4L60E no 1st or OD sometimes
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 05-15-2008, 01:04 AM   #1
dc5282's Avatar
dc5282 is on a distinguished road
I have a 94 s1o 2.2 with a 4l60e transmission, when i bought the truck it acted like it wasnt starting out in 1st and it wouldnt go into OD.
the other day i got to messin with it i remove and replaced the ECM fuse, and worked on some vacuum lines and the transmission shift fine , started in 1st and changed into OD right on time. after about 40 miles, open road and in town, I was pulling away from a stop sign and it started shifting wrong again,
no 1st no OD,has code 83.Has 119,000 miles. Is this electrical or vacuum or what? sure could use some advice
Thanks
Old 05-16-2008, 06:54 PM   #2
I'm slap happy, bitches!
Deeze49686's Avatar
Deeze49686 is on a distinguished road
Re: 4L60E no 1st or OD sometimes
do you manually upshift it to get 2nd gear?
if you do, the trans is going to limp mode, or plain losing power.
if you have only 2nd in third in the drive position, then you ahve a bad shift solenoid, and those are easy to replace, and do both of them.
Old 05-16-2008, 11:34 PM   #3
dc5282's Avatar
no I put it in OD it starts out in 2nd, Ive thought about changing the solenoids, I just cant understand why it worked fine the other day, and then quit like it did, also i've changed the solenoids on my sons 98 s10 and it didn't do any better after I changed them.iv tried changing gears manually but it still wont go into first or OD, Ill probaly change out the solenoids but was trying to see if maybe could be something else..but i do appreciate the advice Ill take all i can get
Thanks
DC
Old 05-19-2008, 02:39 PM   #4
Steve44 is on a distinguished road
How did you make out? I have the exact same problem. What really bites is I just bought the truck yesterday and it was fine. It seems fine when the truck is cold, but within ten minutes, no 1st, and no OD.
Thanks
Old 05-19-2008, 07:17 PM   #5
Deeze49686's Avatar
change the solenoids, but take the pan off the right way, buy dropping the crossmember on the passenger side. you pry the pan out, you will break the solenoids.
Old 05-20-2008, 08:04 AM   #6
dc5282's Avatar
Have not worked on it yet been workin, probably try to work on it in the next couple of days, hope ur right deeze, you seem to know what ur talkin about,
Ill post back the results when i FIX it.
Thanks
DC
Old 06-01-2008, 09:00 PM   #7
OK! Finally done! Replace the solenoids and all is well. Took the crossmember right out. Paint is my excuse Works perfectly now! Big thanks to Deeze! You da man!
Old 06-02-2008, 02:13 PM   #8
Nathanl_01's Avatar
Nathanl_01 is on a distinguished road
ok I just started having the same problem. What solenoids are you talking about replacing.
Old 06-02-2008, 02:16 PM   #9
Nathanl_01's Avatar
ok nevermind. I must have skipped over where it said shift solenoid. How much would it cost to replace these and how big of a job is it?
Old 06-02-2008, 07:06 PM   #10
Deeze49686's Avatar
dealer, 40 bucks, get a filter and pan gasket too.
and REMOVE the crossmember to do it.
scale of 1-10 its a neg for difficulty.
Old 06-02-2008, 07:13 PM   #11
Nathanl_01's Avatar
well how many different solenoids are there. And are they $40 a peice. Why remove the crossmember?
Old 06-02-2008, 07:26 PM   #12
Deeze49686's Avatar
what year?
93-94 have 5 solenoids
2 shift, one 3-2 downshift, a force motor and a tcc solenoid that is part of the harness
95 has 6 solenoids
2 shift, a 3-2 ,a tcc pwm a force motor, and a tcc solenoid. on the 95 the 3-2 is also a pwm solenoid.
96 also have 6 solenoids, but the 3-2 solenoid went to an on /off style.
the 2 you need are the shift solenoids.
and the reason for taking the crossmember all the way off, is because you pry the pan past the trans mount bracket on the crossmember and it ends up breaking the shift solenoids off.
can we make this a sticky so i dont have to keep reposting? please?
Old 06-02-2008, 07:51 PM   #13
Nathanl_01's Avatar
its a 99
Old 06-02-2008, 08:32 PM   #14
My closest dealer told me there was 3 shift solenoids and 1 other solenoid. The total for these was $140. Lucky me, I have 1 extra! Now when I got in there there were only 2 shift solenoids, plus the other one, but the reward of your tranny working the way she's supposed to after you did the repair, rather than some hack who calls himself a tranny builder ( I got burned for $500, even though I told him what to do) is pricelesss!. When you've got advice from a seasoned pro like Deeze, it's like having dessert when your testing!
Old 06-02-2008, 08:34 PM   #15
Deeze49686's Avatar
99 same as 96. just a deep pan instead of a flat one.
Old 06-07-2008, 11:38 PM   #16
fudog's Avatar
fudog is on a distinguished road
I have a 2000 Sonoma,101,000mi on it and I am getting harsh shifts from 1st to 2nd and at times it wont go into overdrive. This usually happens after it is warmed up and driven a few miles. I changed the fluid and filter last year but it made no difference. Does this sound like shift solenoids or a control valve body?
