Out of balance driveshaft/wrong pinion angle? - S-10 Forum
post #1 of 21 Old 09-06-2006, 08:52 PM Thread Starter
PinkNoma's Avatar
User is: PinkNoma is offline
Send a message via AIM to PinkNoma
Can anybody tell me the symptoms of these two? I'm trying to figure out what's up with my truck. I have a slight vibration in the gas pedal when I accelerate down hills and while I'm coasting, also if I take it on the highway and go like 70mph.
When we bagged it we set the pinion angle to the equal and opposite angle of the trans. I also had to have my driveshaft shortened and rebalanced. So the vibration is probably from one of these.
Thanks.
PinkNoma is offline
post #2 of 21 Old 09-06-2006, 09:22 PM
User is: Slammed03 is offline
Re: Out of balance driveshaft/wrong pinion angle?
Thanks.
i have the same problem...i'm havin my driveshaft balanced as we speak..you said you had it reblanced though. if it has been reblanced then that should be the problem...then again i donno cause i'm having the same problem and cant figure it out...whtas you pinion angel look like???pic?..when i get my shaft back i will let you know if the vibration stops
post #3 of 21 Old 09-07-2006, 12:43 AM
Hola Bitches
Myst's Avatar
User is: Myst is offline
Thanks.
same thing with mine and I have had mine shortened ..and get the same vibration and almost when you let go of the gas it sounds like grinding ...but its not ...weird
Im selling my truck ...ask me about it!!
DJ Mystery Meat ....
Myst is offline
post #4 of 21 Old 09-07-2006, 12:52 AM
rmrider's Avatar
User is: rmrider is offline
what rear setups are you guys running? pinknoma has the 5 link on a reg cab, you other 2?
rmrider is offline
post #5 of 21 Old 09-07-2006, 12:52 AM
Blacknoma's Avatar
User is: Blacknoma is offline
Send a message via AIM to Blacknoma
i have the same problem and haven't found a solution
edit: i'm running a 5-link on an ext cab
post #6 of 21 Old 09-07-2006, 12:53 AM
Hola Bitches
Myst's Avatar
Im running a SD 3 Link ...REG. Cab
Myst is offline
post #7 of 21 Old 09-07-2006, 01:01 AM
FUCK YOU
Wicked Mayhem's Avatar
mine has a slight vibratin only when i take off.. i dont care though..
Wicked Mayhem is offline
post #8 of 21 Old 09-07-2006, 08:23 AM Thread Starter
PinkNoma's Avatar
Hmm... I think I might mellow out my pinion angle by a half turn of my forward link bars this weekend. See if that does anything.
PinkNoma is offline
post #9 of 21 Old 09-07-2006, 01:46 PM
twanc
Twanc's Avatar
User is: Twanc is offline
i have the same prob on a 84 ext cab (small vibration while taking off) I'm thinking it is the pinion angle. Im going to align it at work tonight and i will let u know.
Im a FORD tech
Twanc is offline
post #10 of 21 Old 09-07-2006, 04:01 PM
thepunkerguy's Avatar
User is: thepunkerguy is offline
I have the same kinda thing, except mine is mainly on take off. On take off i get a bad chadder, shimmy, whatever ya wanna call it, my gear shift bounces all over the place, IT SUCKS. I have been battling it for 1.5years now trying to get it fixed. I even did all the fancy math and got my 2 u-joints to mathmatically phase properly with the angles and that didnt help either. It goes away when i air the truck all the way up so i know it has to do with the angles, i dont even know what kind of shop would know how to fix it.. it really sucks. I had my whole shaft re-tubed and balance already becasue i thought that was it, it wasnt. I took it toa shop called "Driveline" and they blammed it on my super pivot joints.. which it isnt.. so lame. It could also be becase mine is a Ext. cab, V6. 5 Speed with the single u joints / 2 piece drive shaft. My buddy has the same driveline setup as me and his does it to... what a pain in the neck... i wish i could fix mine.. you arent alone!!!!
- Mike
- Mike
post #11 of 21 Old 09-07-2006, 06:57 PM
User is: DVDA_007 is offline
i have the same thing. i thinks its related to the pinion angle tho. when im doin like 70 mph and i let go of the gas i get the lil 'grinding' type noise also. it did it when it was static dropped too so idk what it actually is.
