Extended cab or no cab.
The Strength of Different Styles of Frame Notches (Info)
I found this posted on GMFullsize.com which was linked to 67-72chevytrucks.com. It talks about the different styles of notches, both step and bolt in and how stong each is compared to original. Some of the data was pretty insightful and a little scary to me!
http://67-72chevytrucks.com/vboard/s...d.php?t=457037 |
S - I - C
Re: The Strength of Different Styles of Frame Notches (Info)
I wonder how strong a taller tube type notch would be. I wonder if height of the notch would affect it?
Disturbed Image Trucks
![]() Age: 27
Location: Boston, MA / Southington, CT User is: OffLine |
thanks for the info!
currently on jack stands
![]() Age: 26
Thanks Cory, I have always wondered how notching affected the strength of the frame. It's nice to see some numbers from an engineering standpoint.
Pizza Technician
Makes me feel a little better. lol
Wow that is a little Scary def have to go with the half circle if I ever start another truck!
Here is the original post from 67-72trucks.com. All credit goes to lakeroadster for the original post and information. I am simply copying here incase the link goes bad in the original post.
Maybe a mod can edit the original post in this thread to contain this info? |
More pictures.
I drive
if someone is notching a truck,they should already know this
Good info though
So JDM my blood type is R
![]() Age: 20
not everyone is an engineer. i would have never thought that a bolt in notch would make its that weak, nor a step notch be weaker as well. pipe i do understand entirely though. doesnt even look like it'd be very strong
![]() Age: 27
Interested to see how strong a bolt on step notch that ART or lowrider depot is.
is the stock frame overkilled then ?
Ridin' on Twankies
I can see how bolt in notches make the frame weaker than stock, but seriously how many people have had trouble with them ? I think bolt in c notches, and step notches are fine, ive had both with no issues.
Does anyone have any info on say bolt on backhalfs? I've had one of those also, just curious to see if its stronger or weaker than stock, since youre cutting off the stock backhalf, and relying on bolts to hold it to the existing frame. I know some people weld them, but still. |
![]() Age: 20
i would imagine it would be weaker, because you no longer have a continuous piece of steel. you would have two "rubbing" against each other. but i'm no structural engineer.
please repost that in english, just in case there was something of use in it.
![]() Age: 26
Go easy on him, man. English isnt his primary language.
But what he's saying is that the metal just under the head of the bolt is taking a lot of stress. I've actually seen a bolt get "pulled through" a piece of steel with the bolt still 100% in tact and a gaping hole left in the steel. |
ok... See, I didn't get that at all. Thanks for clearing it up.
| Sponsored Links | |
Advertisement | |
