fmylife.com
My Redesigned S10 Front Suspension
![]() ![]() Last edited by droppedss : 07-16-2009 at 08:27 AM. |
KZELIMINATOR
re: My Redesigned S10 Front Suspension
sweet bigger rims
umm yea
um crazy... are these gunna be for sale?
30's on a dime that would be sic .. especially if it still layed out.
fmylife.com
Ya, they are Uniball drop spindles. Shoot him an email:
biokustumz@hotmail.com |
how are s10 arms going to bolt to that
♠ Camber'd ♠
OBS FSC
S - I - C
umm yea
haha i was gunna say " you have to include the tire in that diameter"
...and he says hes making arms to go with them |
stock sucks
2500...ouch.
Max builds awesome stuff. But it is not cheap. But it will be right and do everything he claims it will.
Hoods are overrated
looks like a tig welded leaf spring shackle with a hub on the back side.
he does some awesome work, but 30" tires laid out? that's just pushin it a little too far IMO. a little more cutting and i can lay out on 29" tall tires with stock arms and still clear the fenders aired up. I'm sittin on 28.5" tires and clear the fenders by 1" right now. It just gets old though, because with larger diameter comes more width in the wheels/tires. And with that shit no matter what you do your turning radius sucks even when aired all the way up and there's not really anything you can do about it. Last edited by sadexcuse4s10 : 03-01-2009 at 06:56 PM. |
started as a 4X4 anyway
Am I the only one wondering why on these? I don't know about a second gen but my first gen Jimmy lays frame with a 29" tall tire on stock spindles and unmodified tubular control arms. Nothing is binding, with 2" drop spindles I can easily lay 31" tires (but couldn't run a hood because of the bodydrop)
Hoods are overrated
show me the BD jimmy with 29" tires man if you're runnin them. My tires come through the hood on my '86 by nearly 2"
Ask and thow shalt recieve. Give min a min to go snap some. I am in the middle of the BD now. I am laying rocker and 29" tires just kiss the hood.
Max does do some sick work....Another advantage to these spindles is the lift...it's almost limitless. There's no way for the upper or lower BJ to bind....onlything limiting you will be the bag itself....mount it far under the frame and you could easily get 15+ inches of travel. Also depends on what he uses for a tie rod end.....I wanna build a set like that for my Dodge but it's just not worth it right now....I clear my 24's by an inch and have more than plenty of room for turning as I can turn lock to lock a coulpe inches off the ground. Max does do sick work though...
Pics are uploading now. I can't find my cable for my digital so they were taken on my blackberry, I have no clue how good they will look.
fmylife.com
Wow, tough crowd....
Man, I am not knocking your work or your products. I fab almost all my own parts, I know what goes into these things. All trucks are not built alike, everyone has their own outlook on what the finished truck will be, and how to get it there.
And here we go. Pics don't look that bad. Keep in mind, I am working on it right now so my garage is filthy. Tires are 235/75-15, 28.9" tall. Stock spindles.
sick & twisted
max is my hero.
fmylife.com
#24 |
SFBD 4 door
Location: Columbia, Tenakey Location: Tupelo, Ms User is: OffLine |
damn another 4 door bodydrop lol.
ill be running a 22 on my blazer 255/35/22 i might even drop to a 255/30/22 and try my hardest to keep a stock hood that spindle looks good but i gotta see the arms with it |
#25 |
Registered Adventurer
#26 |
Hoods are overrated
with that much camber on that blazer you'd have to air it all the way up to drive it without eating the tires up quicker than the dollar menu
here's a 29" tire laid out, nearly tucks a lug, and hangs out of the fender about 2". when aired up 2" i have 2 degrees of camber and it tracks straight as an arrow ![]() i'd never use stock spindles on something laid out with wheels that big Last edited by sadexcuse4s10 : 03-01-2009 at 07:49 PM. |
#27 |
blazer is dunnnnnnnnn!
i dont get it
![]() you can lay out on 22's with 2" drop spindles. why would you wanna run anything bigger than that on a minitruck? yea, i know about the truck little shop did on the 24's, but that is pushing it. the hood is trimmed on that one, and it's only laying frame. but still, it's on 2" drop spindles. why would you need these? |
#28 |
Hoods are overrated
not trying to start some shit but you should really get some drop spindles on that thing if you want to drive it and have it perform well without having to ride sky high all the time
#29 |
Laid out, camber is 16 degrees. In order to bring it to 3 degrees my ride hight will be 5 inches off the deck. I have drop spindles and I might end up running them, I like to ride low, but I will jump off that bridge when I get there. My goal right now is 255/35-22's, RE8s up front, RE7s in the rear, bag on bar, bodydrop, and keep the rear seat in the factory location. So far I have all bases covered.
#30 |
Hoods are overrated
good luck with it man, i'm runnin 255/30/22 and there's no way they'll fit under the hood
#31 |
Bob Saget bitch!
