want to delete ABS, what proportioning valve to use?? - Page 4 - S-10 Forum
Old 02-07-2014, 10:44 AM   #151
FREAKS
2Xtreme's Avatar
Re: want to delete ABS, what proportioning valve to use??
Ill look into that also. thanks
Old 02-12-2014, 06:44 PM   #152
jdrinkard's Avatar
I have swapped to disc in the rear and plan to use the abs. do i still need to change the prop valve thats in between the unit and m/c or will it adapt itself?
Old 03-07-2015, 12:24 PM   #153
jdrinkard did you have to deal with any metering valves of sorts on that conversion? I had a question regarding pressure differntial switches and where they are located. Mine is an 01 sonoma and I'm about to do the delete. Just wanted to know if the abs valve is also performing the pressure diff functioning seeing as that is where the front brakes T off. And if this is the case should a guy incorporate them instead of a front T just for safetys sake. I'm probably over thinking it maybe these trucks don't even have a pressure differential switch.
Old 03-08-2015, 02:49 PM   #154
jmcclendon87's Avatar
Can I use the stock one from my 2000? I don't mind having to T off the front line. Just wanna make sure before I go n weld a bracket to the frame and run into a problem. Rather do it right the 1st time.
Old 03-26-2015, 09:08 AM   #155
Where in bloddy hell is this "stock" prop valve on the 2000 and 2001s? I have my abs gutted as of last week right to the hard lines. My noma is 4wd with 4 disc brakes stock. I fail to see the apparent proportioning valve that everyone with these years seem to have. I only have an abs valve I swear. Is the rear bias created inside my abs valve? I have 3 outputs 2 are for the fronts and 1 goes to the rear and it goes straight to the rear no valve in between that I can see. My truck has to have bias being all disc and I never locked the rears all winter. My only concern I hope someone can answer is am i missing it? is it inline somewhere? I don't want to run double prop valves to the back that would just be counterproductive.
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
