, but i think it worth giving a shot.
1995 S10 SS, 100.000 miles
Car runs if is not WOT.
Let me try to explain.
If you go WOT with the selector in OD, runs fine until 3500-4000rpm then fells slugish, fells like is losing power, and when if changes from 1st to 2nd, you can fell a kick, if driveway is wet you can fell it losing traction.
I dont know if i am being clear, but engine RPM goes up, but speed wont, but when it switches from 1st to 2nd, car really goes.
gornati is offline
post #276 of 377 Old 08-12-2012, 10:54 PM
User is: AwesomeS10 is offline
[COLOR="Blue"]Call Bowtie Overdrives for all your transmission problems! They can for sure help they offer free technical advice Mon-Fri 8am -5 pm
Last edited by philntx; 08-14-2012 at 05:52 PM. Reason: Sorry, supplier is not a paid advertiser. Phone number deleted.
post #277 of 377 Old 08-12-2012, 10:55 PM
They fixed me up good! Handled My Trans and I have never been Happier w/ my truck!
post #278 of 377 Old 08-18-2012, 04:27 PM
n8rsk8r's Avatar
transmissions are a beast.
You have to first get codes.
If no codes, check the wiring there will be some issues.
Once you get codes you can diagnose
If you don't get codes it is more than likely a computer issue. The computer issue is damn near always overlooked. Why is this?
I have been experiencing some gnarly shit on my trans, stuff that is not covered anywhere on any known troubleshooting guides or written about.
You have to basically immerse yourself into the transmission and its functions and how it relates to all other functions of the vehicle. Run down each one, trouble shoot each one so you can get it figured out so you can eliminate what the bad from good.
Then you can come back to the transmission. But not until then.
Transmissions are complicated, and that is why transmission shops are chalk full of business all the time..
with my last build, it, the build, went great aside from a sales guy who didn't know what the **** he was talking about and sold me the wrong converter.. and it overheated (went to shit) and that was what initially tore the trans up. The rest, an electrical issue on my truck tore the build up even further.. and I try to keep up on things, and try to make sure it is all good throughout.. it is in my best interest to keep it going correctly.
that said.. our transmissions are electrically controlled meaning that in the valvebody (trans brain) it depends on these sensors to do what it is the trans calls on them to do.
The valve body is metal on metal, bores and valves. In some instances the bores are worn, and you have to change to a valve with rubber or other (teflon and other) seals that help to keep the pressure where it needs to go.
These wear out.. you are looking at trouble. then it gets into the case (steels and clutches and the apply pistons).. they are pretty easy when it comes down to it, just making sure the tolerances are correct and you have it made.
n8rsk8r is offline
post #279 of 377 Old 09-14-2012, 05:24 PM
99 ZR2 Auto Ex cab
User is: beatcars is offline
I thought I was having tranny probs. Ended up my throttle position sensor was bad. Causing erratic shifts that had symptoms similar to slipping. All better afrer a new TPS.
99 ZR2 Ex Cab
beatcars is offline
post #280 of 377 Old 09-24-2012, 07:17 PM
User is: guitarman is offline
My tranny seems to have developed problem starting more than a week ago.
I was getting on the interstate one day, and it just stopped shifting into 4th altogether.
I had the fluid flushed, filter replaced, and still had the same symptom. Then, about 4 days ago it stopped shifting into 1st on it's own. If I go to 1st manually it works, otherwise it takes off in 2nd from a stop (Also the 2-3 shift seems to be delayed). However, when it's cold it will take off in 1st for a few minutes.
I haven't heard any odd noises, nor have I felt it slip. No jerking when I put it in gear from Park, and reverse works fine.
