~PROJECT~ ItzAn808
Old 05-14-2009, 10:41 PM   #51
m007gunit's Avatar
Re: ~PROJECT~ ItzAn808
Nice welder!
Old 05-15-2009, 04:16 PM   #52
DontPressureMe
Vikinglax18's Avatar
Thanks the welder is kickass. still waiting on the damn stand tho. its retarded you can either get like $75 cash back or send in the pamphlet and wait 3 weeks for a stand. WTF? lol its so annoying being stationary.
Anyways, the shaved doors are fun! lol a nice touch i cant wait to fill them in from the outside, only have them installed atm.
here are some random shots
what a pos! way too big!
Cool shots while spinning
Old 05-15-2009, 04:18 PM   #53
DontPressureMe
What I'd like to get done today is the mounting bar that goes across from the ac comp and the tab that mounts to the alternator mount.
Old 05-15-2009, 07:59 PM   #54
AFFILIATED KREW
AVNCHRIS's Avatar
slowly working.
i like to see more how u mount the EDC. plan i getting one too.
but maybe have to push my EDC lil more out because im running a big alt
Old 05-15-2009, 08:04 PM   #55
DontPressureMe
I officially hate drilling through this plate. takes forever without a drill press. Still taking some final measurements before i mount the crossbar. I have to put on the new pulley, do some more fitting, and then we'll be in good shape. Ill be gone most of this evening so I prolly wont get to work on it until tommorow
Old 05-15-2009, 08:08 PM   #56
AFFILIATED KREW
AVNCHRIS's Avatar
look good so far! is there another mount. on ther other side of the plate? where it hook up to the alt bolts?
Old 05-16-2009, 03:36 AM   #57
DontPressureMe
yes i will be doing another mount on the backside. i didnt mount anything for the pulley spacer because i dont think ill need one, but if i do it wont be hard to add in. more pics tommorow
Old 05-16-2009, 03:58 AM   #58
hmmm. what goes here?
Famous4Life's Avatar
looks like this is gonna be a real fun project. ill be watchin this also.
and thats alot of stuff you got. cant wait to see you start cuttin, and deff cant wait to see the blazer layin and draggin.
Old 05-16-2009, 04:07 AM   #59
Crazy As Fuck
leadsled2020's Avatar
my ? to you is..... with the compressor mounted solid and the alternator mounted solid, how do you plan on,1) getting the belt on, or 2) putting tension on it to tighten it?????
Old 05-16-2009, 09:29 PM   #60
DontPressureMe
the serpentine belt for everything else has its own tensioner. thats easy to adjust. if you read my post above i will PROBABLY need a pulley spacer when push comes to shove, thats how it will be tightened
Old 05-19-2009, 04:03 AM   #61
DontPressureMe
I have had a few problems in the last few days.
But i did get some more parts in. bad news last
Heres the alternator. But with a broken T50 inside the alt shaft. Channel Lock FTMFL. Im giving it to my buddy who rebuilds them, so im gonna give him the new pulley to throw on as well. It slows down here because My garage is where i work and build stuff and i usually leave the truck outside to work on, but its raining here and i dont have a pop up or anything to work under. That and i have no nights because of lacrosse
Old 05-19-2009, 08:25 PM   #62
V8 with bags
V8Blaze's Avatar
im pretty sure that torx bit is for holding the shaft and the large nut on the outside is what rotates. IIRC those pulleys are pressed onto the shaft similar to a power steering pump
Old 05-19-2009, 08:35 PM   #63
DontPressureMe
yeah i know that. the bitch broke off when my bro was pulling the other wrench when it happened. Got some work done today though. tonite ill be powdercoating the drop spindles orange and maybe/hopefully get the other wheel well all stripped down and ready to go
Old 05-20-2009, 02:41 AM   #64
DontPressureMe
Got some more work done tonite. Got the lower control arm and spindle off, yada yada. i have a few questions tho
There were already drop shocks inside the spring up front, but they are far smaller than the toxics i bought. Which one is the right size? I think its the smaller, but i really cant tell because the bigger may work when compressed
I can take a comparing pic inside the wheel well tommorow if you guys dont have an answer.
alright next
How the hell do you separate the bearing/hub assembly from the spindle!?
and then progress. sorry for the shitty night shots but its something
Tommorow hopefully I can get the upper Ca off, and finish the other side completely. hopefully it will be easier putting it all together because alot of these nuts/bolts/ whatever were rusted as hell and so tight, as if it were the first time they were being moved since the first day they were put on. Thanks for the input in advance.
