#51 |
Turbocharged Pimp
Re: [ProjecT] The Only Bagged AWD Syclone
Heres a pic dont mind the dirt its only been on there 10 years This photo was taken before I blew the thing apart last winter for detailing and to lay out
#52 |
Turbocharged Pimp
#53 |
To see the aim set-up go to this link.
http://www.airbagit-store.com/tech_instructions.asp then scroll down to chevrolet: porkchop: torsion lift 4x4 cycln/typhn You can see the basic Idea behind it. |
#54 |
Turbocharged Pimp
Man They say it fits the sy/ty's now where was this info 10 years ago when I bought it LOL
#55 |
bitch
~edit~ where can i buy one..... Last edited by LaynLo : 08-01-2006 at 12:40 AM. |
#56 |
I actually had a complete set-up for a tahoe in my possession about a year ago. It was sitting my my shop for years. I tried to sell it, but wasnt worth the time. Noone wanted it, and it was so f#@$in heavy that it would cost more to ship it than it was worth. Aim still makes it. The only problem I would see would be getting the travel youd want to lift and lay. The one that I worked on was totally hacked up to get it to fit. I could see some issues trying to get it to clear the exhaust, but i would have modified the exhasut before hacking up the Xmember like that customer did.
Jim, who did you buy it from? Or did you have it custom made. You've had it bagged for 10 years? Im very impressed with the truck. Other than the one that I saw, yours is the only one that I have seen installed. Im kinda impressed that the idea actually worked. On a light truck like an s10 it would work alot better than on a fullsize truck. How much travel do you get in the front from aired out to full lift? The real beauty of it, is that it doesnt require cutting or hacking like some pple think. It can be made to bolt in. You can easily put the front back to stock, and a rear clip would be easy to get the truck back to FULL stock condition. Id love to hear more about the rest of the truck. Rear set-up, engine mods etc. next car I do is going to be a twin turbo V8. Last edited by 98s10inny : 08-01-2006 at 01:32 PM. |
#57 |
if someone could get this to work well enough, it would solve the problem the rest of us have with mounting shocks.
#58 |
bitch
#59 |
Turbocharged Pimp
I bought it originally from Aim and modified it to fit my Sy yep I had problems with exhaust placement(Had to sell my Borla exhaust because it was unusable!) I bagged the truck a little over 10 years ago.The truck will now lay completely out without a problem and I can clear my 18s in the front by about 3inches or so(prbably more but I never measured.The rear is a first gen of the AirRide Technolgies Roadgrater with a 2wd S10 rearend with a locker and 3.42 gear to match the front.If you have any other questions abvout the truck I'll be happy to answer any of them, Thanks for all the kind words Jim |
#60 |
Hoods are overrated
if you wanna mount shocks and keep turning radius, just build a bracket to mount the shocks to the upper control arm and up towards the hood on the front side of the suspension.
mounting shocks = easy installing a whole new crossmember and converting a 2wd to a torsion key suspension with bars = lots of work |
#61 |
Frame Laying Member
#62 |
#63 |
Turbocharged Pimp
#64 |
Turbocharged Pimp
#65 |
who says there couldnt be a conversion? |
#66 |
Turbocharged Pimp
#67 |
i know
#68 |
Center your wheels!
Hey Jim any updates?
#69 |
Frame Laying Member
#70 |
awesome truck you got there. with that front setup, it works kinda like a lever or cantilever so it should get decent lift. |
#71 |
#72 |
Just another asshole
That truck is beautiful
#73 |
Turbocharged Pimp
#74 |
Turbocharged Pimp
#75 |
Turbocharged Pimp
Thanks for the kind words I think I must have talked to you a dozen times while you were at SD it seems like Jerid and I are on a first name basis now with as much money I've spent there LOL |
#76 |
Center your wheels!
#77 |
Registered Asshole
Man that truck is ugly as shit and fukin sucks.
#78 |
Registered Asshole
JUST KIDDING JIM!!!! How u been homie? Looks like ur finally cuttin it wooo!!! U ever get that sub box back from aaron that u gave me? Im pretty sure its at his house. And alls well here in AZ man. I wish i could come to ITB to see it, but nope, no $! DAMN!!! hahaha. Next u gotta cut up that old rod u got! Do i hear chop and channel with airride???
