PROJECT: 1995 s10
Old 11-21-2008, 11:33 PM   #1
95 S10 Single cab V6
djremix's Avatar
PROJECT: 1995 s10
OK so I have way too many pictures to list so we'll start with my cardomain page...
http://www.cardomain.com/ride/3112414
And continue where cardomain leave off...
Inner fenders removed, change all hard brake lines
(partially) installed shock towers
During destruction
lower arm off...most of it is out!
Testing bag fitment, cut spring pocket
Testing fitment, travel, make sure bag doesn't rub spring pocket...
Still plenty of work to do, obviously, so I'll keep updating as I go along!
Old 11-21-2008, 11:35 PM   #2
white wall member
tolowinorlando's Avatar
Re: PROJECT: 1995 s10
looks good so far keep it up man
Old 11-21-2008, 11:44 PM   #3
never finished.
herseydestin's Avatar
i think this is the third thread on this in the last couple of days.
Old 11-22-2008, 11:27 AM   #4
Tom@LRD
98LowS10's Avatar
Looking good so far, but I would do something with the battery tray. If you try to use it like that, the weight of the battery is just going to fold it.
Old 11-22-2008, 04:09 PM   #5
djremix's Avatar
Yeah it's there temporarily...will relocate it...somewhere
Old 11-23-2008, 07:30 PM   #6
djremix's Avatar
UPDATE...UPDATE...UPDATE
I did some work today to it but it's so darn cold working outside that I had to quit a bit early but it's progress...
I still need to replace my brake lines on this side and reattach the sway bar...
QUESTION??? Are you guys running with or without sway bars??? I'm not just going front/back I'll also do side/side...
Old 11-23-2008, 07:36 PM   #7
Hmm.. well now..
Gearstix's Avatar
Are there holes rusted into your frame upfront?
Old 11-23-2008, 07:41 PM   #8
djremix's Avatar
Temporarily...lol
Old 11-23-2008, 07:50 PM   #9
llorracs93s10's Avatar
with the shocks relocated there, theere will be on issues of clearnace for the wheels like 20s would there?
Old 11-23-2008, 09:30 PM   #10
djremix's Avatar
Probably with large wheels there might be issues but I'll be running my stock wheels...I like them!
Old 11-23-2008, 09:31 PM   #11
djremix's Avatar
I'll weld a plate on there when I get a chance but I've been working on this the last 2 days in 25-30 degree weather... so I'll leave the welding for next spring!
Old 04-05-2009, 05:40 PM   #12
djremix's Avatar
OK so now that nice weather is back, I started back on this project...
So far what I did...
Install dehumped lowers that I spent A LOT of time smoothing and painting (courtesy of Kris Dye Fabrication)
Lowered it and tested to see what I would need to cut on the inside so removed the front end and one fender so far...
...and the I cut the inside of the fender...quite a bit. Not sure if it will be enough yet cause I am hitting my heater box now so I have to say bye-bye to my AC and heat...sucks!
I am basically redoing my brakes again...I got some drilled and slotted rotors that I painted to match my spindles and control arms and also painted my sway bar...I know I'm OCD!
These are my latest updates...stay tuned!
There are more pictures here... http://s202.photobucket.com/albums/aa278/djalain1
Old 04-06-2009, 12:44 AM   #13
PHAT JOE
blazerida88's Avatar
looks like a good start, that whole trailer fender is not gonna fit in ur fender without hitting the firewall when u go to install it.
and u dont have to lose ur a/c and heat, just mod ur blower box.
do a search
Old 04-06-2009, 12:51 AM   #14
dtilley86's Avatar
whats with the lower control arms?
Old 04-06-2009, 12:52 AM   #15
where's my chippy?
lee-mill's Avatar
mhm finally nice pics of shock install thanks man
Old 04-06-2009, 10:47 AM   #16
djremix's Avatar
What do you mean about the control arms??? Why did you post them in the hacked thread? Ask Kris Dye about the arms, he made them...they work, they're just not modded to look alike. Sorry if I'm a little OCD. I like my shit to look good as well as function right!
Old 04-06-2009, 10:48 AM   #17
djremix's Avatar
Thanks, not fully up and running but as soon as I'm done with fenders and heater box, it'll be on the ground, hoping in the next couple weeks. Unfortunately I work outside and I don't have a lot of time to work on it. I will update as soon as I get updates!
