Project: over winter - Page 3 - S-10 Forum
Old 03-14-2013, 08:56 PM   #101
i don't like people
Retro Ten's Avatar
Re: Project: over winter
that couch is bagging! parts are nice too. haha
Old 03-15-2013, 05:08 AM   #102
Registered Asshole
rstadelmaier's Avatar
That's not a couch. That's the back seat out of a Lincoln
Old 03-15-2013, 02:31 PM   #103
Lol conversion van, folds out to a bed fer those drunken nights someone help? I'm 1" from laying up front, because my lower arms are up against the frame. Will getting the max travel balljoints help, or do I need new lowers? Trying to stick with stock spindles...
Old 03-15-2013, 02:53 PM   #104
ELTC
Gimp's Avatar
i went thru the whole thread and didnt see if you were on stock lowers or tubular lowers. If you're on stocks you dehumped them right?
Old 03-15-2013, 03:03 PM   #105
Got them "fantastic" FBI arms bruh. I've notched the control arm pockets n what not to give them more travel, nothing else is rubbing but the arms :/
Old 03-15-2013, 03:24 PM   #106
ELTC
Gimp's Avatar
you may have to go to drop spiindles with those arms. i dont see the max travel bj's up top fixing your problem cuz like you said the lower control arm is already bottomed out on the frame. 2" spindles would solve it i think
Old 03-15-2013, 04:16 PM   #107
That's what I figured...I think I'd rather get some mmw arms or something, and keep the stock spindles. For the same price, why not try loll
Old 03-15-2013, 05:13 PM   #108
ELTC
Gimp's Avatar
something about those old FBI arms pushes the spindles out i believe and i think thats why you're having this problem.. Im not 100% on if thats whats happening but i know i heard something a while back on the fbi arms being a pain in the
d!ck.
pretty sure if you get some other kind of flat plate or tubular lower youll be fine and if you're running stock uppers it would def be a good idea to have those max travell bj's from PP.
I actually have a set and just looked for them but cant find em would have hooked ya up as im running mmw uppers now
Old 03-15-2013, 05:19 PM   #109
Registered Asshole
Hell spend the couple bucks and get spindles. What do you want to keep stocks?
Old 03-15-2013, 06:51 PM   #110
ELTC
Gimp's Avatar
^^ lift and camber.. only advantages of stock spindles
Old 03-15-2013, 10:38 PM   #111
Registered Asshole
Lift??? Who needs that? Isn't the point here to lower our trucks?
Old 03-15-2013, 10:45 PM   #112
Yes it is. But aside from the donk ass lift I get, I don't have to tub my firewall. Also my heater box that I've already modded, will still work!
Old 03-15-2013, 10:49 PM   #113
I also have the FBI uppers. Plan is, keep the uppers, and get the mmw lowers for now. As far as flipping my calipers in the rear, do I just flip the bracket? And ima try to scoop a 7" summit booster and waylayed disc/disc prop in the next few weeks. If all goes well, should have this hog out of the garage late April, early may
Old 03-15-2013, 10:50 PM   #114
Ohh but I do have firewall tubs and I'm thinking bout deuces, so I guess getting spindles wouldn't really matter....we shall see!
Old 03-15-2013, 11:40 PM   #115
ELTC
Gimp's Avatar
You're not resting of the firewall what so ever?
Old 03-16-2013, 01:17 AM   #116
^ no sir I am not. Let me try to find a pic
Old 03-16-2013, 01:25 AM   #117
I'm exactly 1" from ground front to back, and I might be 1/4" closer to the firewall than what's pictured. FBI arms,stock but modded spindles, tie rod notches, lower control arm mounts cut, and 245/35/20
Old 03-17-2013, 10:01 AM   #118
i don't like people
Retro Ten's Avatar
ive never layed a 20 on a stock spindle but ima guess that firewalls gonna get cut. start eliminating things, pop the lower bj and see if it will lay, then put it back pop the upper bj and see if thats it so on and so forth
Old 03-17-2013, 06:00 PM   #119
My lower bj is pressed in? I'll check the top one but I don't think that's the issue. If I have to tub I do, no biggie. I'm home tilltuesday, hope I get some shit done!
Old 03-17-2013, 09:08 PM   #120
i don't like people
Retro Ten's Avatar
yea its pressed in but just pop it from the spindle
Old 03-19-2013, 09:19 AM   #121
^duhh lol...smh. Well this weekend not much happened. Got my leaf spring mounts cut off the frame. Someone know what my lower bar length should be roughly?
Old 04-24-2013, 04:48 PM   #122
Been super busy with work and other people's projects, not much has been done to the blazer...but yesterday I did get all this done- my lowers are my cause of not laying, so they gots to go. I'm into my nice blower box and firewall with about 1/4" to frame. Front sheet metal back off, I'm getting mmw lowers this summer as well as that fancy lsoh kit ill love tab the firewall or cut if need be..also a pic of the cleaned up shop, brothers headliner I did, and cousins windows. All this was done yesterday I might add, hehe.
Old 04-24-2013, 09:08 PM   #123
i don't like people
Retro Ten's Avatar
i 100% garentee that firewall will be butchered. and if you ever plan on a bd tub for it now
Old 04-25-2013, 01:03 AM   #124
I believe you sir, which isn't a big deal..I have firewall tubs. I don't think ima go bd with this one.
Old 04-27-2013, 08:49 AM   #125
i don't like people
Retro Ten's Avatar
yea thats what we all say. doing the firewall twice is the worst part
Old 05-01-2013, 10:18 PM   #126
If I go bd, someone chime in if possible...will I be able to jus lay 2x3 in the stock frame, then cut the old to match up to the new?
Old 05-02-2013, 12:20 PM   #127
Inferno Fab
flnole78's Avatar
Yes you can do that but don't be fooled, there's still a ton of work that you will have to do.
Old 05-02-2013, 09:24 PM   #128
i don't like people
Retro Ten's Avatar
but why do certain things twice so.. while your there, plan for it
Old 05-03-2013, 05:36 PM   #129
Werd. I understand theres more work than what it seems :b I know y'all be hating cuz of the slow ass progress, but I think it's bouts get slower..might just pull the body off n build some new rails. I gotta cut the firewall n shit anyway, n we all know we need mooaarr low haha
Old 07-16-2013, 05:46 AM   #130
Uh oh.....
Old 07-16-2013, 05:47 AM   #131
Actually starting on this pig for once..
Old 07-16-2013, 05:50 PM   #132
i don't like people
Retro Ten's Avatar
some progress is better then none
Old 07-22-2013, 02:20 PM   #133
ELTC
Gimp's Avatar
EXACTLY!!!!! so get off the interweb and go work on your truck
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
