~PROJECT~ ItzAn808
Old 07-04-2009, 04:16 AM   #201
Its Hutch
Hutch253's Avatar
Re: ~PROJECT~ ItzAn808
Dude this is gonna be filthy.... I just bought a 2dr blazer all stock right now but that will soon change. I gotta check this out some time.
Old 07-04-2009, 03:59 PM   #202
DontPressureMe
Vikinglax18's Avatar
ahh good to see a local homie joining up on the forums. We should bag your sdime man! We'd be the only bagged trucks in UP
Old 07-06-2009, 06:59 PM   #203
PHAT JOE
blazerida88's Avatar
the wheels look sick with the orange
Old 07-07-2009, 12:13 AM   #204
DontPressureMe
thanks man i think so too
Old 07-08-2009, 11:08 PM   #205
DontPressureMe
UPDATE: FINALLY FINALLY FINALLY got the clutch in its final resting place. it has plenty of angle up now, and I should be DEF clear. I didnt really give a damn too much to clean up the bondo around the wire harness hole and clutch master mount, because to me as long as its functional then its cool. As long as my blazer looks cracking on the outside and inside the cabin, ill be happy. I dont have a ls1 under the hood so whatever.
Anyways, now I can get started on gettin those inners welded in, everything else mounted, and get the inside cleaned up. woohoo getting that much closer. Pics to come my camera didnt have battttttzzz
Old 07-11-2009, 01:40 AM   #206
DontPressureMe
Update. Got wires for all 4 valves up front ran and ready to go. Rewired the gauge cluster, got wires ready for the A-pillar gauges, and finally got the dash in. oh yeah on top of that i got layed off, so ill be working no the truck on the daily now! yay
Can anyone tell me where this harness goes/plugs into? I have vague memories of it not being used when I would be ****ing around with my h/u, but i can't remember exactly.
Old 07-11-2009, 01:43 AM   #207
DontPressureMe
BOTH THOSE plugs actually
Old 07-11-2009, 10:23 AM   #208
CatDaddy52's Avatar
In the first pic, you have a module (door popper?) & a ton of wires stuffed in the air plenum.....you know that's a wet area, don't you??....bad place for electrical goodies!!
Purple plug goes to BCM, I think....hard to see the general location in the pic.
Old 07-11-2009, 11:03 AM   #209
cRooKed eDge
nfamus10's Avatar
yep plugs into black box middle under dash. important.
Old 07-11-2009, 06:49 PM   #210
The Dreamsicle
cpolaris502's Avatar
Quote: Originally Posted by cpolaris502
Thats a sweet orange. And I am picky about oranges.
I had to correct it. ^^
Old 07-11-2009, 09:49 PM   #211
DontPressureMe
Yeah I welding a filler plate to block off that opening so moisture doesnt reach down there, so no worries
Old 07-14-2009, 05:20 PM   #212
DontPressureMe
I need to know if i need a dipstick for my york, or if i can get by without one. thanks!
Old 07-20-2009, 11:52 PM   #213
DontPressureMe
Fellas, I actually need some feedback on this one. Wired up my valves and i have a problem (couldnt find it with the search). The fills work fine, but the dumps STAY open when there is 12V connected. When I disconnect the 12v constant from the switch box hub, the dump valve selenoids release and fall back to close, but when i connect the 12v back into the hub, both dumps are triggered and stay on in the open position.
I wired them the same way as the fills, just wondering what is wrong.
I would assume:
Wiring on the actual valve is wrong, and i just need to reverse ground/power wires
switch box is ****ed up? I dont know
Old 07-21-2009, 06:24 AM   #214
Look on suiciddoors.com i think the have diagrams on how to wire all your stuff...
Old 07-22-2009, 04:35 AM   #215
DontPressureMe
I know how to wire it. Im pretty good with electrical from wiring systems and this is pretty straight forward. both the fill valves work fine and they are grounded with the dump valves
Old 07-22-2009, 08:45 AM   #216
Has Training Wheels
beaniebmx's Avatar
are your dump valves on backwards?
Old 07-22-2009, 03:43 PM   #217
DontPressureMe
no. Even if they were backwards they would still function the same, but both dump selenoids are triggered open when i connect power to my switch box. The black box thing on the valves starts to heat up and get hot from holding the selenoid up the whole time
Old 07-22-2009, 06:47 PM   #218
Giggity Giggity
Woody22's Avatar
this thing is gona be sick! nice choice in wheels man!
Old 07-23-2009, 10:07 AM   #219
CatDaddy52's Avatar
Me thinks you got a switch box problem!! There's another thread describing the exact same issue!
Old 07-23-2009, 04:49 PM   #220
DontPressureMe
haha thats my other thread i think but yeah a new switchbox is on the way. !
Old 07-23-2009, 06:53 PM   #221
scr8pnonu94's Avatar
nice build, I've looked at every page. the wheels are sweet w/ the orange color. I like everything I'm seeing....just can't wait to see it finished! G.luck with the wiring deal, hopefully the issue is the swit.box.
Old 07-23-2009, 11:00 PM   #222
CatDaddy52's Avatar
Dang! I knew it was a fresh thread!! Sure hope that's the fix you need!!
Old 07-24-2009, 12:44 AM   #223
they call me long travel
00chris's Avatar
deff a bad a$$ build, cant wait to see it finished
Old 07-24-2009, 10:09 PM   #224
DontPressureMe
im hoping too man.
Old 07-25-2009, 02:52 PM   #225
Chuk's Avatar
just got caught up, great thread! truck is really coming along!
Old 07-25-2009, 05:16 PM   #226
I Like Fire....HaHaHa
NickZigaitis's Avatar
Are you going to grind and smooth out that rough ass cut you made for the pockets?
Old 07-26-2009, 10:41 PM   #227
~Sunkin Sins~
Wybrow's Avatar
Damn dude, sick build. You have too much money though! hahaha
Old 07-27-2009, 01:27 AM   #228
CatDaddy52's Avatar
Nah!! You have too much money when you get all them tools & they all say Snap-On!!
Old 07-27-2009, 02:17 AM   #229
ntloenuf's Avatar
looks like this is gonna be a badass truck! and i kinda skipped thru alot of this and just looked at pics lol, but are those 22s on the front too? they look small but it might be because they're black wheels?
Old 08-17-2009, 06:42 PM   #230
rolling work in progress
Mr.woodscrewsNbondo's Avatar
you might have said it already but are you keeping the a/c
Old 08-18-2009, 01:21 PM   #231
Lookin good man. BTW that is pretty much how my rims came. Mine are American Racing, which I believe is owned by the same company as Gianelle. Thats pretty much the norm for shipping rims. If you order them with tires mounted alot of times they just band em together and you dont even get the box.
Old 10-19-2009, 01:40 AM   #232
[ ezefer ]
ezekieL's Avatar
So, is this done yet?
Page generated in 0.62606 seconds with 31 queries
[Output: 145.98 Kb. compressed to 133.62 Kb. by saving 12.37 Kb. (8.47%)]
