4 x 4 won't go into 4 wheel drive - S-10 Forum
post #1 of 5 Old 02-14-2006, 10:54 AM Thread Starter
User is: john rando is offline
Angry 4 x 4 won't go into 4 wheel drive
I have a 2000 chevy s10 pickup truck w/auto transmission that will not shift into 4WDH. It will only go into 4WDL. this happened one time before. the dealer said the computer had to be reset. can I do this myself?
post #2 of 5 Old 02-14-2006, 11:51 AM
dillon_b12's Avatar
User is: dillon_b12 is offline
Send a message via AIM to dillon_b12 Send a message via MSN to dillon_b12
Re: 4 x 4 won't go into 4 wheel drive
Unhook the battery for a few minutes(don't just unhook it and hook it right back up actually give it a few minutes). Then hook it back up. If it keeps doing it, I would say it is your encoder motor because that is exactly what mine would do.
1994 S-10 4x4 - Black, 4.3 TBI, Lowered 4/5, 98 S-10 Frontend, Zexel-Torsen Differential, Velm Sunroof, Flowmaster 40 Series, Sony CDX-MP70, Pioneer 4x6s, Pioneer REV Series 6.5s, Pioneer 4x10s, Adire Audio Brahma 12", Hifonics BX1000D, and Corvette C6 18x8.5s with 235/55/18 Michelins.
post #3 of 5 Old 02-14-2006, 11:58 AM
Upsetta666's Avatar
User is: Upsetta666 is offline
Mine did the exact opposite, went into 4hi but not 4lo. I wound up putting an encoder motor and a TCCM in it.
post #4 of 5 Old 09-03-2006, 04:29 PM
User is: LordTauk is offline
I dont use 4WD High or low gear often except when it snows and that's usually just 4 high, and I was cleaning up the truck today and decided to put the transfer case in 4high and low and drive it around the block after getting done... well, upon putting it in 4low... I couldnt get it back to 4high. 2WD High worked, 4 low worked, 4 high did not. After messing with the transmission gears neutral to park, and so forth along with trying to press the 4 high button.
I decided to unhook the battery and do a quick wax job on some areas.
About 15 mins later, negative terminal reconnected and Im back in business, 4 high works.
LordTauk is offline
post #5 of 5 Old 09-03-2006, 08:15 PM
dillon_b12's Avatar
You may have gotten lucky sometimes if you hit the buttons to quick or don't give them time to change the encoder motor gets confused lol. If it keeps doing it your encoder motor is probably shot to hell.
