2002 chevy s10 4x4 quad cab 4.3 v6 transmission fluid questions. - S-10 Forum
post #1 of 10 Old 09-04-2011, 01:03 PM Thread Starter
User is: 44mag is offline
Past experiences have made me leary from changing transmission fluids.
Did one a few years ago and transmission was fine until I changed the fluid with the factory recommended oil and then it started to slip.
My question is what is the best dex3 transmission fluid on the market?
Money is no object to me when it comes to the transmission.
I have limited time to change the oil so id prefer to pick the fluid up at a local supply house rather than order something online. Any suggestions?
44mag is offline
post #2 of 10 Old 09-04-2011, 04:40 PM
AWD V8's Avatar
User is: AWD V8 is offline
Re: 2002 chevy s10 4x4 quad cab 4.3 v6 transmission fluid questions.
Use Type-F fluid, it firms up the shifting and reduces slippage. I use it in all my GM transmissions. Your transmission will last longer.
AWD V8 is offline
post #3 of 10 Old 09-05-2011, 10:51 AM Thread Starter
Wow never heard that one before has anyone else done this and got long life from there transmission with no issues? Ty for the feedback.
44mag is offline
post #4 of 10 Old 09-05-2011, 10:53 AM Thread Starter
Also what about redline or amsoil any comments on it?
44mag is offline
post #5 of 10 Old 09-05-2011, 02:20 PM
Now own a 99 Blazer 4x4
SSsonoma43's Avatar
User is: SSsonoma43 is offline
Send a message via AIM to SSsonoma43 Send a message via Yahoo to SSsonoma43
Originally Posted by 44mag View Post
My question is what is the best dex3 transmission fluid on the market?Money is no object to me when it comes to the transmission. Any suggestions?
Use Dex3 or Dex4. You don't need to spend money on special fluids and things. It isn't going to do anything different then the $1.99 bottle of ATF. The main failure of the 4L60E is a mechanical failure (reaction sunshell or valvebody related). Fluids don't cause mechanical failures.
P.S.- I have heard of other people putting in "Type F" fluids in their GM transmissions, but I would never do it because it is not recommended by GM.
Used to own a 1999 GMC SONOMA 4X4 (X) IAT mod, MAF mod, TB mod, TB spacer, 160 degree thermostat, Gibson exaust, Backyard intake, Headlight removed, Hypertech PP3, Casper TPS controller, Corvette servo, MSD coil, E-fan, ASP power pulleys, and EGR mod, 16.451@81.27
post #6 of 10 Old 09-06-2011, 01:47 AM
AWD V8's Avatar
I have done this for over 9 years on my own, and friends vehicles, with no problems. I know several other well respected techs who will do the same thing.
( years ago when I bought my 89 Jimmy the transmission started to flare badly going into 2nd gear. I took it to a transmission shop and they told me the transmission was on it's way out. I changed out the fluid to Type-F and the flaring stopped. 8 years later it was still going when I switched over to my 95 Jimmy. I also had a friend with a Honda Accord that flared so bad going into 2nd gear he was afraid to leave home. I switched it to Type-F and it shifted fine. He drove it several months more before he sold it.
Many GM guys switch their own cars to Type-F to get firm shifts and reduce potential slippage as a performance and preventative measure. Dexron is slipperier than Type-F and clutches that are old and overpowered can begin to slip and cause the clutches to let go. Reducing slippage prolongs the clutches.
Many tranny shops used Type-F in performance cars many years ago before synthetics were popular. B&M recommends using their Slick Shift or Type-F in the instructions for their shift kits.
Check out the GM forums and see for yourself.
Of course if the transmission is on it's way out you can just get it overhauled instead, or prolong it's life with Type-F, it's up to you.
AWD V8 is offline
post #7 of 10 Old 02-01-2014, 03:12 PM
User is: firemedic947 is offline
Is is OK to do that with just a pan/filter change and not draining the whole system? In other words, is it OK to have, say, 5 qts of F and the other 7-8 Dexron?
post #8 of 10 Old 02-01-2014, 05:41 PM
Forever breaking this S10
NextName's Avatar
User is: NextName is offline
Yes, they are fine to mix. It's advised to have the whole system flushed just to have all fresh fluid since the old fluid is going to prematurely gunk up the new filter, but it's technically alright to do it.
[Mac]
2000 Chevy S10 2.2 auto
1996 Chevy S10 5spd 4x4 4.3L
96 4x4 5-speed whole truck part-out
NextName is offline
post #9 of 10 Old 02-01-2014, 08:31 PM
goin broke but n style
S15vortecpwr's Avatar
DEX6 is also compatible with DEX3. it even says it on the last bottle I looked at.
I think I am gonna try the type F when I get my 94 back on the rd. it has 180k on it so if it fails shortly after, I have gotten its full life out of it.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #10 of 10 Old 02-01-2014, 11:27 PM
"factory freak"...
Crew Cab Sonoma's Avatar
If you install a drain plug kit in your existing pan, or install a pan
that has a drain plug, you can just drain and refill the pan regularly
to increase the amount of Type F in the transmission.
I usually drain and refill the tranny pan every other engine oil change.
95 S-10 2.2. Soon to be DD
