Tested - D.O.T. Fittings versus Home Depot Fittings - S-10 Forum
post #1 of 58 Old 07-10-2006, 11:26 PM Thread Starter
former owner
98SS's Avatar
Location: north of Motor City ... formerly near Memphis
User is: 98SS is offline
Send a message via AIM to 98SS
To properly evaluate the quality of Home Depot fittings versus D.O.T. approved fittings, multiple samples should be tested. The following encompasses the testing of only one set of samples.
Samples in question included six (6) Watts® 1/2" Male thread to 1/2" tube compression fittings, examples of which are shown below. (click any small images for larger version)
Contrast samples included six (6) Parker® 1/2" Male thread to 1/2" tube PTC fittings, examples of which are shown below.
D.O.T. tubing was used for this test. Just feeling the tubing at Home Depot should send a chill down the back of anyone who is shopping for plumbing for an air ride air management system. Shown is a square cut example of DOT tubing used and a side by side of the example test assemblies.
The compression fittings were torqued to 20 ft-lbs.
Both samples were air leak checked to 700 psi with no leaks. The samples were then water burst tested at which both burst tests ended at 1500 psi when the tubing failed as shown.
Fittings 3 and 4 of each type were then retested in the air leak check machine. This time, the Home Depot compression fittings failed at 720 psi when the tubing blew out of the fitting.
The D.O.T. Parker fittings held out to 950 psi until the tubing bubbled. This time the tubing bubbled at a lower pressure because the fluid inside was air and was increasing much slower. During the burst test, the pressure increased so rapidly that the pressure made it to 1500 before tubing failure. Shown here is the air leak check Parker fittings.
Last, fittings 5 and 6 of each type were assembled and placed in the tensile machine. The results here were a disappointing 100lbs force for the Home Depot compression fitting to release the tubing. The Parker D.O.T. fitting withstood 300lbs tensile force and the test only ended due to tubing failure.
Here you can see the tubing just before failure during the Parker fitting test.
For shits-n-giggles, Home Depot plastic PTC fittings were air leak checked. They leaked at 450 psi.
Again, to best evaluate these fittings, multiple samples (30+) should be analyzed and the results averaged to give a more accurate comparison. However, perhaps this helps shed some light on Home Depot fitting performance versus D.O.T. fitting performance.
Having the two side by side and seeing how the cheaper fitting is damaged easier and fails at less pressures and forces, I personally would much rather spend a couple dollars more to have fittings that are approved to be on a motor vehicle and withstand the abuse that they will see over many years of operation.
- Tim -
1998 S10 LS - stock, lemon - gone
1998 S10 SS - bagged, shaved, etc. - gone
2005 Civic
2010 Equinox
98SS is offline
post #2 of 58 Old 07-10-2006, 11:31 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
Re: Tested - D.O.T. Fittings versus Home Depot Fittings
I love you man ha ha.
Man I want one of everyone one of those tools. ha ha..
Lucky man you have a cool place to work.
Nice info BTW
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #3 of 58 Old 07-10-2006, 11:34 PM
forum idiot
orangesonoma's Avatar
good deal...
Brian
orangesonoma is offline
post #4 of 58 Old 07-10-2006, 11:40 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
5/8" Tube home depot fittings are not even close lol that would have been an unfair test ha ha.
DJDAudio is offline
post #5 of 58 Old 07-10-2006, 11:53 PM
The Der
User is: dernoma is offline
Send a message via AIM to dernoma
haha i read through the whole thing thinking I was reading dj's work....
good comparison man
now when someone asks "is it ok to use home depot fittings" you can point them here
- Mike -
MIA
Florida Truck Scene
dernoma is offline
post #6 of 58 Old 07-10-2006, 11:53 PM
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
User is: BlackEsDime is offline
Send a message via AIM to BlackEsDime Send a message via MSN to BlackEsDime Send a message via Yahoo to BlackEsDime
yay! now maybe not so many people will use home depot fittings!!