#79 |
#80 |
Center your wheels!
plus I've only gone out there twice, not 4-6 days a week for 4-6 weeks straight Last edited by layinbody31 : 08-07-2006 at 01:24 AM. |
#81 |
so be a bitch about it..
#82 |
Center your wheels!
#83 |
Registered Asshole
No Fighting Boys!!!
#84 |
Turbocharged Pimp
#85 |
Turbocharged Pimp
Later |
#86 |
Turbocharged Pimp
small update: I got the front leaf spring mounts off the frame removed my ebake cables(who needs those when your frame is just as good as an ebrake!!!!)I got the wheel spacers on and checked clearance,and cleanes up the frame to get it ready for por15,just gotta get the bed back on make sure we got the rear wheels centered and then blow it apart for paint and then final assembly ahhhh there is light at the end of the tunnel!!! I woulda taken pics but theres not any really to show
Later |
#87 |
Center your wheels!
good to hear some progress is being made. I emailed you about coming out on Thursday
#88 |
Turbocharged Pimp
Man tonights update is small too!!!!I mounted up my exhaust,cleaned up and primered my replacement gas tank and removed my old neons,unfortunately I cant go any farther until I can get the bed back on and get the rear wheels centered!Then I'll blow it apart and start the painting,then to start installing my air management(2AirZeniths,2 5gallon chrome tanks all new 3/8 smc valves)
God this going to be a lot to do before ITB,hope I can get it done |
#89 |
Center your wheels!
do you have any help besides me?
#90 |
- INNOVATE -
UPDATE JIM: I needed some fire wood and since your sub box was left at my house and taking up room ( wich i need the room to finish Luka's truck and my Blazer before Indy ) I torched that baby! The marshmellows tasted a little funny though, it must have been the carpet.
#91 |
- INNOVATE -
Just kidding Jim! How is it coming?
I'm busting my ass on Luka's truck to get it done by the week end and then I have a few things to do to the Blazer but if you are in desperate need, let me know. My blazer can go to Indy just the way it is, but I have to get Luka's truck finished first. We are wiring and plumbing this week and we don't really need to put his tubs in to go to Indy. So if need be, me and Luka can start coming over every night as soon as his truck is drivable. Soo let me know! Later Bro! |
#92 |
Turbocharged Pimp
#93 |
Turbocharged Pimp
#94 |
Registered Asshole
Damn man.. id help if i LIVED IN THE STATE $%&*()&* lol.
Wish i coulda been there for ITB.. sucks that everyyooneee i know is going and not me, especially since my truckin is badass now lol. Good luck with it all man. Im just waitin for the show season to kick in out here and ill be fine! |
#95 |
Registered Asshole
hahaha.... i know ur playin but it woulda been some funny shit.... maybe u can light up that field down the street? That would make a sweet smores fire! |
#96 |
Ranger Driver
I love the truck, but that graphics scheme is not for me
#97 |
Turbocharged Pimp
Well I'm officially stuck until tomarrow bot lower link mounts on the frame notch have to be cut and moved forward about an inch and a half and I dont have a welder guess I'll have to ask layinbody31 to weld the tabs back on in the right spots for me this 4wd frame must be bent slightly different because with the links completely screwed together as small as it'll get the axle is not centered in the wheelwell!!!Sorry for the rant but this has to be hurdle 1000 in a long line of things with this truck.Welcome to the world of one-off I guess
#98 |
Center your wheels!
Jim I have good news for ya. The welder is already loaded up in my truck and so I plan to come to your place right from work. With threading the lower bars all the way in to try to center the rear wheels, didn't that screw up your pinion angle big time? I doubt that the 4wd frame is that much different that it could be screwing things up so bad. My only thought is that the kit may have been able to slide forwards or backwards on the frame an inch or 2 in each direction and where you slid it over the framerails just happened to be 1.5" (or however off the wheels are) too far back. Just a thought. Don't forget that if I move the mounts down for the lower bars that the upper bars won't move and the pinion will be all funky. Unless we cut the upper bars and shorten them too...
#99 |
Turbocharged Pimp
We'll have to cut them thats fine with me,I'm just going to be happy the wheels will be centered and I can then sleep a night(dont know why its bothering me this much!!!!!)but cool I'll see ya tonight
#100 |
Center your wheels!
yay we figured out why the axle was crooked in the frame and we fixed it yay. Now to get the wheels centered...