Someone recently asked me about doing an S10 on 24s, and this was the first thing I thought of. I toyed with this idea recently when asked about it. I said the only way I would build S10 arms is if I also built spindles with vertical mounted uni-balls, and I wanted to build a custom drag link and tie rods to help. I had a feeling I would receive a response much the same as the one in this thread. No one wants to spend $3k on their front suspension when they can do it for less than half and achieve "acceptable" results. I am starting to believe minitrucks are not a good market to try to push the envelope anymore, because of threads like this. Last edited by Twisted Minis : 03-01-2009 at 08:03 PM. |
#32 |
A 255/35-22 is the exact same size as whats on mine now, clears no problem. I figured you were doored but your not. I don't know why ours would differ that much.
#33 |
#34 |
In a way it does, but the only way to correctly put the front suspension in an ideal range of motion on a lowered truck is to make new arms, spindles, AND reposition the upper and lower control arm mounts on the frame.
#35 |
fmylife.com
TwistedMinis, your last two lines summed it all up for me... |
#36 |
Bob Saget bitch!
Thanks Low S-10. People like you still give me hope for the things I want to do in the future.
#37 |
fmylife.com
I want to build something different... Let's face it, I could have gone to Suicide Doors and spent $1000 and been set. There's nothing wrong with that. It works! But I'm building this truck to be a little different. Granted, it is an S10 lol, but it's mine!!!
#38 |
Pushing the envelope is what this lifestyle is all about. I understand how suspension systems work but unfortunatly when trying to lay the frame on the ground and keep perfect suspension geometry at the same time it is not going to happen.
I give credit to anyone taking steps to keep the custom aspect in "custom motorsports" There are entirely too many companies out there just making things easy to do. To each is own. If you want to bolt it on, bolt it on. If you want to fab it yourself then feel free. But to spend 2500 on a front suspension just to get 1.5" lower is beyond me. |
#39 |
Demotte4x4, Im not trying to be a dick but you will get a rude awakening when you actually have a 255/25-22 on there! a tire that size tipped 13° will easily be 2" taller than its original diameter due to the fact that its much more squared off than the tire you have now.
As for the real topic of this thread, they are a very nice product and a good idea but certainly not practical for the everyday minitrucker. However the everyday minitrucker wouldnt be running a 30" tall tire anyway ![]() |
#40 |
Hoods are overrated
those baloon tires you have on there will squish down a shitload more than mine with a sidewall like 2.5" tall |
#41 |
Believe me, I know that's coming. I have a little bit of room to spare now but with the drop spindles I think I will clear. Not that it matters right now anyway, my motor sticks above the hood three inches. Hell, the ac pump is over the hood line.
#42 |
Bob Saget bitch!
For stock suspension, 84-95 Toyota suspension is a good starting point. Drop spindles and control arms on 18s and you have great geometry throughout travel. Any bigger wheel wise, well I have ideas on a spindle for that, but I am unsure I will proceed with it. |
#43 |
Honest Abe's Fab Shoppe
stock spindle, 255/35/20 ![]() ![]() |
#44 |
I love the camber man, looks good. That's a damn good fit there. Keeping stock spindles on it?
#45 |
*BUILT NOT BOUGHT*
my silverado has all stock suspension on a 24 with a healthy tire and its cambers alotttttt
i have driven the truck and it seems fine when aired up (seth gave some ideas on the steering) which i re did with rod ends so it doesnt bind anymore but i do plan on redoing the arms for less camber sometime this summer ... ![]() |
#46 |
Bob Saget bitch!
That's right, what did you end up doing for steering to get it all to work?
#47 |
*BUILT NOT BOUGHT*
i put stock spindles back on (fter i cut a set up trying to do something i wasnt understanding in the first place)
removed the stock tie rods from the rack and just built my own with rodends on both sides everything in the stock location just no binding ... |
#48 |
What y'all watchin HOES!?
What Max has told me is that with this front setup drivability will ultimately be much better on a larger diameter wheel. Driving on a 22 will be so much nicer than the changed geometry of any other tubular arm, and the larger dropped spindle will do exactly what everyone has said already. I'm excited to get a set, since I will be on 22's laying frame, and will be driving it to long distance shows and around town as a daily driver.
I don't want to put my 22's on, say "Damn that looks good! But I hate the way it drives now" I put my faith in Max, and will be one of the 1st people to have a suspension like this, so if it works amazing... cool! If it doesn't deliver, oh well... lesson learned by Me for You. I have no doubts that Max will pull through though, and have another quality product designed the RIGHT way. |
#49 |
Many people are saying they don't see the point in paying that much $$$ for a set of spindles....just imagine driving your Bodied S10 on 22's....2 inches off the ground to a show several hours away....during that ride there is no horrible bumpsteer....there is no abnormal tire wear....and you don't have to lift to change lanes....how nice would that be. Take it from someone who experiences that everyday....it's worth every penny you would spend on them spindles. I don't think Max would go through the trouble of making them unless they were a huge improvement over what is currently on the market.....Yo Seth yall still making it to Tex Mex
#50 |
Hoods are overrated
you can do that with 2" drop spindles, you don't need 3 1/2" or anything special like that
i used to do that with my s10 bodied on 22's. It will switch lanes on the highway lifted a few inches with 2" spindles and stock arms |