-Ryan
I build aluminum fuel cells. Maybe...
www.honestabesfabshoppe.com
post #7 of 58 Old 07-11-2006, 12:00 AM
User is: DevilDriver is offline
added to sticky.
post #8 of 58 Old 07-11-2006, 12:06 AM
xdraggerx's Avatar
User is: xdraggerx is offline
I spend enough time in home depot bying stock for work and DOT isn't much more $$$ some might as well always use the good shit
93" bagged, running steelies and rattle can flat black.
post #9 of 58 Old 07-11-2006, 12:09 AM
so, who do you think is going to be first to say "i've had home depot fittings on my truck for x amount of miles and no problems, blah blah blah... i'm an idiot... blah blah blah" ?
-Ryan
post #10 of 58 Old 07-11-2006, 12:25 AM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Give it one day lol
DJDAudio is offline
post #11 of 58 Old 07-11-2006, 12:34 AM
bodydropped on 22s!
JMew03's Avatar
User is: JMew03 is offline
Send a message via AIM to JMew03 Send a message via Yahoo to JMew03
i have had home depot fittings on my truck for 2 years
and they suck ass
JMew03 is offline
post #12 of 58 Old 07-11-2006, 01:13 AM
Beer, Bait and Ammo
MoneyMike's Avatar
User is: MoneyMike is offline
Swagelok
We use just about every single product that they make at work.
Swagelok FTW
Project: Bulls on Parade
Get it on-line, All-Chix!
Click me im trendy!
Originally Posted by schlsux
When I think of MoneyMike I think of Denis Leary singing "Asshole"
Originally Posted by david4991 View Post
Mike, you are completely right.
post #13 of 58 Old 07-11-2006, 01:21 AM
draggin plastic
aquaxtreme's Avatar
User is: aquaxtreme is offline
nice work 98ss.
post #14 of 58 Old 07-11-2006, 02:53 AM
Bagged
chevy power's Avatar
User is: chevy power is offline
Send a message via AIM to chevy power
good info
post #15 of 58 Old 07-11-2006, 06:16 AM
rmrider's Avatar
User is: rmrider is offline
is it just me or for our applications of 140-200 (sometimes higher) psi it seems that home depot fittings will work perfectly fine? both the parker and home depot fittings withstood the burst test up to 1500 psi in which case the line failed, A+ for both fittings. 720 psi for a line to blow out of the tank does not seem unreasonable to me, especially when we're using less than a 1/4 of the pressure it popped out at.
I am not trying to start a war, but my understanding is that those results are good enough to say that home depot fittings can be used on air ride suspensions up to, and exceeding, 200 psi. Please fill me in on your reasonings before the flaming starts....
rmrider is offline
post #16 of 58 Old 07-11-2006, 06:18 AM
rmrider's Avatar
for the record, I am not using home depot fittings - SMC plastic PTCs and SMC brass with an ~ 2psi leak at 145 psi in 12 hours. I am happy with my fittings and would definitely spend the little bit extra money for my stubborn mindsake
rmrider is offline
post #17 of 58 Old 07-11-2006, 07:48 AM
User is: LayinFrameGMC is offline
700 psi is still fine for me.
post #18 of 58 Old 07-11-2006, 10:00 AM
Audi Tech
RacerXS10's Avatar
User is: RacerXS10 is offline
What about d.o.t. compression fittings? Are you able to try those? I'd be interested to see d.o.t. compression vs. d.o.t. ptc.
Nice test though, props for taking the time to do all of that!
JEFF
96 4.3l 5spd Sonoma.
post #19 of 58 Old 07-11-2006, 01:10 PM
no more S10
NCarolina910's Avatar
User is: NCarolina910 is offline
Send a message via AIM to NCarolina910
Very nice work Tim!!
