Most Hacked Shit Ever Seen 2009 Thread!!
Old 01-17-2009, 04:10 PM   #201
Vroom 2.2 Vroom
Oldskool94's Avatar
Re: Most Hacked Shit Ever Seen 2009 Thread!!
skylines are sweet.
Old 01-17-2009, 06:35 PM   #202
anyone want to help?
ntloenf's Avatar
Quote: Originally Posted by kdknebel
not really hacked just dumb
holly orange peel. yikes
Old 01-17-2009, 07:30 PM   #203
she will lay one day
jwillie000's Avatar
cant say there not factory lol
Old 01-18-2009, 01:14 AM   #204
lol
i like the notched notch
Old 01-18-2009, 01:18 AM   #205
i wonder if i can get this guy to do my body work he is craaaazy
Old 01-18-2009, 01:25 AM   #206
forum idiot
orangesonoma's Avatar
oh shitz
Old 01-18-2009, 01:30 AM   #207
good bye red, it was fun
1/4milecrazy's Avatar
thats what i said
and i have seen worse welds than in that first pic
Old 01-18-2009, 02:26 AM   #208
Afterhours Admin
AVTekk's Avatar
ya the welds arnt terrible, the technique needs to be cleaned up a LOT. but the notched notch?? and that wishbone crossmember looks to be notched as well, i can see open tubing inside there. also its waaaaay too tall and thin to support that wishbone, will probably fall over when you hit the gas.
Old 01-18-2009, 02:34 AM   #209
The Dreamsicle
cpolaris502's Avatar
i dont see whats wrong with that. the doors warped? so.
Old 01-18-2009, 10:44 AM   #210
forum idiot
why are there holes in the door?
Old 01-18-2009, 10:54 AM   #211
vince921's Avatar
maybe he was trying to pull the warps out
Old 01-18-2009, 11:06 AM   #212
Under Construction
digbmx4130's Avatar
atleast he used a stud gun and pulled them instead of filling it full of mud.
Old 01-18-2009, 11:09 AM   #213
forum idiot
oh thats why?
so every shave job looks like this?
Old 01-18-2009, 11:12 AM   #214
vince921's Avatar
i hope not
Old 01-18-2009, 11:18 AM   #215
Under Construction
digbmx4130's Avatar
who said every shave job looks like this? not everyones doors turn out like that. i shaved my truck doors and they didnt warp, and 1 out of 4 doors on my blazer warped
Old 01-18-2009, 11:20 AM   #216
at least it aint cardboard glued in and smoothered in bondo, that would be surely innovative, lol.
Old 01-18-2009, 11:51 AM   #217
lame-o
dragginbalz's Avatar
Panels warping are not always avoidable. Depending on where the door brace is can effect how the metal moves when you weld it.
Drilling holes and using a slide hammer is a perfectly acceptable way to pull out a warped door. A stud gun is better,since you do not have to weld up the holes, but it works and did for many years.
With the few holes that he had to drill, I would say the warpage wasn't even that bad. As stated, it is much better to pull the dent than just fill it in with filler!
Now if he ducktaped the back side of the holes and filled them with roofing tar, then it belongs on here.
t
Old 01-18-2009, 11:55 AM   #218
The Dreamsicle
it's just regular body work practice. nothing wrong with it.
Old 01-18-2009, 11:58 AM   #219
White Stealth's Avatar
Quote: Originally Posted by orangesonoma
oh thats why?
If you take your time and move from panel to panel a shave job will turn out almost perfect. It's a matter of controling the heat. If you don't let the door cool long enough between welds then it's gonna warp cuz it's so thin. I have seen much worse out of supposed experienced guys who charge big $$$ for their work.
Old 01-18-2009, 03:51 PM   #220
Vroom 2.2 Vroom
Oldskool94's Avatar
that body work dosent look bad at all, its not even closed to finished.
Old 01-18-2009, 05:16 PM   #221
MoKo CuStOmS's Avatar
why would you weld all the way around on a flippin door handle shave? should of just put bondo on the lip and stuck the filler plate on. s10 doors are pretty hard to warp. im just calling out hacked. regardless if he pulled out the dent. no need to put that much heat into a door handle lol. take your time and move to the next door after a few tacks.
Old 01-18-2009, 07:15 PM   #222
The Dreamsicle
my doors had some warpage when i shaved them too. I guess my truck is hacked now. it was even pulled back out and fixed right but i guess that doesnt matter.
I sure hope you were joking about slapping in a filler plate with bondo, but knowing you, probably not.
Now to get the thread moving with more pictures...
Nice gussets here.
Old 01-18-2009, 07:17 PM   #223
lame-o
You suggest just putting body filler (not panel bond would actually be an acceptable solution) on the lip and slapping it in place and you are calling that fully welded handle hacked?
Shame on you!
t
Old 01-18-2009, 07:19 PM   #224
rocknthehawk's Avatar
this guy didn't like that i said he's a hack...maybe i'm wrong:
Old 01-18-2009, 07:30 PM   #225
stone the crow...
Draggin97's Avatar
Doing good body work>you
That shit will crack and line back out over time not to mention if moisture creeps inside you have rust .
Old 01-18-2009, 07:37 PM   #226
the comment was for the guy trying to fully weld in a filler plate and warping it. it was obviously a joke.