Old 05-20-2009, 03:41 AM   #65
Wicked Crispy
9K CRAZY's Avatar
The toxic shocks will be fine. I'm running stocks on the front of my blaze and can lay with 20's using sd lower studs and ART relocaters. Keep in mind I also dehumpped my lca's. My recommendation bearing/hub would be to reinstall the knuckle assembly but leave the bolts out of the hub then put a slide hammer on the wheel lugs and go to town. just my $.02 , someone else may have a better way.
Old 05-20-2009, 01:47 PM   #66
CatDaddy52's Avatar
Is it a goofy angle of the pic (6th pic in post 52) or do your door plungers actually face forward???
Also, you might want to clean up the "+" battery wiring....all those terminals on one post ain't a good thing.....
Old 05-20-2009, 03:45 PM   #67
DontPressureMe
The door poppers are in the door yes. The battery is long gone lol I was just dry fitting some things
Old 05-29-2009, 04:02 AM   #68
shit's lookin good.
IS THAT A GSXR 750 with a 1000 tail?!?!?!?!?!
holy shit you must know a really good tig welder to put the subframes together!
i got some shit for you to powdercoat on my new dirtbike too. you free this weekend? i wanna see the blazer, then maybe we can ...uhh...blaze down hwy 7 on the bikes.
Old 05-29-2009, 06:18 AM   #69
nemesis8's Avatar
to take the pulley off the alternator i used a socket and had my dad hold the pulley tight with pliers.
yeah it messed up the grooves on the stock pulley but i wasnt going to use it anyways.
Old 05-29-2009, 02:23 PM   #70
welding bum
Quote: Originally Posted by Vikinglax18
More new shiz! now i can start on the handles woohoo
For shits and giggles!
Shoulda just said "look at me. I smoke weed and won this many gold metals. Get ripped!" LOL
Btw this kit is already impressing me its beefy as you can see!
best shave kit on the market!!! had the autoloc/vpa kit in my honda for a month and it shit on me...put in the spal and 5 years later it still worked flawlessly!!!
Old 05-29-2009, 09:31 PM   #71
DontPressureMe
yeah man. SORRY GUYS haven't had time to update this thread in a while. Just finished up Lax season, came out 4th in state. But im ready to graduate lol. Anyways, that and just got my wisdom teeth pulled this morning, and i cant really be doing anything with alot of movement for the day today and prolly tomorrow as well. The best part about my situation now is I have WAy more time to work on stuff all day after school and weekends, I no longer have to go to practice. Work to make money, and then the truck will come after during the week! super excited now man
Good news, Jason shipped out the arms and the (i think) slim and skinny and they should be here tomorrow, which means ill have 95% of the parts i need to get the front down low. Got the doors shaved right now, just finishing up Sanding the Rage Gold to clean it up.
ATM while i sit up stairs bored out of my mind, 80 degrees and sunny out, I'm jotting up a list on my new mac book pro 17" (****ing sick) on my order of operations, how im going to go about doing things
Things I need to do:
- get the passenger side wheel off and both ca's/ tie rod off (other sides already stripped)
- Powder coat the Drop Spindles, bag cups, CA's (I DONT know if im gonna be able to PC the arms because are the ball joints and all that jazz hard as hell to get out? should i just throw some paint over it and call it good?) I know i cant pc it with the BJ's and stuff in. if you have any input on how much work it would be let me know)
- recess the tubing in the frame for the shocks, as well as build the lowered shock mount on the CA's
- Cut out the spring pockets and weld up any/all seams
- Mount Cups on bags then install that shiz (this includes running the air line)
Thats basically all i can think of. If some of you guys have a tried and true, really efficient way of going about the whole process, list the steps. Time is on my side but id like to get it done faster than going about it in my own way.
Old 05-29-2009, 09:36 PM   #72
DontPressureMe
Quote: Originally Posted by lifted96Z
shit's lookin good.
Bro Just noticed your post. jeremy you ****! i know its you lol. Yeah bro hit me up man we'll have to kick it. Blazers about to be So dope!
To the s10 forum. Thanks for helping out along the way it does make a huge difference.
Old 05-29-2009, 10:28 PM   #73
DontPressureMe
Yeah my bro who goes to Bates technical college up here is going to rebuild my alternator. I guess the bearing, stator, and a few other parts were just really worn out. I think he's upping the amperage 40 so for about $85 i think it is I'm refurbishing my alt with brand new internals and a bigger output. plus that i got the case in the garage waiting to be PC'd orange =) i think its a decent alternative for the moment instead of shelling out $300 for a new H/O alt.
