Project Redo My Old Backhalf - Page 5 - S-10 Forum
Old 05-05-2012, 11:07 PM   #201
Jimmyfied
Drain Bamaged's Avatar
Re: Project Redo My Old Backhalf
Old 05-05-2012, 11:11 PM   #202
Jimmyfied
Lastly a pic of the splash shield with the headlights installed
Old 05-06-2012, 12:28 PM   #203
BOOBIES
monster 98 s-10's Avatar
Quote: Originally Posted by rstadelmaier
After the alero?
its some Chrysler p.o.s.
n kinda ya i took that pic way back when before one of my friends got knocked up n turned into a bitch
BUTTTT i still love ur truck
Old 05-06-2012, 02:31 PM   #204
Registered Asshole
rstadelmaier's Avatar
Somebody come do my plumbing...please
Old 05-06-2012, 02:54 PM   #205
Jimmyfied
What you think of the shower liner
Old 05-06-2012, 06:51 PM   #206
Registered Asshole
i like the idea if it holds up to heat
Old 05-06-2012, 07:20 PM   #207
Hot Rod Enthusiast
s10kid17's Avatar
Lookin badass guy.
Old 05-06-2012, 08:11 PM   #208
Registered Asshole
Thanks man. I need to take a break im mentally strained from it haha
Old 05-06-2012, 09:29 PM   #209
Jimmyfied
It is vynil not sure of the heat how much we talking
Old 05-06-2012, 09:32 PM   #210
Registered Asshole
the heat a solenoid gives off
Old 05-06-2012, 09:34 PM   #211
Jimmyfied
That should be fine it is esy to work with and it comes in a four foot wide roll you buy by the foot for I think four dollars for a 1x4 piece but you can get any number of feet by fur footvwide I love the crap
Old 05-07-2012, 11:14 AM   #212
out draggin.. brb
Gimp's Avatar
i hear that.. my break lasted a whole yr
Old 05-07-2012, 11:20 AM   #213
Longbeds FTMFW
gunther19820's Avatar
After the alero?
lol....thats a kick right in the nuts.
Looks really good man. Soo jelly
Old 05-07-2012, 11:48 AM   #214
S - I - C
DROPTSBLAZE's Avatar
Looks great man, I've been following the thread, just haven't posted since I don't have much to add to what's been said already.
Quote: Originally Posted by gunther19820
My trans is -2*, my rear is +2*.
I know this doesn't usually end up happening on bagged trucks, but it can. The top example in this picture is actually bad for the u joints. There is no operating angles so they're not moving like they're supposed to, to lubricate the needle bearings properly.
Old 05-07-2012, 12:33 PM   #215
Longbeds FTMFW
^ I dont know if this image is supposed to be viewed in elevation or plan view^
I do agree with you, that if the u joints are totally inline with each other (both elevation and plan), it would be bad. But I believe this image only references either elevation or plan
Old 05-07-2012, 04:57 PM   #216
gettin layed
Dmbh09's Avatar
break is over get back to work... looking good man... are you having any issues with your drive shaft hitting the back of the cab...
Old 05-07-2012, 06:19 PM   #217
Registered Asshole
drive shaft does lay on the cab, but it drops just as much as i'd like it to.
i still plan on tubbing the cab a little just t not have that strain on the driveshaft.
Old 05-07-2012, 06:27 PM   #218
gettin layed
Dmbh09's Avatar
ok cool mine does the same thing... gonna try a hammer first it just touches when the frame is on the ground...
Old 05-07-2012, 06:32 PM   #219
Registered Asshole
yeah mines not on it too hard. actually my differential bracket touches my notch crossmember when layed out. which i am ok with too, because it's less than a half inch from the bags bottoming out. and i like that it bottoms out there that on the bags.
Old 05-07-2012, 06:34 PM   #220
gettin layed
Dmbh09's Avatar
does the truck lay out? or is it resting on the dif cover?
Old 05-07-2012, 06:36 PM   #221
Registered Asshole
once i decide to tub the front fenders. it'll lay out just fine.
Old 05-07-2012, 06:41 PM   #222
gettin layed
Dmbh09's Avatar
front is the worst part... you gonna keep a/c? well i say the worst just because of all the relocating... have you ever tubed an s10 before...
Old 05-07-2012, 06:55 PM   #223
Registered Asshole
truck has no a/c. sucks but works out good for tubbing. also the truck is a 95 4.3L TBI. Has alot less under the hood than an EFI. i relocated my coolant overflow and removed my ABS already. my only real concern is the wiring harnes on the driver side, but i have some ideas.
