**Project** Relocate to under Bed
Old 07-06-2006, 02:27 AM   #1
Isuzu= s10 w/face lift
slammed isuzu's Avatar
Some fo you guys may remember my old thread when I got the truck all done. Well, since then I have changed my compressors out twice, and now got new tanks. Needless to say, I was tired of putting holes in the bed, so I decided to relocate it all under the bed.
Kind of sux because I just got the truck driveable a month or two ago (after being tore apart for 7 months) and now its under the knife again.
OLD SETUP: (1) 8 gallon tank , (1) DC7000 compressor , 1/2" GC valves for rear/1/2" SMC for front
NEW SETUP: (2) Stainless 5 gallon tanks, (2) Chrome viair 480's, 3/8" SMC for rear/1/2" SMC for front
Should be done very soon. Got most of the metal all cut and now most welded in the rear. I still have to get the "L" brackets welded onto the frome in the front to mount front valves on frame underneath the doors.
Heres some progress pics. All raw steel right now and not cleaned up at all. Tanks and compressors are just test fitten, nothing mounted permanantly yet.
Old 07-06-2006, 02:29 AM   #2
Re: **Project** Relocate to under Bed
heres a few more. Ill keep the pics coming as I get time to do more work as well. I should be able to get some more done Friday night or Sunday afternoon (depending on work schedule).
heres a link to the old thread so you can see how it was done originally.
http://www.s10forum.com/forum/showth...ghlight=months
Old 07-06-2006, 01:15 PM   #3
SHENANIGANS!!!
projo198's Avatar
I like the little tray for the compressors, pretty cool. YOu might have been able to jam a third tank in there though. My buddy and I got 2 eights in there after some fabbing.
Old 07-06-2006, 01:22 PM   #4
growing up a bit..
_Sly_'s Avatar
looks good so far.. keep it up..
Old 07-06-2006, 02:57 PM   #5
.gM 2 eNvY.
NoMa.On.20's Avatar
looks good i run everything under the bed and only time i dont like it is when you want to work on something under there is alittle of a mission...but if you are looking for a clean look its the way to go.
Old 07-07-2006, 12:50 AM   #6
yeah, I could have easily gotten the third tank in, but I only wanted 10 gallons total. I think this will be fine. If I had another 5 gallons under there, then the fill time would prolly take forever......lol
Anyways, nothin done today, but hopefully if I get off of work early enough tomorrow, I can get the rear finished, and get my brackets welded up for the front valves to bolt to and get some plumbing ran here........getting close to being on the road again.
Old 07-07-2006, 10:24 AM   #7
I Like Fire....HaHaHa
NickZigaitis's Avatar
Not trying to whore your thread but just throwing out a word of caution for ya. I have 1 5 gallon in a similar fashion as yours. But you have a 2nd one further back closer to the rear bumper. According to my calculations, I'll only have about 2 inches or so between the tank and the ground when pancaked. If you run front up-ass down, you are probably going to drag the hell out of that rear tank.
Just a thought.
Old 07-07-2006, 12:35 PM   #8
MGSDime97's Avatar
im tired of the stuff in the bed too, so i am putting it all under as well
Old 07-07-2006, 01:11 PM   #9
Mike D.
minkistinkis's Avatar
i've got a 5 gallon under the bed and i just shortened the backets, word of advice...weld the nut or bolt in before you put the backet back on. it's a bitch to tighten if you don't .
Old 07-07-2006, 01:27 PM   #10
yea my tank is under the bed along with 2 460 8 valves and charcle canister i'll try to get pics if sombody could do it for me that will be great
Old 07-07-2006, 02:20 PM   #11
dman311w's Avatar
I cut the legs off my standard 5 gallon tanks and welded them right to the cross bar.
Old 07-07-2006, 02:21 PM   #12
Polishing Guru
samandjen1's Avatar
In the process of gather new parts
Old 07-23-2006, 04:11 AM   #13
all right guys, after several weeks, I got her done now. I dont have the bed done yet, but heres some pics of the truck done.