I was curious if it might be a bad solenoid, but I've yet to see the dummy light turn on since this began.
post #281 of 377 Old 09-24-2012, 10:02 PM
User is: Chubbin707 is offline
My 85 700R4 shifts into overdrive at around 35 mph and if I floor the throttle it wont downshift unless I manually shift it. Tv cable is adjusted properly and I am at a loss.
post #282 of 377 Old 09-25-2012, 02:13 AM
n8rsk8r's Avatar
Chubbin.. if you have a 700r you probably have problems with the seperator plate and the check balls at the least.. they wear like a mutha..
The 700r is a governor regulated trans. are you sure it is OD and not another gear and other gears are just not coming on?
n8rsk8r is offline
post #283 of 377 Old 09-25-2012, 02:16 AM
n8rsk8r's Avatar
check out that site I posted about the 30 top problems with the trans. I cannot for the life of me remember off hand what it was, but there is a particular reason this happens.. check it out.. you described it perfectly.
n8rsk8r is offline
post #284 of 377 Old 09-25-2012, 04:01 PM
Thanks I will buy a kit and see if that helps. I'm positive it goes to overdrive because I can count the shifts but doesnt stay in drive long maybe 30 seconds. I also bought a tv replacement sleeve and plunger to try that. Hopefully the rack will be free soon so I can install all of this.
post #285 of 377 Old 09-27-2012, 01:42 PM
99 ZR2 Auto Ex cab
Monitor the rpms, and what they should be. Mine was having a deal where it would get into OD, but the torque converter would never lock up. So teh rpms went down from D, but not as low as they should have been when teh TC locked up in OD.
This was the 4l60e
99 ZR2 Ex Cab
beatcars is offline
post #286 of 377 Old 10-03-2012, 06:14 PM
This was the 4l60e
Thanks I think I have an aftermarket tach I can put in and check that. I appreciate the help. Hopefully I can check it out within a couple days
post #287 of 377 Old 10-31-2012, 12:48 PM
User is: 95gmc is offline
im having a problem with my truck going in second and not coming out after you floor it off the line into second. you can manually putt in 1st but its still in second. but is back to normal after you park and pull the key out for ten seconds or so and restarting it.
any ideas?
95gmc is offline
post #288 of 377 Old 01-17-2013, 11:34 PM
2000S106.0's Avatar
User is: 2000S106.0 is offline
I have a problem and I am hoping someone will get on and help me. I have looked at all the scenarios and everybody else's but mine is different. It sometimes is a little sluggish/slip from a dead stop, but not every time, occasionally revs a little and shifts firm into second but not every time, 3rd gear is fine, also my truck sputters a couple of times before going into overdrive but not every time. Check engine light came on, hooked it up and all it said was trans component slipping. It's a cheap device and I know someone who has a better code reader and see what it says. If anybody can help me out with what my problem is I would greatly appreciate it.
post #289 of 377 Old 01-18-2013, 12:02 AM
Wanna Play a Game?
Countryboy732's Avatar
User is: Countryboy732 is offline
did you happen to get the code?
96 4-Dr Blazer 4x4 Sas'd
5.7 Vortec, 411 PCM, HPDana 30 Front Axle w/ 3" Waggy Lift Springs SUA, Ford 8.8 Rear SOA, 3.55's and 33's
Time To Get High
V8 Build Thread
post #290 of 377 Old 01-20-2013, 02:45 AM
2000S106.0's Avatar
I want to say it was p1870, which ever one it was it said trans component slipping
post #291 of 377 Old 01-22-2013, 09:06 PM
denis's Avatar
User is: denis is offline
Originally Posted by 2000S106.0 View Post
I have a problem and I am hoping someone will get on and help me. I have looked at all the scenarios and everybody else's but mine is different. It sometimes is a little sluggish/slip from a dead stop, but not every time, occasionally revs a little and shifts firm into second ...
If the code is DTC P1870 then look at post #5 in the following link:
http://www.s10forum.com/forum/f13/4l60e-issues-510334/
There is an old TSB (10 years old) for this problem. Also, it is a common problem caused in general by wear of the solenoid bore(s) in the Control Valve Body.