Old 01-18-2009, 07:38 PM   #227
Redd's Avatar
lol i got to watch my friend shave his door the wrong way. Maybe a total of 6 tacks to hold the filler in place, then used the bondo with fiber glass in it and swiped it, sanded it and primed it and called it done. Needless to say everything he did cracked out. or you can start to see it through the bodywork
Old 01-18-2009, 07:44 PM   #228
therukus99's Avatar
we outta take this thread and make it a reality show or take it to the jerry springer show
Old 01-18-2009, 07:51 PM   #229
[quote=cpolaris502;5949668]my doors had some warpage when i shaved them too. I guess my truck is hacked now. it was even pulled back out and fixed right but i guess that doesnt matter.
Old 01-18-2009, 10:15 PM   #230
crew cab sfbd commin soon
blazed00's Avatar
i have a few pics from thiis weekends winter cruize in fayetteville. saw a guy that had his compressor and tank sitting in the pass seat. and another with his valve blocks sitting on the gastank with nothing holding them down. alot of hacks show up at the winter cruize shows
Old 01-18-2009, 11:01 PM   #231
FAT GUY IN A LITTLE TRUCK
DOORDRAGGER's Avatar
lol
CHECK OUT THE TOTAL BUILD SO FAR ALOT OF THIS IS CLEANED UP AND REINFORCED. IT'S ONLY A 4.3 NOT A MONSTER MOTOR. http://www.s10forum.com/forum/f30/pr...dydrop-373484/
Old 01-18-2009, 11:21 PM   #232
getting shit done
laydout97's Avatar
lol
Anyone notice that the D/S is missing a bolt?
Old 01-18-2009, 11:35 PM   #233
The Dreamsicle
I did go through it and found no other bracing for the wishbone crossmember. The rear frame lowering does not look good at all either.
Old 01-18-2009, 11:36 PM   #234
V8 with bags
V8Blaze's Avatar
also notice its missing the body too lol
these threads are rediculous, most of you are little girls
Old 01-18-2009, 11:58 PM   #235
getting shit done
laydout97's Avatar
Why, because we show pics of hacked ass work?
Old 01-19-2009, 12:26 AM   #236
Patawick's Avatar
and here it goes
Old 01-19-2009, 12:42 AM   #237
Startin' From Scratch
PowerDown's Avatar
What's wrong with this, i guess i'm missing it?
Old 01-19-2009, 01:17 AM   #238
tohoopty's Avatar
on the truck with dual axles did anyone notice how close the back tires are to each other
Old 01-19-2009, 01:24 AM   #239
this was my reply to cpolaris502, he posted a picture of the setup the day i started on it. and i was replying with the almost finished product.
Old 01-19-2009, 01:24 AM   #240
GAVE his truck to 96super
bubbagt57's Avatar
it was a reply
EDIT: nvmd
Old 01-19-2009, 01:31 AM   #241
2legit2quit
iLLblazer's Avatar
please tell me this is a joke
Old 01-19-2009, 01:36 AM   #242
lol yeh already said it was. thats why the last sentence says take your time and put some tacks on one door and go to the next. i guess i didnt clearify to go back and forth until its tacked enough.
Old 01-19-2009, 01:37 AM   #243
l1ld3v1lrydr's Avatar
wow you guys can really judge a book by its cover huh? i just love it when ppl go to a build thread and just look at the pics and dont bother reading shit, then wanna go and harrass them on shit thats just mocked up or isnt fully completed yet. you may laugh at our "hacked work" now, yet when its all said and done with, come up to us at shows and shake our hands for what we have built.
my notch is notched so we could have the notch as low as possible for floor clearence in the end, and the axle clears the notch as is, we just added the extra clearene incase its needed. the axle is a good 2-3inches higher than being laid out in that pic.
theres isnt a nut on the drive shaft simple becuz we were taking the drive shaft on and off to see where it needed to be to clear the crossmember.
and i garentee you that 3 link cross member is strong enough to with hold the power of 200,000 mile 4.3 with all of maybe 200 horse power.
as stated earlier, this is just a cruiser/show goer, not an all out performance vehicle.
Old 01-19-2009, 01:46 AM   #244
SAME GROUP OF GUYS BUILDING THIS. CAN BE SEEN AT CARLISLE EVERY YEAR DRAGGIN. WOW AND SO FAR THEY WIN EVERY YEAR! HELL YEAH WANNA KNOW HOW STRONG THIS STUFF IS? THEY HAVE MORE DEMOLISHED DRAG BLOCKS THAN HUGH HAS BUNNIES. AND NO PROBLEMS YET EXCEPT LOSING A CALIPER BOLT AND THINGS OTHER PEOPLE DID.
Last edited by DOORDRAGGER : 01-19-2009 at 01:56 AM. Reason: MISSPELLED WORDS FORGOT INFO.
Old 01-19-2009, 01:47 AM   #245
PowerDown's Avatar
It sure has come a long way. nice job.
Old 01-19-2009, 02:06 AM   #246
update on my last post...here is what i found behind all that foam.......
Old 01-19-2009, 02:09 AM   #247
very well put i must say!!
Old 01-19-2009, 02:09 AM   #248
twistedxknights's Avatar
damn thats look like it was in a demo derby or something
Old 01-19-2009, 02:29 AM   #249
FOR ALL THE HACKS.
Old 01-19-2009, 02:39 AM   #250
Here's one I found on another forum. Jeez....
Page generated in 0.69611 seconds with 32 queries
[Output: 219.98 Kb. compressed to 200.99 Kb. by saving 18.99 Kb. (8.63%)]