Bryan
1964 Impala 333cid 4-speed | 1992 S10 4x4 4.3L | 2002 Impala 3.4L
post #20 of 58 Old 07-11-2006, 01:23 PM
User is: 98s10inny is offline
Yeah I was wondering the sane thing. How much of a performance difference is there with a DOT compression fitting and a Homedepot compression fitting. I personally love ALKON ptc's . Make my ife so easy lol.. Amazing job with the test. Sounds like you work in a lab like I do.
post #21 of 58 Old 07-11-2006, 02:50 PM
SHENANIGANS!!!
projo198's Avatar
User is: projo198 is offline
Send a message via AIM to projo198
Well heres the deal:
Sunday afternoon. Just finishing up your weekend project.
BAMN! I need a fuggin' 1/2 compression union!
Gotta drive this truck to work tommorrow. Can't order online. Lets see whats open...
Well, Home Depot is still open.
Thats usually how it goes for me.
GREAT test thread though. I was wondering when someone would do something like this.
projo198 is offline
post #22 of 58 Old 07-11-2006, 03:05 PM
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
User is: Dragginbody is offline
Send a message via AIM to Dragginbody Send a message via Yahoo to Dragginbody
great work tim.
so basically even though this test cant compare reliablity over time or a real world daily setup,
it shows that they can hold up to 700 psi...
kris@krisdyefabrication.com
440 258 6600 - kris
post #23 of 58 Old 07-11-2006, 04:53 PM Thread Starter
former owner
98SS's Avatar
Originally Posted by Dragginbody
so basically even though this test cant compare reliablity over time or a real world daily setup, .
Not the first one, no .... but, I did the test again to the point of failure.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #24 of 58 Old 07-11-2006, 10:24 PM
(Chaos)
Xaos.'s Avatar
User is: Xaos. is offline
nice thread man . i have a shit ton of fittings all dot. from freightliner for sale if any one needs them. im running hydrolic line so i no longer need them. spelling lol
I AINT SIGNING SHIT>
in the shop: 98 dime under construction. 4''stock floor body drop, top secret motor swap, clue its supercharged.
in the drive:
00 328ci dropped otherwise bone stock, maybe!
Xaos. is offline
post #25 of 58 Old 07-11-2006, 10:36 PM
x00
Got 20's?
x00's Avatar
User is: x00 is offline
your comparing apples to oranges thought...
should have tested home depot compression vs parker compression fittings....
altho you get props for doing this
x00 is offline
post #26 of 58 Old 07-11-2006, 10:58 PM Thread Starter
former owner
98SS's Avatar
I know. I don't have any D.O.T. compressions, and really don't care for compressions period. PTCs are just too user friendly and work great. I used PTCs on my truck so I had some left over. I can get some compressions and have the data amended to the post later.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #27 of 58 Old 07-11-2006, 11:06 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Anything you need changed just let me know man.
DJDAudio is offline
post #28 of 58 Old 07-12-2006, 10:05 PM
x00
Got 20's?
x00's Avatar
ya man i hear you. PTC's are the shit! i got them on my truck too, SMC tho.
was just pointing out that you can't really compare compression vs PTC..i am almost positive that parker compressions would yeld about the same result as home depot fittings.
x00 is offline
post #29 of 58 Old 07-24-2006, 01:58 AM
User is: BlueFalcon915 is offline
What about AN fittings and SS PTFE line?
Are those just for fluids... or would they work for air?
post #30 of 58 Old 07-24-2006, 02:51 PM
BAAWDDYYY DRAAAWP!
dnut24's Avatar
User is: dnut24 is offline
Send a message via AIM to dnut24
as mentioned this proves that home depot fittings are good to use if you run a normal 150psi system. if you go higher psi go with dot, so people can still and will say they've had no problems with home depot fittings.
great tests though, but as mentioned and to me is the bigger battle would be compresion vs PTC all DOT style. i use DOT compression and dont trust PTC (never used them) just dont seem safe to me. i'd be very interested in seeing those tests.
Big wheels are over rated.... thats why I have some!
I'll join the crowd- view my SFBD thread
http://www.s10forum.com/forum/showthread.php?t=236584
dnut24 is offline
post #31 of 58 Old 07-24-2006, 02:59 PM
Roll Tide
Bama's Avatar
User is: Bama is offline
very good info
Bama is offline
post #32 of 58 Old 07-24-2006, 03:09 PM
Mcfly Minis inc
Mcfly Minis's Avatar
User is: Mcfly Minis is offline
Send a message via AIM to Mcfly Minis Send a message via Yahoo to Mcfly Minis
I'm going to need to see the calibration certificates for all that equipment.....