Old 06-01-2009, 07:58 PM   #74
DontPressureMe
LIttle update:
Got the bag cups, spindles, and alternator Powder coated. I'm going with a Darker orange called 'nissan orange'. It pops out in the sun it should look pretty cool. Did you guys keep your dust shields when you installed your drops? im about to ditch them.
ALRIGHT got a few questions
Does the offset of the bag cup matter at all? depend on side? etc. etc
pics:
2. There are 3 bolts that hold the bearing hub onto the spindle. On our old spindle, they give you 3 holes in the back to push the bolts through. On the new one, they only give you 2 of the holes for the bolts from the back of the spindle. The 3rd hole is IN FRONT, with no access point in the back, but it is threaded. How do you fit that bigass bolt in that little space? what do i do?
pics:
Old 06-01-2009, 08:20 PM   #75
The Schnauzberrys
bmack8613's Avatar
x400 best kit ive ever used.... very nicely priced as well
Old 06-01-2009, 08:27 PM   #76
DontPressureMe
figured out the bolt spindle hub assembly forgot the bolts they included with the spindle lol. the question about the bag cup mount still stands!
Old 06-01-2009, 09:34 PM   #77
PHAT JOE
blazerida88's Avatar
if they r the sd cups with the hole in the side to run the airline through the frame, then they should only fit up tight on the correct side, the hole in the cup faces the rear of the truck, so place the bag and cup in one side with the hole facing the rear of the truck, and if it pulls up and sucks up flush in the spring pocket then u r good to go, but if it doesnt suck up flush when u tighten the nut, then it probably goes in the other side
Old 06-01-2009, 10:41 PM   #78
DontPressureMe
yeah they are the sd cups. I guess ill just have to fumble around with it until i get it right, no big.
Got the second bearing hub out of the old spindle. took damn near forever because it was old and rusted to hell. Check this out, found out the 2 are different models. WTF?
Rusty and old
newer and nicer!
Well whatever. they are both in their new homes so im happy. I think that may be all for the night im pretty tired
Old 06-01-2009, 10:56 PM   #79
Bmanxer's Avatar
Bro make sure you pack the hell out of those bearings with grease and grease your spindle too, I obviously didn't put in SHIT TONS of grease in mine and I actually seized my bearing hub assembly to my spindle...literally welded itself to my spindle...
In the process it blew off my dust cap over the castle nut and which in turn blew out my BRAND NEW RIMS center cap
That was NOT a fun experience...
Old 06-01-2009, 11:48 PM   #80
Moderator
Wicked Mayhem's Avatar
he has sealed hubs.. so there's no maintenance.
and one has probably been replaced at some point.
and i cant see from the pics, but i assume you found the stud that came with the drop spindles to use in place of the third bolt?
you ordered sd control arms, did you tell them your running blazer spindles? IIRC they have to do some machining on something for them to not hit. might give them a call to double check on that.
Old 06-01-2009, 11:52 PM   #81
DontPressureMe
Yeah i told ricky about the arms going on a blazer, he made the note. and on the bag cups, I meant how the bag mounts to the cup, not cup to truck. Where should the bag be mounted since there is plenty of play within those mounting holes? Do i need to offset the bag away from the engine?
Old 06-01-2009, 11:53 PM   #82
looks good man
Old 06-02-2009, 12:44 AM   #83
DontPressureMe
thanks mayne. super excited to get working on everything else
Old 06-02-2009, 02:01 AM   #84
bagged DD on 20's
Big_Bake's Avatar
you should push the bags as far towards the outside of the frame as they can go on the cup. that way you dont have to notch as much frame.
Old 06-02-2009, 05:23 AM   #85
DontPressureMe
cool. thats the answer i needed. More work tommoroW! Ca's and tank coming in, pics to come.
Old 06-02-2009, 06:10 PM   #86
V8 with bags
V8Blaze's Avatar
everything looks great man. And yea, with a larger bag it makes it easier to slide the bag towards the spindle to keep from cutting into the weld on the engien crossmember. I had to cut mine to slide them over due to my old ass sd cups.
