My bagged and bodydropped 92 s10 blazer thread - Page 2 - S-10 Forum
post #51 of 86 Old 03-11-2005, 10:41 PM Thread Starter
Banned
User is: bradcarney is offline
Send a message via MSN to bradcarney Send a message via Yahoo to bradcarney
Re: My bagged and bodydropped 92 s10 blazer thread
thanks guys i have a idea for the back. i was thinkn about fabbin some bag bracket like jason's for beihnd the axlebut putting them in front and cutting my upper bag bracket off thats on the now and cutting it so the frame slides onto it somewhere before it levels off on to be the top of the c-notch. this pic should give you an idea of what i mean...somewhere in there maybe lower and maybe higher. that way i could leave me lower bars where they are and then just have to make upper bars and get one of jason;s diff bracket. what do you think? also here is what im talking about for the lower brackets............sorry for the pics i suck at using paint but this might give you an idea...and i alreadt know i will have to gusset the shit of everything
post #52 of 86 Old 03-17-2005, 01:01 AM Thread Starter
Banned
alright guys i need some help, i cant seem to get the front end of my frame to lay out completely on the ground...ive notched the a arms where they were hitting and the tierods arent hitting...what should i do? its almost laying out but almost only counts for horseshoes and hand genades. Any suggestions would be great...im gonna buy some byc arms here sometime but i dont know if this will fix my problem or not
post #53 of 86 Old 03-17-2005, 07:28 AM
bitch
LaynLo's Avatar
User is: LaynLo is offline
Send a message via AIM to LaynLo
did you cut the humps off the lower control arms?
Yea my trucks got a few mods
97 std cab S10 4.3 AKA The bodydrop
LaynLo is offline
post #54 of 86 Old 03-17-2005, 09:15 AM
F**K STOCK
themostoriganal's Avatar
User is: themostoriganal is offline
Send a message via AIM to themostoriganal
if you run your upper link bars outwards towards that part in the frame where it goes up for the notch (like in the pic you posted) then your upper link bars are gonna have to be really short which would probably cause a pretty big pinion angle change, i would mount the bars to the that cross member in front of the notches and use one of jasons differential brackets. by looking at the pictures i think that youll be fine if you mount the bags on the lower arms as long as the bag doesnt rub the frame when compressed
if the control arms are not bottoming out anywhere and the tie rod ends have clearence then the only other thing would be the upper bag cups
NEW 3X3 CENTER FRAME RAILS, SHEETMETAL CAB FLOORS, BUILT SMALL BLOCK, A FULLY GLASSED INTERIOR, AND LAYIN BODY OVER 22S..................IN PROGRESS
post #55 of 86 Old 03-17-2005, 11:52 AM
2legit2quit
iLLblazer's Avatar
User is: iLLblazer is offline
check the lower control arm mounts, and the tie rods. if the back is on the ground, the front crossmember will not lay though, because the frame flaatens out at a lower point then the front crossmember. lift the rear a bit to get the back frame of f the ground and see if the crossmember lays...but if the firewall back section is already on the ground, the crossmember won't be.
post #56 of 86 Old 03-17-2005, 02:06 PM Thread Starter
Banned
Ok The Cross Member Is On The Ground...the Front That Is...isnt There A Way To Make The Front Of The Frame Lay Out? This Is Pissing Me Off I Thought I Was Done With The Front But I Guess Not....thanks For The Help Themostoriginal I Think Im Gonna Take Your Advice And Do That...also Im Gonna Mount The Bags Far Enough From The Frame So They Dont Rub....any More Suggestions On The Front?
post #57 of 86 Old 03-17-2005, 02:22 PM
cab
I <3 SPARKS
cab's Avatar
User is: cab is offline
Send a message via AIM to cab
the skid plate is on the ground?
cab is offline
post #58 of 86 Old 03-17-2005, 04:17 PM
Some Day
96dragginSdime's Avatar
User is: 96dragginSdime is offline
Send a message via AIM to 96dragginSdime
balljoints binding?
Trucks for sale!!!!!!!!
post #59 of 86 Old 03-17-2005, 07:50 PM Thread Starter
Banned
yea i think it is the ball joints...only way to fix that would be new a arms right?
post #60 of 86 Old 03-17-2005, 07:55 PM
cab
I <3 SPARKS
cab's Avatar
no you could cut and angle the ballljoints..
cab is offline
post #61 of 86 Old 03-18-2005, 12:33 AM Thread Starter
Banned
that is true i think i might just wait till i get some arms in about a month or so...i dont know im gonna work on it this weekend and try to get the rear done and then figure something out for the front
post #62 of 86 Old 03-18-2005, 11:30 AM
cab
I <3 SPARKS
cab's Avatar
yeah that's what I'd do.. tubular arms are definately the way to go.. not to mention they look better, heh.
cab is offline
post #63 of 86 Old 03-18-2005, 02:36 PM Thread Starter
Banned
yea i know....got the tubing for my upper bars but ddint get to order the brackets and rear end mount for sd today...gonna try and get it ordered on monday and have the rear and front done by next weekend so i can paint the frame and put the body back on..........yea
post #64 of 86 Old 03-22-2005, 01:04 AM Thread Starter
Banned
alright guys got the rear brackets done and welded....also i order all the brackets, rear diff cover, rod ends, bag cups, and the 8pc shock kit for sd today...hopin to get err all done and paint the frame next week....im gonna paint the body flay white, and paint the frame candy green (dupont) and then put some candy green graphic or somethin on the body...then carry it all into the interior...also got the steel the my upper and lower bars...lowers are 2x2x1/4 and uppers are 1.5 schdule 180 with a 1/4 wall. also got my new powder coat machine now all i need is an oven....any ideas with that?