J/K
...sorry it's my calibration humor, I'm a Metrologist.
post #33 of 58 Old 07-24-2006, 03:51 PM Thread Starter
former owner
98SS's Avatar
J/K
And I'm an engineer, so you're in good humor. If it's just necessary, they were calibrated June 5, 06.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #34 of 58 Old 07-26-2006, 12:29 PM
un banned
Baggd's Avatar
User is: Baggd is offline
Send a message via AIM to Baggd
if you have a bagged truck, you SHOULD have some extra fittings airline and bags. i even keep a spare compressor laying around.
Baggd is offline
post #35 of 58 Old 07-30-2006, 07:50 PM
Ricky
WhyNotFab's Avatar
User is: WhyNotFab is offline
Send a message via AIM to WhyNotFab
what about comparing both compression, instead of Comp/PTC? DOT vs. Home Depot.
I use and sell mainly compressions (DOT of course) but I'd like to be able to show some comparison between DOT/Home Depot compressions.
this obviously shows whats better thanks alot.
- WhyNotFab.com - "Keepin' the D.O.T. Busy.."
post #36 of 58 Old 07-30-2006, 10:02 PM
slowandlowxtreme's Avatar
User is: slowandlowxtreme is offline
i'm with this guy..im not out trying to say home depot fittings are ok to use, but they are being tested at almost 4x what most normal setups would see right? If these fittings were blowing out at 150-200 range, thats a clear sign not to use them. I may be talking out of my ass here but when someone asks the question" is it ok to run 200psi in a tank rated at 150psi" most people respond that is like 4x under what it can truley hold (800psi). So lets say pressures were to be that high with air ride, wouldn't we be seeing tank failures, tanks that we all run on our systems, along with home depot fittings?
Kyle
post #37 of 58 Old 07-30-2006, 10:49 PM
Hoods are overrated
sadexcuse4s10's Avatar
User is: sadexcuse4s10 is offline
Send a message via AIM to sadexcuse4s10
my HD fittings have been fine to 240 psi many times
but I'm slowly phasing them out for parker PTC's because I change my setup so much that I'm tired of having to buy new compression ends
Project '86 *Shame to Fame* FOR SALE, wife expecting baby. No engine or trans.
'93 Honda XR650L rebuild
post #38 of 58 Old 07-30-2006, 11:38 PM Thread Starter
former owner
98SS's Avatar
I will be ammending D.O.T. compression data to the first post soon.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #39 of 58 Old 05-02-2007, 02:54 AM
s_dimenickel
PACREEP's Avatar
User is: PACREEP is offline
Send a message via AIM to PACREEP
wow there is way too much abriviations.. in this post...
im pretty sure its in there but what about fittings from an autopart store.. napa for example.
Pennsylvania, Rollin' 24 Inches Deep.. In To Potholes.
PACREEP is offline
post #40 of 58 Old 05-02-2007, 09:28 AM Thread Starter
former owner
98SS's Avatar
It's funny that you bumped this thread up. The Parker compressions actually just came in yesterday. Finally.
I will be revising this test information within the next week, but since you mention it, I'll swing by a Napa while I'm out this afternoon and see what they have.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #41 of 58 Old 05-02-2007, 10:02 AM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
yaaaay!!!
post #42 of 58 Old 05-02-2007, 08:56 PM
I dont do bolt ons
snakenet's Avatar
User is: snakenet is offline
im getting ready to do the same thing. My HD fittings dont leak(my setup runs at 200psi), but god i change my setup all the time cause the bed is constantly coming off and iv been moving shit,, iv prolly been through like 500 crush collars already lol
~ 2004 Silverado - Kp6link with watts, ART LCA/UCA, HE and SS bags,3AZOB1s, Stealth valves, black with blue flames with lots of powdercoated flat black, and Panther juice 6 22s
- Gary 'Numatik' Eberle
InDePeNdEnT
snakenet is offline
post #43 of 58 Old 05-02-2007, 09:26 PM
VVVthat thing is deadVVV
NeverEnough188's Avatar
User is: NeverEnough188 is offline
yeah thats the only thing that sucks about compressions. if you ever blow a line somehow then you have to have a new insert and collar for each fitting before you can replace the section of line. ptc's you just unplug and push the new line in!
