OASIS FACTS and info.
Old 04-21-2005, 06:28 PM   #1
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
This will be the start of more to come.
1. THERMAL CUT-OFF SWITCH - Protects motor by turning unit off when motor gets too hot. Resets automatically.
2. CONTROL WIRE - Connection point for pressure switch or dash switch.
3. LOW VOLTAGE CUT-OFF - “Smart” technology turns compressor off if voltage drops to protect motor.
4. LOW VOLTAGE INDICATOR - Alerts when voltage is low.
5. HIGH FLOW - Swedish Steel valves.
6. AIR FILTER- HD filter with replaceable element.
7. COMPRESSED AIR OUTLET - Connects to air hose. Can be rotated 360°.
8. YORK COMPRESSOR - Twin cylinder. 10 cubic inch High-Output unit.
9. HD ROLLER BEARINGS - at both ends of crank shaft.
10. CRANK CASE BREATHER - Bronze filter is easily removed to check oil level.
11. MOUNTING PLATE - Steel housing designed for easy bolt-on installation.
12. HEAVY-DUTY COUPLER - Provides a direct drive connection.
13. 5 HP MOTOR - modified winch motor runs on 12v or 24v DC.
14. POWER CABLES -10’ of #4 AWG cables.
INSTALLATION TIPS
Oasis compressors have a small ‘foot print’ and can be mounted almost anywhere, in a truck bed... in a ventilated trunk... in a storage compartment of a utility truck... under a service truck... on the front bumper of an off road vehicle... or on a detachable mount. There are several factors that must be considered in every installation:
Checking oil with the dipstick provided.
Adding oil through the vent fitting using the cap as a funnel.
1. Ventilation. The Oasis will get hot! It must be located in an area where it will get airflow.
2. Service Access. Mount the compressor in an area where it will be easy to check the oil and replace the filter element.
3. Mount to a sturdy surface. If you are off roading or working on a construction site, your vehicle takes a beating. Make sure the compressor base plate is bolted to the vehicle frame or a sturdy bracket.
4. Make a good battery connection. The Oasis compressor comes with special battery cables. They must be connected directly to clean battery posts. Route the cables carefully so that the insulation does not rub against body or frame member. Use rubber grommets when passing through metal panels.
5. Under vehicle installation. You will need to fabricate a ‘splash guard’ to protect the compressor from road debris, mud and dirt.
Oasis offers several installation packages for most popular applications. However, you may wish to configure a custom set-up to meet your specific needs. Oasis stocks all necessary components to build your own system.
THE HP1000™ Duty Cycle 30% @ 12vdc
THE HP2000™ Duty Cycle 90% @ 12vdc
Old 04-22-2005, 07:07 AM   #2
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Re: OASIS FACTS and info.
Old 05-06-2005, 04:05 PM   #3
ThorRacing01's Avatar
how much do thses run normally? and is there a big differance between the xd and hp??
Old 05-06-2005, 04:11 PM   #4
LayinSdime's Avatar
i knew all that it comes with the compressor when you buy it!!! DJ u are way better then copy and paste show me your skillz with this thing too
Old 10-03-2005, 11:02 PM   #5
Beer, Bait and Ammo
MoneyMike's Avatar
how much does it wiegh?
Old 10-04-2005, 01:44 AM   #6
sawzall's are cool
ohsolos10's Avatar
ALOT the 2000 is one heavy bietch i would say over 40lbs
Old 10-04-2005, 01:53 PM   #7
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I can't wait to get my hands on one to do some testing,
the larger one has a better dutty motor so can run faster and longer, only real difference.
Old 10-04-2005, 02:20 PM   #8
Shipping weight on the hp1000 ia 50lbs and the xd2000 is 70lbs
Old 10-04-2005, 06:07 PM   #9
LowNoma22's Avatar
shit thats heavy lol ill put it on the right side to offset the good ol chevy lean....lol
Old 10-04-2005, 06:20 PM   #10
DRAGGIN187's Avatar
hey remember when you had that chance test the xd 2000, but some retard from New Mexico blew a fuse to his compressor. yeah that is me (Derek). i think the reason why it blew the fuse is because i put a new alternator that weekend and it had a higher amp rating. my fuse was only rated for 100 amps.
Old 10-04-2005, 06:26 PM   #11
DRAGGIN187's Avatar
he is serious, it is no joke. it is one heavy muthafuc*a
Old 10-04-2005, 06:26 PM   #12
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
lol,
hit me up man,
djd@landisusa.com
I still want to get you BOOSTED!!
Old 10-04-2005, 07:14 PM   #13
djdaudio PM with some shipping info, i would like you to test some stuff for me.
Old 10-04-2005, 07:18 PM   #14
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Done
Old 02-12-2006, 09:25 PM   #15
layin body!
s1043's Avatar
I got the xd2000 for my truck i have yet to install it and actually see it in action but it is one heavy bitch full of power... it does weight about 70lbs i plan on puttin mine in the bed... hope it works out!!