post #65 of 86 Old 03-22-2005, 01:06 AM Thread Starter
Banned
here are the pics sorry
post #66 of 86 Old 03-22-2005, 01:45 AM
cab
I <3 SPARKS
cab's Avatar
looks good
cab is offline
post #67 of 86 Old 03-22-2005, 09:47 AM
F**K STOCK
deff go tubular arms, they look sweet and make the job a lot easier. glad i could help on ideas for the rear setup bro
post #68 of 86 Old 03-22-2005, 11:07 AM Thread Starter
Banned
yea thanks guys i wanna get this bitch done
post #69 of 86 Old 04-04-2005, 02:42 AM Thread Starter
Banned
got all my shit in the other day from sd...but i gotta take some time off working on the truck...drank a 5th and a half of yeager last night...found this dude that egged my truck a couple months back and stole my motorcycle two weeks ago we started fightn i blacked out from a sucker punch and he kick me in the head a good 5 times...im kool and nothin is broke but i can hardly see.....o well he'll get his when i heel up and am not drunk
post #70 of 86 Old 04-04-2005, 09:38 AM
F**K STOCK
lmao, damn bro gettin crazy huh.........fight for getting your truck done not other people! lol
post #71 of 86 Old 04-04-2005, 12:22 PM Thread Starter
Banned
haha yea no shit i havent been in any shit like this for about a year....and the fag is goin to school on a soccer scholorship....kicks kinda week i think....im still here talkin and shit
post #72 of 86 Old 04-04-2005, 02:18 PM
cab
I <3 SPARKS
cab's Avatar
hahahahaha get him!
cab is offline
post #73 of 86 Old 04-25-2005, 01:28 AM Thread Starter
Banned
sup guys...all heeled up from the soccer match that my head played in as the ball...ne wayz been racin every weekend and havent gotten alot done but here are some pics...goin to wyoming tomorrow morning and ill be down there visiting wyotech tell like thursday,.....
post #74 of 86 Old 04-25-2005, 01:48 AM
was brown still down
brown and down's Avatar
User is: brown and down is offline
Send a message via AIM to brown and down
jager > yeager. beat the hell out of that kid. truck looks sick, keep it up.
post #75 of 86 Old 04-25-2005, 05:58 AM
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
User is: Dragginbody is offline
Send a message via AIM to Dragginbody Send a message via Yahoo to Dragginbody
u got knocked the fuccccck out... sorry had to say it.
kris@krisdyefabrication.com
440 258 6600 - kris
post #76 of 86 Old 04-25-2005, 09:28 AM Thread Starter
Banned
na its kool the dude was pretty big...o well im over it i heard he got arrested for kidnapping or some shit
post #77 of 86 Old 04-25-2005, 09:28 AM
cab
I <3 SPARKS
cab's Avatar
you ever woop his ass? lol
sweet tho.
cab is offline
post #78 of 86 Old 04-25-2005, 04:55 PM
cab
I <3 SPARKS
cab's Avatar
oh shit you posted at thesame time i did this morning lol
cab is offline
post #79 of 86 Old 04-25-2005, 06:08 PM Thread Starter
Banned
haha damn....na i havent seen him since that fight and i think he is in jail
post #80 of 86 Old 04-25-2005, 11:53 PM Thread Starter
Banned
will be in laramie tomorrow...woot....gonna check out wyotech and all that...brought my bike with and was hoping to swing by a couple tracks on the way home but it looks like its gonna rain for the rest of the trip so im leavin my trailor at my dad firends house in neb till i come back through...my mom doesnt like driving with a trailor newayz so she is happy...when i get back i plan on hitting it hard as hell to get as much stuff done for s series nats as possible
post #81 of 86 Old 05-14-2005, 08:14 PM Thread Starter
Banned
hey guys here are some pics...been workn like crazy on this thing will have many more tom
post #82 of 86 Old 05-14-2005, 08:16 PM Thread Starter
Banned
some more
post #83 of 86 Old 05-14-2005, 08:28 PM
MR MR MR MIKE's Avatar
User is: MR MR MR MIKE is offline
looking good
post #84 of 86 Old 05-15-2005, 07:23 PM Thread Starter
Banned
here is a couple pics of the rear....pretty much done willl post some more tonight
ID:	71830   Click image for larger version
post #85 of 86 Old 05-16-2005, 01:08 AM Thread Starter
Banned
here is everything i got done tonight...rear is completely welded and most of it so off with a coat of primer and paint already here are the finished pics tell me what you think
ID:	71863   Click image for larger version
ID:	71864   Click image for larger version
Name:	new grinder.jpg
ID:	71865   Click image for larger version
ID:	71866   Click image for larger version
Name:	rear front.jpg
post #86 of 86 Old 05-16-2005, 01:09 AM Thread Starter
Banned
here are the rest
ID:	71868   Click image for larger version