Old 06-08-2008, 10:20 AM   #17
Deeze49686's Avatar
its not overdrive, its lockup, and you have an 187o slip code pending......
Old 06-16-2008, 01:41 AM   #18
fudog's Avatar
Showing code 1870 per auto zone code reader. Thanks for the reply Deezee.
Old 06-17-2008, 12:55 AM   #19
dc5282's Avatar
finally got a chance to change solenoids,,0nly drove about 10 miles, so far so good, thanks for the help Deezer.
Old 06-17-2008, 07:28 PM   #20
bling bling like WHOA
xtreme03blzr's Avatar
xtreme03blzr is on a distinguished road
rockauto.com has the solenoids cheaper then dealer. I think they were $15
Old 06-18-2008, 06:01 PM   #21
Deeze49686's Avatar
dont use cheap solenoids.........
Old 06-19-2008, 02:45 PM   #22
Mine were ACDELCO Part # 24230298 for 16.66 @ rockauto.com
Old 06-27-2008, 12:14 AM   #23
z28z281996 is on a distinguished road
I have had the same problem my transmission will go into 3 in drive and overdrive if I manually shift it into second it will go into second. I have no first or forth gear. I also will not shift from three into two after upshifting. I have replaced all the solenoids and am still having the same problems. It also has new pump seals and torque converter. All fuses are good. Transmission shop says they have no idea without tearing it down and costing a small fortune. It was working fine until I had someone replace the seals due to a leak. Any ideas on what it could be??????
Old 06-27-2008, 07:02 PM   #24
DEEZE or anyone when i said all the soleoids i ment both shift soleoids and the 3-2 downshift soleoid i also replaced a thin black part that lies right above the trans filter. it is now giving me a 67 & 81 code
code 81 QDM Solenoid "B" monitored voltage differs from commanded
Anti-Lock Brake System (ABS) message fault (Saturn)
Brake switch circuit problems
CODE 67 Cruise control - switch circuit problems
Air Conditioner (A/C) pressure sensor - circuit problems
Torque Converter Clutch (TCC) solenoid - circuit problems
Cruise control switches - circuit problems
Retrieving ECM Codes
I replaced the brake switch 15 mins ago still didnt help
thanks James
Old 06-27-2008, 07:30 PM   #25
Deeze49686's Avatar
if you put the trans in OD, does it start out in limp mode?
heres what ya do.....
pull pan back off, the solenoids in the back both have a common red wire, you MUST have 12 volts on these with the key on. im thinking you have a bad ignition switch.
if they have 12 volts, page me.
Old 06-27-2008, 07:36 PM   #26
when you say ignition switch like where the key goes, now is that going to be easier than taking the pan off, if so i would rather just put a new switch in
yes it is starting out in limp mode
thanks james
Old 06-27-2008, 07:51 PM   #27
Deeze49686's Avatar
not the key cylinder, the actual switch. and these run about 105 bucks thru the dealer, or a delco dealer. and you can mess it up really easy by trying to put the key in ignition contact in wrong. if you dont have the little inverted torx bit for the top screw its a PITA. best bet, take it somewhere, and have them do it. no broken switch.
the only thing im concerned about it the tcc code.
if you clear codes, and just turn the key on, does the check engine light come back on?
Old 06-27-2008, 07:56 PM   #28
the codes stay off until i start it
Old 06-27-2008, 08:13 PM   #29
Deeze49686's Avatar
and the tcc code sets right away?
what codes reset after you start it?
Old 06-30-2008, 10:51 AM   #30
Deeze I Replaced The Last Solenoid Last Night And Still No Luck It Is Still IN Limp Mode I Have No Clue Some One Please Help!!!!
Old 06-30-2008, 07:39 PM   #31
Deeze49686's Avatar
ign switch time.........
Old 07-01-2008, 12:35 AM   #32
deeze i am taking it to the dealership tomm and i will let you know what the say.
Old 07-01-2008, 12:43 AM   #33
slow as shit-10
94S10asm's Avatar
94S10asm is on a distinguished road
does anyone have a picture of where the shift solenoids are inside the trans when you have the pan off. im starting to develope a similar problem. but mine starts out in 2nd gear some of the times and then it doesnt like to shift into 3rd. my mechanic said it was more than likey the shift solenoids and replacing the pressure manifold switch wouldnt hurt while i was in there. i changed the fluid and filter about three months ago with no results. does it sound like solenoids?
Old 07-01-2008, 09:40 PM   #34
bs01xtreme's Avatar
bs01xtreme is on a distinguished road
im having diffrent but same problems..i did the center console shifter conversion added a secondary cooler and changer the fluid and filter now my truck is screwed up..it starts out slow and takes awhile to get going..the tranny doesnt slip but takes alot more gas to get her goin..then at say 50 it feels like it drops a gear then up shifts then drops then up..and reverse seems to go in and out or a weird bucking if you may..any thoughts on that??? im totally lost
