NewB Accuair ?
Old 11-02-2009, 04:33 PM   #1
NewB Accuair ?
I really like the look and simplicity of the accuair manifold valve. My question is: can I use just some simple gauges with it or does it need the high tech (expensive) digital front end to operate it?
Old 11-02-2009, 04:56 PM   #2
B JELUS
GET_LOW's Avatar
Re: NewB Accuair ?
yup, just plumb it correctly.
Old 11-02-2009, 05:02 PM   #3
fmylife.com
LOW S-10's Avatar
Re: NewB Accuair ?
They sell the manifold seperate.... No gauges are needed if you use their ride control.
Old 11-02-2009, 05:17 PM   #4
Re: NewB Accuair ?
I cant seem to find the ride control on SD. All I see is the e-level gear. I'm not looking to spend a ton of cash and would almost rather have the classic look of gauges. Can you give me a link? Thanks.
Old 11-02-2009, 06:08 PM   #5
fmylife.com
LOW S-10's Avatar
Re: NewB Accuair ?
http://avsontheweb.com/product.php?p...cat=511&page=1
Old 11-02-2009, 06:14 PM   #6
Re: NewB Accuair ?
So where do the pressure lines going to the gauges exit the manifold, or is it set up for digital gauges only?
Also, can and how can I get automatic level setting using this unit.
Sorry for all the questions, I'm fairly new to all this and have not found any local resources.
Old 11-02-2009, 06:20 PM   #7
Patawick's Avatar
Re: NewB Accuair ?
you could get a union where you splice the line filling the bags
Old 11-02-2009, 06:33 PM   #8
fmylife.com
LOW S-10's Avatar
Re: NewB Accuair ?
^^^ Yep.
Old 11-03-2009, 09:56 PM   #9
Re: NewB Accuair ?
these set-ups arnt designed to use gauges. what im doing is a using a union with a gauge port im using digital gauges but connect the same as normal manuel gauges. the manifold is designed for thier height based system not pressure based system.
Old 11-04-2009, 12:22 PM   #10
Useless posting member
Wrkn prgs's Avatar
Re: NewB Accuair ?
Old 11-04-2009, 09:15 PM   #11
Patawick's Avatar
Re: NewB Accuair ?
yep, thats what i was talking bout ^^ Ive got a set for my front bags and never had a problem with em. they only come in 1/2 like that tho
Page generated in 0.57555 seconds with 31 queries
[Output: 73.23 Kb. compressed to 68.39 Kb. by saving 4.83 Kb. (6.60%)]