Http://www.streetsourcemag.com/Profile.aspx?profileid=38717
DVDA_007 is offline
post #12 of 21 Old 09-07-2006, 07:00 PM
***1987 LSX S10***
SoLowXtreme's Avatar
User is: SoLowXtreme is offline
Send a message via AIM to SoLowXtreme
a ride height u guys should have the pinion set to like -2or3 degrees
post #13 of 21 Old 09-08-2006, 12:54 AM
Hola Bitches
Myst's Avatar
yea more often than not I dont drive usually ever at ride height ..lol...so I think it has something to do with a bagged truck that I drive and its gonna have kinks ...
Myst is offline
post #14 of 21 Old 09-09-2006, 02:22 PM
Bagged
chevy power's Avatar
User is: chevy power is offline
Send a message via AIM to chevy power
Do you guys with extened cabs have you carrier bearing shimmed? It helped a lot on mine.
post #15 of 21 Old 09-10-2006, 02:46 PM
radarblue95's Avatar
User is: radarblue95 is offline
mine does this on take off when i run the rear below 40 psi i get the knocking shimmy noise and feel the vibration it will do it at 35 psi but not at 40 im gonna say its pinion angle i have adjusted my bars out 5 turns with no help i am runnin the 5 link regular cab
post #16 of 21 Old 09-10-2006, 03:16 PM
Anybody got 20's?
Bdydrp02s10's Avatar
User is: Bdydrp02s10 is offline
Send a message via AIM to Bdydrp02s10
It would help alot if you shim the tranny and carrier bearing up. I did that to mine and it helped alot.
Sold to my younger brother. 2002 ext. cab S-dime Getting rebagged with 20s. http://www.cardomain.com/ride/769386/1
2006 ext. cab GMC Sierra VortecMax. Stock. Fully Loaded. http://www.cardomain.com/ride/2932266
post #17 of 21 Old 09-23-2006, 04:40 PM Thread Starter
PinkNoma's Avatar
I just got around to working on my truck (been working 6 day weeks). I lengthened my forward bars half a turn. It seems to have helped a lot. My pinion angle now sits between 3º-3 1/2º. I need to go drive it down a hill though. That was when it was worst. But right now it seems pretty good.
PinkNoma is offline
post #18 of 21 Old 09-23-2006, 06:03 PM
User is: JMikeson is offline
Why?
JMikeson is offline
post #19 of 21 Old 09-23-2006, 06:20 PM
KentuckyMinis.com
Slammed83Mazda's Avatar
User is: Slammed83Mazda is offline
Send a message via AIM to Slammed83Mazda
its pretty common to get some what of a vibration with any link setup its just normal really...
My buddy got_u_sick has the sd.com wishbone 3 link, and he gets some what of a vibration but its just normal...
Nick
| D.I.P. Fred "Pinky" Browne '80-'06 | D.I.P. Ed Boley '80-'07 |
http://www.KentuckyMinis.com Get with it, or get ran over.
http://www.facebook.com/dwp101 Quality coverage, Quality images.
post #20 of 21 Old 09-23-2006, 06:48 PM
The Der
User is: dernoma is offline
Send a message via AIM to dernoma
- Mike
mike i am having the same problem as you wiht my new truck sd 3 link 5 speed 4.3
- Mike -
MIA
Florida Truck Scene
dernoma is offline
post #21 of 21 Old 09-24-2006, 12:02 AM
seekndestroy's Avatar
User is: seekndestroy is offline
its deffinitly the pinion angle get it set right at your ride height and you wont have a problem.I have the same problem on my truck that I just finished baggin a couple of days ago I have to adjust my bars I have a KP, I also had the same problem on my lifted chevy the whole coasting down hills thing and getting on the gasvibration and grinding. What happens is your driveshaft angles are different at your pinion and transmission and what happens is they fight eachother and bind causing the grinding sound and vibration fix it or youll be going through pinion bearings from the vibration it will screw them up pretty bad not to mention your transmission too.
I want to get a midget they store easily in a suitcase to f@ck
