LinkBack (2) | Thread Tools |
#1
former owner
Well, I've made you wait long enough ... 98SS Bagged
It's been done for about 2 weeks but I wanted to surprise the Bama crew by rolling up at stock height, airing out, and dragging to a stop at the meet this past weekend. Some of the faces were worth all the work.
->Click Here<- for the album of build pics. Thorbecke Brothers (suicidedoors.com) Superpivot 3 link with Custom bolt on axle brackets and sorta KP/Cando style lift bars made Thorbecke style with 2" x 2" x .025 wall tubing under Airlift 2B7s. Slam RS72s in front on unmodified stock arms and unmodified Suicidedoors cups. Powdercoated Belltech 2" spindles help it lay Y-pipe on the ground and tires on the wheel wells. The front has been done since Easter. Back was done over Memorial day weekend ... 4 hours on Saturday, 8 hours on Sunday, and about 11 hours on Monday. (click for bigger picture) ![]() ![]() ![]() ![]() Air management is currently 5 gallons of air utilizing a Viair 450C and 380C on two different pressure differentials. I have the power to the relays wired to on/off switches so I can cut each compressor on or off as I please to keep them cool. (wiring diagram below). 1/2" Parker valves, 1/2" Parker Parflex airline, Parker PTC fittings and adapters (all of which are friggin awesome! ... first time bagger and not one leak from the Parker stuff.). The AVS ARC rocker 7 switch makes it much easier to adjust the truck height than the cinder block 10 switch boxes. ![]() ![]() Yes, I know it needs some body work. But now, with the overheating and really rough idle, body work is the least of my problems. I showed Jason the axle brackets a while back and he said they were too busy working on the control arms, but that they were hoping to offer the exact same thing soon. Once they come out, the 5 link will be offered completely bolt on except for the notch and upper shock bar and mounts. |
Drop N Destroy
Re: Well, I've made you wait long enough ... 98SS Bagged
very nice Tim
355 member
damn huge sig bro
Nice work, it looks great. Now pop open the hood and start tearing shit out.
!! TALK NOW !!
its about time! looks good.. check the EGR vavle for rough idle.. clean it out.. or might be bad.. common thing if truck idles rough
wants a 2 door 98+ blazer
looks nice man
Disturbed Image Trucks
Location: Boston, MA / Southington, CT User is: OffLine |
That doesn't get very much lift... I like the look of an ss with the newer zq8's. Whats up with the tag? That shit is like facing the ground.
It's a Blue thing...
![]() Fix it! |
CHANGE YOUR EMAIL ADDRESS
Sweet
stole his dad's s10 :)
looks good man.
thats RIGHT
very clean
former owner
Yeah, but it's within the new forum specs. I checked and double checked. The rough idle started on my way back from Birmingham and the truck overheated twice. It started a nasty clicking noise so I pulled over to let it cool. Started it back up and the clicking went away but the idle was really rough. As for the license plate, yeah, my bracket is all screwed up. I've got more important issues right now, though. Thanks for the compliments. Surprising everyone this past weekend was well worth all the work that went into it. |
no more S10
Looks great. I know this has been in the works for a while. Glad you're finally there. One question though, where are your shocks mounted?
Its about damn time you post up the pics publicly. Sorry I never replied to the PM (or did I?). Anyway, it looks great, you did a fantastic job....
former owner
'Stevie Joe'
thats a damn nice lookin truck bro
<:The Shadow Conspiracy:>
looks pretty nice man..
Flat Out Fabricator
looking good Tim. How's my comp holding up? hope you enjoy being bagged now
tim is was definately great seeing the truck bagged, i remember the last meet u were at you were like i don't want to do all that work to my SS becase its a SS and now almost 1 year later ur fully bagged. it definately was a shocker to me but looks awesome and it was great seeing u again.
Wow nice man!
Lay'd
Nice work man it looks really good.
"six3onei"
nice man!
#24 |
looks good tim. i would go up to maybe re8s to get more lift in the rear to even it out.
#25 |
growing up a bit..
looks real nice man... i love it.. wanna trade?
#26 |
former owner
The comp is doing good so far.
Thanks a ton guys. Yeah, Jon, seeing ya'lls faces was well worth all the work. And I know I said all that, but after it being through as much as it has, I figured, what the hell. Yeah, Kris I probably will go with something bigger, but I'll have to make a new cage to give the larger bags some space. The roll plates for the 2B7s have little to no clearance between them and the tank cage, but they don't hit or come close to hitting unless I'm at full lift. Also, the 2B7s lift it high enough to ram the driveshaft into the tranny to where I can't drive at full lift, so they're plenty for now, until I get the shaft shortened a little. Thanks for all the compliments. Lilsly, yours has been on my desktop wallpaper a handful of times. Thanks for the props and mad props to ya. Last edited by 98SS : 06-12-2006 at 11:11 PM. |
#27 |
former owner
I see that they have internal bump stops. Do the 2B7s? I've been laying the truck out and squishing these 2B7s and wasn't sure if it would hurt. I'll be making some type of solid stop anyway, but can't seem to find out if these 2B7s have internal ones. |
#28 |
NTBSSHEVN
Mad clean setup. Looks awsome.
#29 |
Neglected & Broke
Very sweet.. I know your happy.. youve got a lot of time and design in everything..
way to go man, cant wait to see it in person |
#30 |
former owner
Yeah. Definitely happy. ![]() Let me know what you're getting into this weekend. Sorry, I forgot to give ya the number. Now you have it, though. We're gonna try to yank the bed off again this weekend to gusset the frame above the bags. I didn't think to do it because at that point we were just ready to finish bolting it all on and get it on the ground. Now the passenger side frame rail is starting to bend up just a little. Not good, but we'll fix it, easy. Anyone know anything about my last post about the 2B7s having bump stops? |
#31 |
i love Hurricane
truck looks badass man....itd look sick bodydropped just the way it sits.
