Viair Is Awesome!!!
Old 10-20-2009, 03:15 PM   #301
VIAIR Corp
lance_martz's Avatar
Re: Viair Is Awesome!!!
Quote: Originally Posted by hotrodhombre
ok doesn't look like ill have a ride tell around 5 if it doesnt work out then ill just come get it tomorrow. I just dont trust taking truck on highway or i would come right now.
Drew
NO worries bro, its on my desk. Today, tomorrow - whatever is best for you. Definitely play it as safe as possible! (Don't you have a schrader valve on your tank? - That would make it easy to air up using a portable compressor in a time like this.)
Old 10-20-2009, 11:18 PM   #302
Utter End
hotrodhombre's Avatar
no.... that's and awesome idea ill have to go get one now lol... cant believe i haven't thought of that now lol.
Old 10-21-2009, 01:41 PM   #303
Utter End
hey Lance!
when would be a good time to come down today? i kinda ghetto riged the head to not leak so i can make down now.
Old 10-21-2009, 02:11 PM   #304
VIAIR Corp
hey Lance!
Anytime is good bro... Come on down!
I take lunch around noon time. If there's a lifted silver Tundra, a silver GSXR, or a big black V twin cruiser here - I'm here.
Old 10-21-2009, 02:27 PM   #305
Utter End
ok cool do i just walk in and ask for lance?
Old 10-21-2009, 03:34 PM   #306
VIAIR Corp
Nope, ask for Phillipe...
Of course you ask for me!
Old 10-21-2009, 04:15 PM   #307
Utter End
hahaha gotcha.... well more fun with my truck.... i go to leave but wanted to make sure head still wasnt leaking that bad after my jerry rig.... all is good... then i hear another hesssss.... its from my second tank which my valves are screwed into... so dont have time to mess with that tank again. so i run the fill line from tank one to tank to into the valves... but now the fill valve is cross threaded some how.... so had to switch that valve out... then put all back together (lots of zip ties lol) and now what... i come inside and see its 12 lol!!!!! gota wait another hour lol... i swear man im just not meant to have this truck working lol.
screw it ill just leave now and wait in the parking lot...hope there is no traffic lol... might bring tools and change head out in parking lot lol!
Old 10-21-2009, 05:22 PM   #308
VIAIR Corp
Thanks for stopping by!
Let me know how it goes, okay?
Old 10-21-2009, 07:10 PM   #309
Utter End
Thanx Lance!!!!
sorry i was a little dirty i just got done doing what i said to truck and took off. I would like every one to know that Viair is of the best companys out there! Ever one there was super nice while i was waiting. One guy was talking to me about my truck when i first pulled up then later came out and gave me a viar lanyard lol. then every one said hi when they passed. Just seem like a super nice place to be. Lance came in from lunch and went and got me my new head, bolts,bushings and some sick looking viair stickers! Shuck my hand and asked if i needed anything else let him know.
all in all viair and lance are the shit!
thanx again man im having lil bit of hard time getting the wax out of the bolt heads but after that should be all good!
Drew
Old 10-21-2009, 07:18 PM   #310
US Beer Drinking Team
hamagc's Avatar
lol see now aren't you glad we said talk to lance!
for the wax, if you have a toothpick or small screwdriver and a light/torch, they come out easy.
Old 10-21-2009, 07:44 PM   #311
VIAIR Corp
Drew
Totally welcome Drew!
That's not wax - its two part epoxy. Drill it out with a smaller drill bit and pick out the leftovers with a small slotted screwdriver - OR - You can torch it, sink an Allen wrench into it and just remove the bolt. I gave you new bolts so you don't have to mess with nasty old bolts again.
No worries about being dirty bro. -You are accomplishing things!
I have spent years in custom shops in my time, so to me - you looked clean! lol
I am sorry I didn't have time to hang out with you. I left for an hour, and when I came back - I had a ton of work piling up already!
Old 10-22-2009, 05:02 PM   #312
Utter End
ok awsome!!!!! got new head on and no leaks!!!! thanx again Lance your the man!!!!!
gotta question. what is the 2 lil pieces of metal on the the piston and the plat that the head sat on? im guessing the control the air flow or something?
Old 10-22-2009, 06:43 PM   #313
VIAIR Corp
I'm pretty sure you're talking about the intake & exhaust valves...
They allow air flow into the compressor and keep it there during the piston stroke that compresses air through the leader hose, past the check valve and into your air tank. If those don't seal, you will also have a leak - and may blow fuses. The check valve at the end of the leader hose keeps these alive longer.
If the valves are dirty, remove the fixing screw, then clean and put them back. Sometimes filth and buildup gets stuck in the orifice that they each seal. If they're cracked - they need to be replaced.
Old 10-23-2009, 08:38 PM   #314
Utter End
its so awesome that i go out in the morning and my truck is still holding air and not layed out lol! dont have to run the compressor nearly as much!!!! im stoked!
Old 11-02-2009, 12:15 PM   #315
hey, i think some one from the corp. sent me the wrong p switch. its for 200 psi and my comp. is only rated for 200? its working realy hard to get to 200 i think. i bought all my items over a year ago and just finishing installing them. could i get a new switch or is this one fine? im running 5 gallons and one 100% duty cycle compressor.
Old 11-02-2009, 02:57 PM   #316
VIAIR Corp
A 200 PSI switch is what you use for a compressor that is rated to 200 PSI. One compressor on 5 gallons is okay for nominal use. Just don't expect fast fill times if you are switch-happy.
The products you purchased have/had a one year manufacturer defect warranty. If there is no defect, that's the extent of the warranty. If you would like a different pressure switch, please seek out any of the fine vendors on this forum. I'm sure they have what you need.
Old 11-14-2009, 03:23 PM   #317
bagginthechevy's Avatar
Hey lance for some reason my computer wont let me go to viar website I was wondering if you could price me a new liter hose for my 380
Old 11-16-2009, 02:06 PM   #318
VIAIR Corp
When buying regular parts like a leader hose, you're likely to get a better price from a stocking dealer, like Lowrider Depot, Suicide Doors, etc. The part number you need for the leader hose is P/N 92793 - 21" S.S. Braided Leader Hose w/ Check Valve (1/4"M to 1/4"M, NPT, Swivel)
If you need anything else, (not new compressors, I can't sell them to the public) please PM me for a price.
Tks,
Lance
Page generated in 0.79642 seconds with 32 queries
[Output: 105.08 Kb. compressed to 97.67 Kb. by saving 7.41 Kb. (7.05%)]
