its lime time!
sanden 508 and 709 ?
are these two compressors the same housing size? same mountign holes and such?
also is the Sanden 7176 the same mounting as either the 508 or 709? reason i ask is im going to buy a serpentine kit for my v8, i currrently have a york, i dont want to loose my edc so i will replace it with a much sleeker looking sanden and use that as my edc... the brackets im gonn use say they fit a Sanden 7176 so im wondering really if a 508 or a 709 will bolt in place.. (i cant find any polished 709's 508's i can however)... so i would really like to know if a 508 or 709 are the same as a 7176 mounting wise..... |
ROLL N LOW
Re: sanden 508 and 709 ?
They are different 5 series bolts from front to back 7 series bolts top to bottom.
its lime time!
so the mounting point are way different? |
it depends on the model some have the same body and some are a little longer or shorter but the front and rear ears are all the same 5 or 7 cyl you have to check exactly what you have
http://www.sanden.com/lib/drawings/4627/body.html http://www.sanden.com/lib/drawings/4509/body.html |
Dark Side Master
Im in the same position with my V8 and serpentine kit, need to find a polished sanden to use as an EDC
Inferno Fab
Did anyone ever figure out what Sanden comp to use where a sanden 7176 would mount? I will be needing this info in the near future to mount an EDC on my v8 with serp kit.
No idea, I use the polished 508s
its lime time!
no idea.. its been so long i forgot.. i went with a polished 508 however...
| Sponsored Links | |
Advertisement | |
