relay?
Old 06-28-2005, 02:28 AM   #1
Beau is low
2lw4fthos's Avatar
relay?
ok this might need to be in the electrical forum but here she goes
why do i need a relay on my compressor
can someone please explain to me why i would need one
i mean cant i just use a fuse?
or am i missing the whole point of what a realy does
please help me out and explain this to me in a way i can understand
Old 06-28-2005, 06:45 AM   #2
SIC FL Chapter prez
vio0633's Avatar
Re: relay?
A relay acts like a switch. When 12vdc is applied from your PS when the psi is low to the relay it will click over and turn the compressors on.
Old 06-28-2005, 09:57 AM   #3
I got nothing...
Re: relay?
Just wanted to add that you could burn up you PS if you run the power for the compressor thru the switch. I'm not using an inline fuse, I'm using a 30a relay as the 'fuse.'
-Kevin
Old 06-28-2005, 11:15 AM   #4
former owner
98SS's Avatar
Re: relay?
Maybe this will help.
->Click Here<-
(In case the page will not load, the information is copied below.)
A relay is a simple electromechanical switch made up of an electromagnet and a set of contacts. Relays are found hidden in all sorts of devices.
A relay consists of two separate and completely independent circuits. The first is at the bottom and drives the electromagnet. In this circuit, a switch is controlling power to the electromagnet.
When the switch is on, the electromagnet is on, and it attracts the armature. The armature is acting as a switch in the second circuit. When the electromagnet is energized, the armature completes the second circuit and the light is on.
When the electromagnet is not energized, the spring pulls the armature away and the circuit is not complete. In that case, the light is dark.
When you purchase relays, you generally have control over several variables:
  • The voltage and current that is needed to activate the armature
  • The maximum voltage and current that can run through the armature and the armature contacts
  • The number of armatures (generally one or two)
  • The number of contacts for the armature (generally one or two -- the relay shown here has two, one of which is unused)
  • Whether the contact (if only one contact is provided) is normally open (NO) or normally closed (NC)
In general, the point of a relay is to use a small amount of power in the electromagnet -- coming, say, from a small dashboard switch or a low-power electronic circuit -- to move an armature that is able to switch a much larger amount of power. For example, you might want the electromagnet to energize using 5 volts and 50 milliamps (250 milliwatts), while the armature can support 120V AC at 2 amps (240 watts). Relays are quite common in home appliances where there is an electronic control turning on something like a motor or a light. They are also common in cars, where the 12V supply voltage means that just about everything needs a large amount of current. In later model cars, manufacturers have started combining relay panels into the fuse box to make maintenance easier.
In places where a large amount of power needs to be switched, relays are often cascaded. In this case, a small relay switches the power needed to drive a much larger relay, and that second relay switches the power to drive the load.
Old 06-28-2005, 11:28 AM   #5
Dildoans
Phildo's Avatar
Re: relay?
that needs added to the basic baggin FAQ or something!!
very nice tim!
Old 06-28-2005, 01:02 PM   #6
Beau is low
2lw4fthos's Avatar
Re: relay?
ok but i am not running a PS im just running a manual switch you still think i need one?
Old 06-28-2005, 01:05 PM   #7
Dildoans
Phildo's Avatar
Re: relay?
yes. just put the manual switch in place of the pressure switch
Old 06-28-2005, 01:34 PM   #8
former owner
98SS's Avatar
Re: relay?
He just said he wasn't running a PS.
Do you mean put the pressure switch in place of the manual?
Old 06-28-2005, 01:37 PM   #9
Dildoans
Phildo's Avatar
Re: relay?
no, i was referring to a typical setup. instead of using the PS, run those wires to a manual switch.