Old 05-07-2012, 07:01 PM   #224
gettin layed
Dmbh09's Avatar
that easy pull it back into the cab... cut out the bracket and move it up or to the side of the firewall... with the abs gone and no a/c you will not have many problems...
Old 05-07-2012, 07:07 PM   #225
Registered Asshole
i'm thinking side of the firewal hidden behind the fender
Old 05-07-2012, 07:16 PM   #226
gettin layed
Dmbh09's Avatar
Sounds like u have a plan... When are you trying to have it back on the road?
Old 05-07-2012, 07:21 PM   #227
Registered Asshole
having it back on the rode this week would be nice. probably no bed on until i finish all the plumbing and some little shit. i'll do the front within the next few weeks as well.
Old 05-07-2012, 09:27 PM   #228
Jimmyfied
It seems like lifting is easier than bagging
Old 05-07-2012, 10:55 PM   #229
Registered Asshole
By far easier. No clearance concerns and no air leaks.
Old 05-07-2012, 11:12 PM   #230
Jimmyfied
All we have to do is make room for 100 pound rim and tire plus the same for spare
Old 05-08-2012, 12:15 AM   #231
4x4 v6 blazer
neo71665's Avatar
Lifting does tend to be easier.
As for no air leaks mine has one right now. Then again all it effects is my horn and I can't air up a tire right off the bat. Doesn't leave me stranded on the frame waiting on tanks to fill, lol.
Old 05-08-2012, 11:57 PM   #232
One of my favorite builds so far! Keep it up man, good luck!
Old 05-09-2012, 10:04 PM   #233
Registered Asshole
thanks man. slowly but surely it's getting there.
Old 05-09-2012, 10:06 PM   #234
Registered Asshole
anybody like stainless hardline?
granted i only did one side tonight because i've been waiting over a week to get the rest of the stainless in.
but i also made some of these. tampons....... i mean shackles.... stainless duh. they'll get holes soon.
Old 05-09-2012, 10:22 PM   #235
Jimmyfied
Looking good
Old 05-09-2012, 11:32 PM   #236
nolowis2low's Avatar
that stainless is gonna look damn good man. iam ready to see more progress pics mayne. DO WORK!!!
Old 05-10-2012, 01:07 AM   #237
rce10's Avatar
This is some amazing work man, great job!
I was thinking of going with the same setup with the bags behind the axle but no real such about much else yet because this will be my first bagged project.
Old 05-10-2012, 07:26 PM   #238
Registered Asshole
thanks alot man. yeah this build has been picking my brain for awhile now
Old 05-10-2012, 07:48 PM   #239
Registered Asshole
well this is my idea for the valves. gonna throw it behind the passenger seat.
Old 05-10-2012, 07:59 PM   #240
gettin layed
Dmbh09's Avatar
hey man let me save you some trouble... before you install that i would go ahead and notch/tub for your drive shaft...
Old 05-10-2012, 08:01 PM   #241
Registered Asshole
i plan on tubbing it soon. this setup for the valves is 13"x21". it's gonna go directly behind the passenger seat where the jack used to be, so it wont be in the way of the driveshaft at all.
Old 05-10-2012, 11:03 PM   #242
out draggin.. brb
Gimp's Avatar
^^ that looks real nice and tight bro. I like your work yet again!
Old 05-10-2012, 11:50 PM   #243
gettin layed
Dmbh09's Avatar
looking good man... keep it up...
Old 05-11-2012, 06:55 AM   #244
iam glad ure doing this before i get to it so i know what iam kinda looking at. mine will be done a little differently but same idea.
Old 05-12-2012, 09:18 PM   #245
Registered Asshole
Old 05-13-2012, 04:11 AM   #246
Patawick's Avatar
Looking good!
Old 05-13-2012, 09:40 AM   #247
sick & twisted
1sikPuP's Avatar
i was gonna say, i hope you use stainless hardline on this...so much more dependable and looks so nice when done right...where did you order the tubing from and how much?
Old 05-13-2012, 11:55 AM   #248
Registered Asshole
i used stainless on a good bit of it. the rest is just airbrake line running into the cab.
i ordered the tubing from McRandal Fluid in Creighton. it was around $2.70ft which was an awesome deal. it's .049 wall and other places i shopped had .035 wall for $5ft
he also make hydraulic hoses and stainless braided
Old 05-13-2012, 01:43 PM   #249
out draggin.. brb
Gimp's Avatar
Hydraulic hose ftw
Truck looks so good man. No doubt this things gonna hold up for a long time to come. Keep it up!
Old 05-13-2012, 01:55 PM   #250
Diesel Tech
richarddhoward's Avatar
Want to bag a truck for me?
