#1
[Project] Bagged 98 S10
Ok so this is just another customers truck, his name is s10r0b on here. I bagged the front of it a while ago and dont have any decent pics of it but this one..He has billet 17s on it now and other shit..
![]() Im doing a standard air over axle setup with a bridge kit from Suicidedoors, as well as a forward 4 link with the stock gas tank. Heres a shot of the bridge crap tacked up; Ill prolly change the bars in the future for more clearance.. ![]() I made a custom gas tank crossmember that not only raises the gas tank so it doesnt drag, but provides a mounting point for the upper bars AND has dope diamond plate ends ![]() ![]() Im using the stock hangers but moved them back on the frame rails so they dont drag and to get the upper and lower bar lengths closer to each other. The problem with most bolt on kits is they have the hangers in the stock location, so the lowers are much longer than the uppers causing significant pinion angle change at the extremes of the travel. ![]() Since the bags are over the axle, there isnt much room for the upper bars to mount to the axle tubes, so I bent this piece of 1.5" steel with a torch to bridge the pumpkin. If this was an import or another truck I can weld to the center section, but the diff housing is cast on s10s and a typical MIG weld will eventually break out and fail. The bridge is a lot safer. ![]() Ill update the pics as I work on it.. |
Oh, yea...
Re: [Project] Bagged 98 S10
Wears Black Shirts
I need to start taking notes on this, did you get my pm on the blazer? looking foward to seeing the bars all mounted.
Hoods are overrated
<--thinkin bout making an axle bridge like that to link my truck up cause mine's over the axle too & it's a tight fit
Lay'd
Looks good so far man, nice work.
sweeet
werd.
damn man, theres lots of work up there isnt there? btw this is cab
Drop N Destroy
:thumbup:
Rocker layin member
Looks great Dave. Why are you doing a 255/224 bag instead of an F9000? Is the kid going to hop it a lot or something?
He bought all the stuff and gave it to me to install, so thats what I got. Otherwise ya Id prolly do a F9000 behind the axle..
fuq dem hataz
werd....who makes those
I <3 SPARKS
the f9000's? firestone.
airlift makes a similiar bag. |
lol..nothin wrong with double convoluted over the axle, its just a basic tried and true setup thats easy to install and holds up well, just doesnt ride the best and doesnt give the best lift..
![]() as for f9000s, heres the one i did last year.. ![]() |
forum idiot
looks good dave...i like the diamond plate
Post Whore?
hey dave, do you got anyone local that makes steel braided airline with the fittings and length that you want? having a problem finding one around me. my buddy needs a couple lines.
yep The Hose Shop in piscataway does it, its how I did the fuel lines on the blazer x..
Rocker layin member
f9000s=the whip. I love mine, but I guess you have to install what the customer brings you. I am sure it will look clean and professional like always.
Post Whore?
got any idea what these would cost to have made? 1/4" npt male x 1/4" npt male swivel. one 3 feet long, one 3 1/2 feet. might be able to get them local, and im not sure how much my boy should be paying.
gumby green
looks cool dave, i know rob is happy his rear is getting bagged. its going to be a nice install witht he stock gas tank and the 4 link
are you planning on getting another 5 gallon? and where are the tanks going this time? |
(Chaos)
keep the pic/.s coming on the 4 link 4 link right? i might steal your idea .
tanks are goin in the bed, only one 5 for now :\
ive been away on vaca and other general bs so ill be back on this truck tomorrow and get a bunch of shit done. |
Oh, yea...
"And get a bunch of shit done". Shit includes pictures right?
planning and saving
could that notch get any bigger? guess you dont really need to use your truck as a truck.
#24 |
Draggin bed
Why would u wanna use a truck as a truck?
#25 |
planning and saving
serious...
#26 |
say what? its not any bigger than any other notch out there..actually its a lil smaller because i only used about 6 out of the available 8 inches..
#27 |
(Chaos)
he must be new to baging for 20s
#28 |
or to baggin period..