Old 04-06-2009, 05:03 PM   #18
dtilley86's Avatar
they dont seem right to me
Old 04-06-2009, 06:23 PM   #19
djremix's Avatar
Read the hacked thread that you posted my arms in...I said what I wanted about the control arms...done! They work and that's it!
Old 04-09-2009, 06:54 PM   #20
djremix's Avatar
Today was a nice day to work outside so I took the truck apart, hood and fenders are now off...
Took heater box off...was thinking of taking it out and keeping it out but my heat and AC work perfectly so...
...I'll mod the heater box instead...
Old 04-09-2009, 07:02 PM   #21
djremix's Avatar
So after the heater box was off I lifted the tire up with a jack under control arm to see how high it would go and if it would lay skid but not quite, missing about one inch (that's with no weight on the tires, on the ground) something is preventing it from lifting higher, the truck is lifting up instead. I think my upper ball joint is binding...WHAT DO YOU THINK?
Old 04-09-2009, 07:20 PM   #22
djremix's Avatar
Oh and I'm running 225/60/16 on stock wheels if it makes a difference...
Old 04-10-2009, 12:58 AM   #23
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
well the tire calculator says that tire is 26.6 tall.
thats about a 20 with a 245 35 20 tire.
usually anything over 25'' binds the upper balljoints.
Old 04-10-2009, 01:02 AM   #24
MODERATOR
first things to check is
tie rod hitting frame, notch for them
lower control arm hitting frame anywhere,you have to trim frame where the control arms slide into the frame.
take the bags and cups out, might have to trim cups down.
if all that dont get it laid out, you need to get pie cut upper arms or get tubulars
Old 04-10-2009, 01:03 AM   #25
tohoopty's Avatar
your ball joints are in wrong and turn your drivers side tire rod adjuster down a little bit
Old 04-10-2009, 07:46 AM   #26
_
GET_LOW's Avatar
They look like there in right unno:
Looks like those joints are pretty new. If you wanted you could get some Power Performance joints and see if those work. They have a lot more range then stock ones do.
Old 04-10-2009, 03:40 PM   #27
djremix's Avatar
Everything under there is new including Ball joints, tie rod ends, brake pads, rotors, calipers, lower arms, shock, drop spindle,... can't mess up an upper ball joint it can only go in one way! and I still need to tighten everything down tight after I check all fitments and clearances...
Old 04-10-2009, 03:43 PM   #28
djremix's Avatar
Can you send me some? After all these new parts I have very little cash. I'm not spending another $80 on new ball joints. Can anyone sponsor them for me??? LOL
Old 04-10-2009, 03:47 PM   #29
djremix's Avatar
I checked all those clearances already and nothing is rubbing or touching anywhere. Maybe if I put the truck right on the ground and lower it that way with all the weight on the tires, might go all the way down...worth a shot, if not then looks like I'll get tubular uppers! Thanks Kris!
Old 04-10-2009, 03:51 PM   #30
djremix's Avatar
So I had a few minutes this morning and I plated my heater box...should be good enough. Blower is about 1/4" from plate can't cut anymore. Sorry about the crappy camera phone pic. Will update again soon!
Old 04-10-2009, 05:40 PM   #31
MODERATOR
double check the most tricky part of laying out the front of a s10.
right where the control arms slide into the frame. you will have to trim down the lip that will hit the lower control arm.
you cant see it that good until you jack the control arm up very close to the frame.
Old 04-10-2009, 09:38 PM   #32
djremix's Avatar
I checked that too and it's not even close to hitting that...I'm 99% sure it's the ball joint at this point. I spent a good deal of time checking and it's the same on both sides... Tubular arms are on my wish list...
Guys what do you recommend for good and resonably priced tubular upper control arms?
Old 04-10-2009, 09:55 PM   #33
_
GET_LOW's Avatar
SD upper arms. Raw with no BJ or cross shaft are 200 bucks. A pretty good deal. You can mod the uppers really easy. Atleast try, its not liek its gonna cost ya any money.
Old 04-10-2009, 10:12 PM   #34
Tuckin15's's Avatar
i really like how you did your arms!
Old 04-10-2009, 10:22 PM   #35
_
GET_LOW's Avatar
He just painted them dumb ass. Kris Dye cut them up.
Old 04-10-2009, 10:35 PM   #36
square bodies ftw
cruisinlows10's Avatar
I am running 225-55-16s and I had to beat back the top of the wheel arch in the cab for tire clearance. That may be holding you up on yours as well.