-Travis-
03 zq8 xcab 5/5 drop and some other goodies
post #44 of 58 Old 05-03-2007, 02:20 PM
YOU ARE GAY
layedouton20s's Avatar
User is: layedouton20s is offline
i was talking to a guy that works a evco in utah and he said that the plastic smc fitting arent made for 200 psi thats why i have leaks all the time. so i just bought dot.
[/IMG][/IMG]
post #45 of 58 Old 05-03-2007, 02:26 PM
rmrider's Avatar
ive had my plastic smc up to 280psi ..no probs at all, i have them on the bag and off the fill valve tee
rmrider is offline
post #46 of 58 Old 05-03-2007, 04:54 PM
Sprint Car Addict.
FCKNLOW's Avatar
User is: FCKNLOW is offline
Send a message via AIM to FCKNLOW
-Zach-99 s10-99 Silverado-04 z400
Originally Posted by 99 BUCKET View Post
Bitch told me she wanted 12" and to make it hurt!
so I stuck the 6"s in twice and punched her in the face.......
FCKNLOW is offline
post #47 of 58 Old 08-07-2007, 07:44 PM
In Da Workz
lowblaze2003's Avatar
User is: lowblaze2003 is offline
Send a message via Yahoo to lowblaze2003
All you guys arguing this sayin HD fittings are okay to use are complete morons.Yeah they work okay an some of you have had them on your ride for a few years BUT they were not made nor ment to be used on a suspension system...That be the case trucks repair shops would be going out an using HD or Lowes fittings on semis an whatnot..Use your freakin head....
95S-10, 4.3,front & back bagged, smooth skin and caddies lookin real perty..
post #48 of 58 Old 08-07-2007, 08:06 PM
Too broke to bag. :(
The-other-doug's Avatar
User is: The-other-doug is offline
I agree
BTW ZOMBIE POST ALERT
yes the HD fittings are good to 700 psi and you only run 200 right.....? WRONG! when you fill a bag the pressure inside is multiplied . and if your hopping as you hit the ground you could be doing 8-10 times as much pressure in those bags and anywhere upstream, that doesn't have a check valve. this is the same reason air hoppers blow bags and lines so easily.
so lets see 200 psi x the weights natural effort to stay down (untill upward momentum is achieved) = Easily over 700 psi. (actual pressures would depend on your trucks weight)
while yes its a very short period of time and most likely wouldn't blow it does let in the possibility (too much possibility for my liking) in that respect no Home Depot fittings are not capable of handling the load.
post #49 of 58 Old 12-09-2007, 08:16 PM
User is: jetlagged is offline
Oh noes! Thread diggin'!
Question...obviously don't get the compression/PTC fittings, but what about Home Depot 1/2" plugs for the tank?
post #50 of 58 Old 12-09-2007, 11:14 PM
Anybody got 20's?
Bdydrp02s10's Avatar
User is: Bdydrp02s10 is offline
Send a message via AIM to Bdydrp02s10
Originally Posted by The-other-doug View Post
I agree
Wrong the pressure is not multiplied. It still will be measured in pounds per square inch. There will be just more volume of that air. And for everyday driving the fittings will be fine. Even hitting a big bump in the road there will be a short raise of pressure but will never even get near 700psi.
Sold to my younger brother. 2002 ext. cab S-dime Getting rebagged with 20s. http://www.cardomain.com/ride/769386/1
2006 ext. cab GMC Sierra VortecMax. Stock. Fully Loaded. http://www.cardomain.com/ride/2932266