TSB QUOTE: This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Also, in the link above, there is reference to a MOTOR magazine article, which describes various aftermarket parts to 'solve' the bore wear problem.
And if not 'fixed' promptly, you will damage (destroy) your trans. Good luck.
denis is offline
post #292 of 377 Old 01-27-2013, 09:41 AM
RuDolf956's Avatar
User is: RuDolf956 is offline
So glad I found this thread. Thanks!
Totalled 2001 s-10 262
2000 s-10 262, 2wd, dropped 2/3, straight piped, TB Mod, No A/C, No P/S, E-fan, sideways steering wheel.
post #293 of 377 Old 01-28-2013, 10:03 PM
User is: SCmixer is offline
Originally Posted by putman91 View Post
I have a 2001 s10 4 cylinder. When I start driving it shifts normally into 1st, 2nd, and 3rd, but then seems to get stuck in 3rd and wont switch to overdrive. When I stop after driving this way at a stop light, etc., it seems as if it is still in 3rd and accelerates very slowly. While going approx 50mph the truck seems to rev high like it wants to go into overdrive, but wont shift. I had my transmission completely flushed about 2 months ago. When I turn my truck off and start it up again, the same problem happens again. What could this be?
Any luck figuring out what was going on? I am having the EXACT same problem. I back out of driveway, put it in D and take off in first, then as soon as I break and go to take off again it feels like I am towing 20 fat chicks. I then shift to N, shut the truck off / Restart and everything is ok for a minute until I stop again. I repeat the process and Im ok again. It seems as though after I drive for a while it kind of stops, but is happening more frequently.
What remedy did you come up with?
SCmixer is offline
post #294 of 377 Old 01-28-2013, 10:37 PM
Wanna Play a Game?
I'm pretty sure this is common on all gm models but if your tcc valve is faulty, od will not engage and 4th gear won't work after warm up and/or after key cycling. As for towing fat chicks, replace your throttle position sensor.
Time To Get High
V8 Build Thread
post #295 of 377 Old 02-02-2013, 04:51 PM
User is: 1933vette is offline
i just put valve body in i think i put wrong bolt in sun no reverse sur hate to drop pan again just to see
post #296 of 377 Old 02-04-2013, 02:02 AM
User is: DIXIEREBEL4X4 is offline
01 crew cab 4x4 4.3 178xxx miles truck runs fine from a dead stop if i floor it tranny doesn't shift to 2nd until about 4xxxrpms shifts fine in all other gears but if I easy on the gas its about 3xxxrpms and if im on the highway cruising and get on the gas hard it down shifts to first reeves to 4xxxrpms and then upshifts fine anybody have a clue as to what the hell is going on ive taken it to the Tranny guys 3 or 4 time and they say nothings wrong but I got a buddy with a 95 blazer 4.3 4x4 who kicks my ass everytime I tray to race him I know its not a race truck but I like to be able to get up and go if I need too
post #297 of 377 Old 02-08-2013, 02:45 PM
Wanna Play a Game?
Sounds to me like your tranny is running fine. He's only kicking your ass because he's probably manually shifting through the gears.
Time To Get High
V8 Build Thread
post #298 of 377 Old 02-12-2013, 09:29 PM
txpro1200's Avatar
User is: txpro1200 is offline
looking to have my 98 v6 tranny rebuilt,truck is mostly towing.have a trans go valve body plate in it,and have spring shift kit to go in.was told there is a heavier reverse/first clutch hub.anything else to get or it should have??has a aux cooler as well
AIN'T SCARED!!
post #299 of 377 Old 02-12-2013, 09:36 PM
Wanna Play a Game?
Deeper pan and filter and Corvette servo will help keep it cool.
Time To Get High
V8 Build Thread
post #300 of 377 Old 02-13-2013, 08:31 AM
txpro1200's Avatar
forgot to mention i did the factory deeper pan and filter,corvette servo??
AIN'T SCARED!!