Old 06-02-2009, 06:54 PM   #87
4blow
tjwskateboy0505's Avatar
dam that is alot off shit. wish i had that sitin in my house. lol good luck with the build
Old 06-02-2009, 10:39 PM   #88
DontPressureMe
New update:
Arms Came in. Almost Creamed my pants after opening the boxes. Now thatsssss why they are $$$ Excellent workmanship and build quality, the cost is totally justified . Ballin ass shit Jason thanks man
Question. I ordered them raw as you can see, and I dont want them to rust. Im assuming that = Paint then? LMK
The dash removal wasn't bad at all, i just dread putting it back in. Not the actual dash, but routing the wiring harness like it was originally. Its just a breath of fresh air because I can rewire all my switches, my h/u, all the shitty switches i had wired, and make them CLEANNN! yay.
Okay 1 more question. You know how on a virgin spring pocket at the bottom, there is that little lip that bends inwards and up? Am i supposed to cut that ****er off? just zip around the bottom edge or what?
Old 06-03-2009, 04:38 PM   #89
V8 with bags
V8Blaze's Avatar
yes indeed, the little lip all the way around has to go, just be carefull at the part on the back, if you cut to far it cuts into the weld. Just once you get the verticle part of it cut off just pay attention to where you grind and it will be alright.
Old 06-03-2009, 08:59 PM   #90
DontPressureMe
Sweet. I figured it was the little lip. I mounted up the bag on both pockets and made sure there was a maintained spaced of ATLEAST 1/2"+ all the way around the bag. Most of the time it was more, only in some areas was it CLOSE to 1/2'', so i think im pretty set. I read that slams do not ballon right? if so they will work perfect. I cant imagine a balloning bag used in an s10, sure seems like youd have to cut alot more out. SLAMS are ****ing dope anyways. Im just letting my compressor cool down before i go out and mount up the arms and bags.
I'd like to make a point about cutoff wheels. I was using the 'husky' brand ones that came with my husky cutoff wheel. Better wheels make a HUGE difference. my buddy gave me some of these 'razor edge' ones that were a bit thinner, and they performed much better. I could keep a higher speed longer and at lower air pressures, it would cut through the metal WAYYYY faster, the passenger side pocket was a breeze compared to the driver. I mean, given I've never done it before and the first one was basically a pilot, these cut off wheels helped alot. So if your going out to get some, either get a nicer brand or ones with a sharper, thinner style. they do help out
Old 06-03-2009, 10:30 PM   #91
V8 with bags
V8Blaze's Avatar
i bet your going to have to cut up higher and a little farther back on the backside of the pocket. Slams dont ballon out but when they compress they get a little fat at the top and bottom. To solve this on my truck i took a big ass cresent wrench and flared the pocket out to make a little lip that cleared the bag
Old 06-04-2009, 01:01 AM   #92
00layinlow's Avatar
X2, definitely need to cut higher and angle back further, you probably want to make the corners more rounded as well. Man, F the 3" air cutoff wheel, the 4 1/2 electric grinder cuts the frame like butter!!
Old 06-04-2009, 01:16 AM   #93
DontPressureMe
you should post up pics of it if you have em. 1/2+ isnt far enough?
Old 06-04-2009, 01:34 AM   #94
00layinlow's Avatar
I probably cut about an inch higher, alittle into the tab, and used the cresent wrench method, and about a 1/2" further back. Things get kind of tight in the top rear corner when the bag is compressed.
Old 06-04-2009, 01:49 AM   #95
DontPressureMe
Got the Arms Primered and painted. I used these two. REally dont care about look just longevity.
a nail and welding wire. BrillianT!
Old 06-04-2009, 01:51 AM   #96
DontPressureMe
do you guys got any pics of your pockets?> I kinda get what your saying but its hard to decipher exactly w/o pics
Old 06-04-2009, 02:15 AM   #97
00layinlow's Avatar
It's rough, but something like this:
Old 06-04-2009, 02:56 AM   #98
DontPressureMe
Sounds good. ill take care of that tommorow. Does everything else check out?
heres a vid of the Driver side. Passenger side has even more room around it.
There is alot more cut out that video was before finishing both up and keying in on some of the tight spots seen.
Old 06-04-2009, 03:03 AM   #99
00layinlow's Avatar
Are the cups tight in the pocket?
Old 06-04-2009, 03:06 AM   #100
00layinlow's Avatar
And if you cut it up more and use the cresent wrench in your highlighted area, you won't have to cut that section out.
Page generated in 0.65889 seconds with 31 queries
[Output: 226.69 Kb. compressed to 207.82 Kb. by saving 18.87 Kb. (8.33%)]
