Project Air Ride - Page 6 - S-10 Forum
Project Air Ride
Old 01-14-2013, 09:23 AM   #251
lowpat's Avatar
Re: Project Air Ride
New wheels arnt in the budget right now so I just needed to make due whith what I got
Old 01-21-2013, 12:56 PM   #252
lowpat's Avatar
ok ive been dealing with this prob for a while when i got the ass droped down while driving im getting a weard vibration from the rear end everything is straight and the pinion angle is good. Ive herd some people talk about having to shorten the drive shaft up could that be whats wrong ? ive had the truck up on a lift and still couldnt figure it out ?
Old 01-21-2013, 09:56 PM   #253
i don't like people
Retro Ten's Avatar
is the drive shaft bottoming out on the trans then? try and move the axle back a half in.
Old 01-22-2013, 06:35 PM   #254
lowpat's Avatar
I think it might be bottomed out but not 100% don't think I can move the axle back with the setup I got thought ? Can I ?
Old 01-22-2013, 07:42 PM   #255
i don't like people
Retro Ten's Avatar
yea by your lower bars turn them out but your pinion will change if no one gives you a def answer give sd a call you may have to get you ds shortened a lil. start a new quik thread youll get more responses on your prob
Old 01-24-2013, 07:46 PM   #256
I ride low
Mr.cripple's Avatar
set up looks great!
Old 01-25-2013, 12:59 PM   #257
ELTC
Gimp's Avatar
its the SD 5 link i believe you can. You may have your lowers to tight and your rear bars too tight. Loosen the rear bars a little that will push the bottom of the axle back then loosen the rear bars that will counter the work you did on the front lowers. You'll only be able to make a slight change tho because of the wishbone length. If it doesnt work you may need to shorten that driveshaft
Old 01-25-2013, 04:44 PM   #258
lowpat's Avatar
Got it thanks
Old 03-01-2013, 07:42 PM   #259
lowpat's Avatar
Well had a rare day off so did a little work on the old truck today. I didnt really do a clean job with all the wireing for everything i just kind of had it all shoved behind the pas seat. I pulled the seat out and tucked all the wires and other shit underneith.
Old 03-01-2013, 07:45 PM   #260
lowpat's Avatar
My next bone to pick with this truck is getting some new fenders over my rear wheels not really a tub though. I still want the midle open
Old 03-01-2013, 09:18 PM   #261
i don't like people
Retro Ten's Avatar
do a small notch for the tie rod without welding any thing in then see if it clears down the road youll need it any way. and i agree the bag cups look big, then weld in a pipe for the tie rods after all said n done
edit: sorry wrong page
Old 03-01-2013, 11:16 PM   #262
lowpat's Avatar
used a nice kinda hidden place to run some kill switches for all the air management stuff
Old 05-02-2013, 06:48 PM   #263
lowpat's Avatar
Just finished up the bed and all sorts of odds and ends shit but im happy with the results.
Old 05-02-2013, 06:50 PM   #264
lowpat's Avatar
Old 05-03-2013, 08:53 AM   #265
Dems 22s
mattadams13's Avatar
How do you like the ride of the shocks up front? Ive really been wanting to try some fox shocks on my truck.
Old 05-03-2013, 10:25 AM   #266
lowpat's Avatar
I like them. I think its a better ride for sure
Old 05-20-2013, 05:03 PM   #267
lowpat's Avatar
So right now I have some nasty noise coming from the rear end I re checked my pinion angle on the tranny its at -5 and now on the rear end its about when im at ride height im at about +3 I have new u joints and the truck was level when I checked it.
Any help would be great
Old 05-20-2013, 05:05 PM   #268
lowpat's Avatar
Old 05-20-2013, 09:23 PM   #269
lowpat's Avatar
I got it adjusted to +5 now still getting a nasy sound though
Old 05-25-2013, 02:14 AM   #270
Square-body crazy
J@mes's Avatar
Is it like a whining sound..?
Old 05-25-2013, 11:24 AM   #271
ELTC
Gimp's Avatar
check your trans mount and engine mounts. make sure none are busted. just had a huge issue myself last weekend with my fan hitting the shround when riding low/draggin and the damn trans mount was busted and I never even noticed it before!
Old 05-25-2013, 02:02 PM   #272
lowpat's Avatar
The mounts are all good and yes its kinda a whining slash grinding noise just when I lay out im just waiting for something to explode lol
Old 05-25-2013, 02:31 PM   #273
Square-body crazy
J@mes's Avatar
Ah. I had a drivetrain noise back when the rear was static and monoleafed (Works,but oh my god.. It rides HORRIBLE) and it was the rear end rotating a little when i accelerated and causing the rear universal joint to be at a bad angle.
I was just thinking that may be something to look at,even though you're bagged & linked.
Old 05-28-2013, 12:47 AM   #274
YOU ARE GAY
layedouton20s's Avatar
I would bet money your driveline is hitting the bottom of the cab.
Old 05-28-2013, 03:01 AM   #275
5.74x4's Avatar
Could the drive shaft be bottoming out in the transmission causing your U-joints to bind?
Old 05-28-2013, 03:05 PM   #276
ELTC
Gimp's Avatar
never noticed if you did a driveshaft tunnel on your cab or not??
Old 05-28-2013, 06:28 PM   #277
lowpat's Avatar
Nope still got room under the cab not much though if I was to run a bigger wheel it would for sure
Old 05-31-2013, 02:08 AM   #278
YOU ARE GAY
Check all the way forward cause there is the little hump that drops down. I tunneled my driveshaft and didn't do that part and it was still hitting. it was only when the front was aired up to 50 and the rear was dumped. I was pissed.
Old 05-31-2013, 10:56 AM   #279
Deadlines are Overrated
wirrrey21's Avatar
So the sounds happens when your driving real low? or nose up ass low? or completely up? i have a feeling you have to shorten your driveshaft just alittle bit. I dnt know if you can do it, but put the truck in the position that it makes the noise and crawl under and try to remove the driveshaft. if you can't slide it forward...there's your answer. probably easiest is if you can get it on a 4 post lift you drive up on.
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