Remember, I relocated everything to under the bed versus it was all in the bed before and I changed compressors, tanks, and rear valves.
I have the front valves mounted on the frame under the doors, I have the EAI chrome 7-switch box, and no longer the custome made switch panel in the console I had before.
Let me know what you think, plenty of pics comin.
Old 07-23-2006, 04:12 AM   #14
heres some more......
Old 07-23-2006, 04:15 AM   #15
and a few more.....
Old 07-23-2006, 04:17 AM   #16
I still have to weld all the holes shut in the bed that I originally made when I mounted the tank, and compressors, and SR80 in the bed. I then have to trim a little off the mounting brackets (where the bed bolts to frame) to comphensate for where some of the brackets are in the rear.
I am also gonna weld in some wheel tubs if all goes well.......im just so damn anxious to drive it....
by the way, the EAI switchbox works AWESOME!!!
Old 07-23-2006, 04:21 AM   #17
by the way, I did shorten the brackets on the tanks about 1 3/8" and it clears just fine. Had I not done this, I would have dragged the tank for sure.
Old 07-23-2006, 07:00 PM   #18
well, drove it a little today (just zip-tied the taillights to the bumper so I didnt get into an accident or pulled over) and everything works great.
I also leak-tested the system and found 3 very small leaks, and oddly enough, they are all coming out of the push-n-lock fittings from suicidedoors and not any of the brass fittings (the threadlocker 545 is good shit!!) so I may have cut the lines crooked or something, I will mess with it later, it didnt even drop quite 5 PSI overnight, so they are very minor.
Old 07-23-2006, 11:39 PM   #19
you deserve it.
defekt's Avatar
make sure you have em pushed ALL the way in. they go in alot further then you think, at least i thought so...
Old 07-24-2006, 10:38 AM   #20
yeah, I noticed that too. I am pretty sure they are, but I am gonna try just taking them out and pushing them in again. If not, I will cut the line again and make sure its straight as fock.
Old 07-26-2006, 12:48 AM   #21
come on guys, I was expectin some input here........I just drove it for the first time the other day and then drove all day today and everything seems to be holding up well. I still havent gotten started on repairing the bed yet, but I might get started tomorrow night.
Old 07-26-2006, 12:56 AM   #22
would you?
02indigo's Avatar
looks really good man...i just got my eai switch box in the mail the same as u but im not even bagged yet hahaha.
Old 07-26-2006, 12:59 AM   #23
growing up a bit..
_Sly_'s Avatar
looks good.. tanks dont drag?
Old 07-26-2006, 01:07 AM   #24
nope, I shortened the brackets almost 2" so they dont really even come close to dragging now. Had I not done this, they definetly would have dragged (maybe not the one towards the front, but the one right by rear bumper would have for sure)
Old 07-26-2006, 01:15 AM   #25
Evan's Avatar
Looks like it fits nice and snug!
Old 07-26-2006, 02:21 AM   #26
Frame Laying Member
GCash's Avatar
looks good, i just went through all that a couple weekends ago, i ditch the 12gal in the bed for 2 5gallons like yours under the bed. i mounted mine as far up as they could go, and mine don't drag at all when i'm riding cali
Old 07-26-2006, 10:11 AM   #27
Wears Black Shirts
RacerXS10's Avatar
I was wondering about that. I have a 5gal 8 port under the bed and had to chop the tank mounts down and even had to space it up above the bed rail. Draggin drain plug isn't good.
Set up looks real nice and clean. I'm sure the compressors aren't as loud since they are under.
Old 07-26-2006, 10:21 AM   #28
PUNISHING GROUNDS
got_u_sick's Avatar
Looks good man. I feel yah on the underbed setup, i just did the same thing. Great job!
Old 07-26-2006, 12:42 PM   #29
thanks alot guys. I really like it so much more now, and the compressors are so quiet I dont even know they are on sometimes while driving.
Page generated in 0.63638 seconds with 32 queries
[Output: 146.82 Kb. compressed to 134.99 Kb. by saving 11.83 Kb. (8.06%)]