#29 |
un banned
another sick job rolls outta daves garage. looks good, man. that ssd bridge kit is nice.
#30 |
(Chaos)
wel shit im new to baging and im not that dumb no offense but this is nt a work truck after all its a s10
#31 |
(Chaos)
oh ya new muffler time that thing is a monster
#32 |
Ok couple of pics of what I did tonight...built the lower bars and upper wishbone...oohh look at the sexiness, you love it..
![]() ![]() If case youre wondering, I use chains to set the axle at drive height, then jack up the front of the diff to dial in the pinion angle..this method works well for me. |
#33 |
I took this pic to show the bars relation to each other. You can see they are almost parallel, which is actually what you dont want, thats why its ALMOST parallel heh.. In this pic the lowers are at 4° and the uppers are at 6° meaning the instant center of the setup is somewhere up front. Actually it doesnt really matter because Im not building a drag car here but its good to know the setup is in good shape...werd
#34 |
forum idiot
ah ha
#35 |
un banned
those are some big notches. this thing gettin some 20's?
#36 |
no..thats a standard notch size. ya see, when you have a 'bridge kit' the bars and bag mounts are already set at a determined height on the notch. so the notch size isnt in question, you have to find out how high the axle needs to be to lay out on a specific tire, then add half the axle tube to get to the top of it (1.375"), the axle mount (1.5"), and the height of a compressed bag (3"). That measurement is how high the bag mounts need to be in relation from the center of the axle to the frame. You then set the axle mounts (which is the notch in this case) to that height and weld em in. Of course it usually ends up the notch is a couple inches higher than it needs to be but thats fine, only leaves room for bigger wheels in the future heh..
#37 |
un banned
#38 |
(Chaos)
ya i think i ****ed up i got 8 inchs above frame i got 16 inch wheels will i be layed out with full ext of the bag?
mono leaf bridge |
#39 |
fuq dem hataz
#40 |
Ok people have been asking about the driveshaft tunnel so I took pics of the one I just did. Of course this is just a general overview, youll need to test fit your driveshaft to make sure you clear.
The real problem is the hump underneath the cab, but once thats cut the pinch weld at the back needs to be cut too. Here I cut up as far as possible without cutting into the cabin. Theres quite a few pieces of metal here so you can cut them all out and just leave the fold. Afterwards weld the seam if you need to, or just seam seal it. Also Im satisfied with the cut because it hits the shaft the same time the shaft hits the gas tank crossmember, and I know it doesnt go that high so Im good. ![]() |
#41 |
Inside I dont need a huge cut, maybe just an inch of clearance underneath, so what I did was cut the floor out then bend it up out of the way, and then continue the cut on the thicker bottom panel so it was gone. You can see the two layers here..
![]() I then straightened the floor panel out, trimmed it down, and bent it back into place. This will leave a gap between so filler pieces will need to be made and welded up. Once finished, just seal the hell out of it and youre done. ![]() ![]() ![]() A tunnel like this wont even hardly show thru the carpet, and this one is actually an inch higher than the shaft. If you need anything bigger then I suggest cutting the floor out to the back wall and making a replacment tunnel. |
#42 |
nice dave, what size tube did you use for the gas tank crossmember?
#43 |
1"x2"x3/16"
#44 |
forum idiot
dave...you need to notch out my floor in my s10...shit rubs alot...
#45 |
you lose
#46 |
lol
#47 |
Gave her the O face.
Location: tallahassee/orlando/ft.lauderdale User is: OffLine |
Lemme get this straight, your doing this bc of his set up and also b/c he has a reg cab right? ... From what I've read... but havnt confirmed is that you USUALLY don't have to worry about the shaft rubbing if you have an extnd cab?
#48 |
S - I - C
And on the reg cabs it depends partly on your tire size |
#49 |
landscraper
#50 |
(Chaos)
so every stand cab has to do this .
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f125/project-bagged-98-s10-121327/
| :::::::::::::::::AFTERHOURS FABRICATION::::::::::::::::: | This thread | Refback | 01-08-2008 08:35 PM | |