#32 |
now XTREME
HELL YEA!!! represent with the SS love the bags an gives us SS guy somthing to look up to way to go man
#33 |
former owner
Thanks again guys. I remember back when I first got on here and Tony's SS was the shit. That truck was one to "look up to".
#34 |
now XTREME
haha |
#35 |
Yea Tim it looks good! i will be posting mine on here soon. Thanks for the help on the directions to Memphis i would have never made it without you I would still be driving around Memphis. So thanks man! It looks good! Talk to you later
Heath |
#36 |
Cogito Ergo Sum
any chance you would share with me how you made the bolt on axle brakets? You could PM if you dont want alot of people to know.
#37 |
former owner
Glad you found your way Heath.
As for the bracket design, I have no problem sharing. I showed them to Jason back in early January (saved the PM) and offered to assist SD in developing them, but he said they were too busy working on the control arms to work on these brackets. (Are the control arms even available yet? I recall they said they would be in Jan.) ![]() But anyway, once they do get the axle brackets going, they can make them way easier than the average Joe. A good jig will help drastically when doing any project. Here's some of the CAD drawings. I'll post exact dimensions later. (click for bigger) ![]() |
#38 |
former owner
These parts are some of what makes up the bolt on axle brackets and frame mount brackets.
![]() Refer back to the CAD drawing above. That is drawn as if you were going to trim the rear portion of the frame rails, box and gusset them, and then sandwich them with the rear frame mount brackets. You want to create an upper case "H" shape with each pair of the frame mount brackets as shown in the pics. Or you can trim off the inner side to create a lower case "h" shape and you won't have to trim the frame rails. The rear most edge of the frame mount brackets are 2.0" from the rear edge of the framerails. Lift bars are 29" center to center and the shackles are 5" center to center. The 5" shackles lay 25.5" - 26.0" diameter tires. Add 1/2" to the shackles for every extra inch of tire diameter that you plan on running. |
#39 |
i love Hurricane
you think it would be possible to untuck 26.5" tall tires with a 3.5" bodydrop with your setup? i got 2 pieces of 2x2x.25 laying here and your pics got me thinkin about trying it.
#40 |
former owner
I'll have to measure. I know my tires are right at 26" and I untuck the rears about an inch or two. But I'm also running 2B7s, so I'm not getting the lift I could. It's enough for now, though and I'll buy some more bags later. Right now I'm concerned about body and engine work.
But I'll layout the dimensions for you when I can get time. I'm in Mexico right now so measuring my own truck isn't possible. |
#41 |
Sinatra Lives!
Is that smudge on your rollpan from the sticker that came on it? Mine still has some glue residue there too, I cant get it off.
#42 |
former owner
No my license plate bracket used to be on that side and it had enough flex to it going down the road to where it would rub the roll pan. That's part of the reason it's bent so far back like someone mentioned before ... so that it won't wiggle and hit the pan. I have some ideas for making it stiffer. Just haven't worked on it yet.
Try gasoline, then clean the gas quickly with soap and water. Either that or Fast Orange (or equivalent) hand cleaner. That shit takes everything off. Last edited by 98SS : 06-26-2006 at 09:17 PM. |
#43 |
i love Hurricane
alright...awesome, thanks for the info man....lemme know what you firgure out...i got 26.5" tall tires id like to untuck in the rear with 2b7's if anything id jsut order diff bags or something...
#44 |
former owner
Small addition...
Add that stuff with this ... ![]() And you got yourself a bolt on axle bracket. Just check the lateral spacing of the tabs that mount the forward link bars before welding them. |
#45 |
98ss are you able to do this with the SD bolt on brackets and do you have any pics of your bracket?
#46 |
former owner
Look at that rear portion of the 3/8" plate under the 3.0 dimension. I'm not sure how far the SD bracket goes back but I'm sure it's not as much as mine. This extra plate gives more surface to weld the pivot ball housing tabs to the underside. If you don't have very much weld, they could be weak and crack prematurely. I mounted the center of the pivot ball housing almost right under the back edge of the plate to get all the weld I could. Then, the back edge of the plate was welded to the top of the pivot ball housing as indicated above for more strength.
#47 |
Si vis pacem, para bellum
here's a link to my carb I did when I was rebuilding my 350 to stab in my dime. http://www.turbosquid.com/FullPrevie....cfm/ID/326946 |
#48 |
former owner
Yeah, I did those. They're pretty outdated and poor compared to my recent work. Especially now that I'm using Catia V5.
That carb looks pretty nice. What program is that? Also, this is a pretty old thread, but for the very first post, that should say 2" x 2" x .25" wall square tubing. Not .025" wall. And check my New Project Thread in my sig for latest updates and changes to what is posted in this thread. |
#49 |
#50 |
Under Construcktion!
dam man thats a dream come true. i got exactly what u got but stock. hopefully 1 day ill be in ur shoes, if u get what i mean. =)
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f125/well-ive-made-you-wait-long-enough-98ss-bagged-254357/
| AirRideTalk.com Forums - Project - Miscellaneous Bagged Ride Changes | This thread | Refback | 01-08-2008 03:26 PM | |
| Business Administration Degree Online - business degree from, degree online social | This thread | Refback | 06-26-2007 11:33 PM | |