Old 04-10-2009, 11:02 PM   #37
djremix's Avatar
Here are a couple more pix of heater box... about 1.5" til tire hits heater box.
This is as high as it goes and starts binding...tires don't rub anywhere, arms are not hitting anywhere, tie rods are close to frame but don't hit (I can put my hand between tie rod and frame)... Just ordered SD uppers, see if that helps!
Old 04-10-2009, 11:04 PM   #38
djremix's Avatar
Thanks...yeah I just smoothed them out and painted them...
Old 04-10-2009, 11:13 PM   #39
djremix's Avatar
Old 04-11-2009, 12:00 AM   #40
_
GET_LOW's Avatar
I would just run it over the top of the blower motor. That should have a good amount of slack in it. I think it comes off the ignition and some wires that go across the back of the tranny.
If you go on the inside on the passenger side. Under the glove box there is a pannel down by your foot area. There is like 4 7mm bolts that hold it in. un screw em and the pannel shoud drop out. There are 2 big connectors that plug into a CPU. Un plug them and the you can feed the wire out of the cab. You could cut each wire and lengthen them if you wanted.
Old 04-18-2009, 09:30 AM   #41
Yup Im his Bitch
DimePrincess's Avatar
Looks great. Working on mine now. Already took TONS of stuff out. Plenty of room. On stock tires for now. Nothin hits. At least you can work on yours in your yard. lol Neighbors dont like it here.
Old 04-18-2009, 10:19 AM   #42
^^^ PUSSY MAGNET ^^^
Gimp's Avatar
first off nice build so far man, and 2nd i really like how instead of just putting down a little paint where you cut out your pockets you did the whole portion of the frame. spend a little extra time and things look that much better. Nice job!!
ok last where did you get your bolt on shock brace. I like them and I'd like to pick them up too
Old 04-18-2009, 11:33 AM   #43
djremix's Avatar
I got my shock relocators from suicidedoors.com
http://www.suicidedoors.com/shock-re...t-shock-mounts
and you'll need the shock studs too if you relocate your shocks on the side of your control arms
http://www.suicidedoors.com/shock-re...ck-stud-button
and the stock shocks won't work either, I used Nissan Hardbody shocks don't remember what year
Old 04-18-2009, 11:36 AM   #44
djremix's Avatar
I got some progress done yesterday too...I finally got all my wiring and plumbing done for my air management. I was able to fire everything up and hear the ever popular sounds....PSSSTTTT PSHHHHHHHH...
I have major air leaks at the tank where I have a couple plugs. Need to get that resolved and check all other fittings for leaks I can't hear...
WHAT DO YOU GUYS USE TO SEAL YOUR FITTINGS?
I HEARD TEFLON TAPE TO PASTE TO LOC-TITE TO PERMATEX THREAD SEALER...
WHICH WORKS BEST???
Old 04-18-2009, 12:07 PM   #45
where's my chippy?
lee-mill's Avatar
what kinda metal did u use for the box? and did u just rivet it into the plastic houseing
Old 04-18-2009, 12:31 PM   #46
djremix's Avatar
I just used 22GA sheetmetal, made some cardboard templates, cut the sheetmetal and riveted to the plastic stock housing. I still need to seal everything up with caulking and rust proofer inside and out. I'm just waiting for my upper arms to get here to lay my truck out, make sure it doesn't hit the heater box.
Old 04-18-2009, 02:38 PM   #47
Resident Alcoholic
dimebaggedmofo's Avatar
looks great man, reminds me of the days when i bagged mine!
Old 04-18-2009, 04:10 PM   #48
where's my chippy?
lee-mill's Avatar
ok cool man thanks and one more question how did u cut the blower box with like a dremel?
Old 04-18-2009, 04:12 PM   #49
djremix's Avatar
I wasted no time...sawzall
Old 04-18-2009, 04:21 PM   #50
djremix's Avatar
Here's what I did today. I fixed a couple air leaks on my tank and one's still leaking a bit but I'm too worried cause that's where my fitting for gauge will go.
I took the truck off jack stands and filled the bags...
Aired out...
Don't mind the oily, dirty undercarriage, the kid that had it before me drove around with a leaking oil pan and was leaking from the front of the engine and the fan would blow oil all over the place...getting cleaned as we speak!
