looking for 2 door blazer 1st gen build logs
im having a hell of a time finding 2 door 1st gen build logs (the squared off ones)
V8 with bags
Re: looking for 2 door blazer 1st gen build logs
there really arent any. The best one i can think of is phatfarmer hes got a huge one around here somewhere. Ive got some pics in my sig but nothing major, i suck at taking and posting pics.
thats a shame
Just Because
I've got one.
http://www.s10forum.com/forum/f30/88...5/#post6185976 It's a 1988 GMC S15 Jimmy 2 Door |
finally thats one. i need to start figuring how to lay frame and still keep my backseat and not have a huge step in the rear
Uncommon Engineering
search iLLblazer
f#ck rich kids
one we are building on a budget for my little bro.........watch for a lot of updates real soon
http://www.s10forum.com/forum/f30/lo...blazer-398728/ |
V8 with bags
to keep a back seat i wouldnt use any setup with a diff bracket, they stick up way to high. Id go with a regular 4 link. Use behind and under brackets to keep that part low. And the most important thing IMO is dont over notch it. Pick a rim size/over all diameter tire you would like to run, and do some measuring and only put the notch as high as you need. Same goes with the driveshaft crossmember
I think my plan is going to bag the front then worry about the rear
V8 with bags
well with a parallel 4 link, the upper bars are going to come up into a weird spot in the body, then you will have to run a panhard bar or a watts, which will again compete with gastank space. Theres not alot of room. First gen frames are similar enough to second gen ones that you should check out the second gen blazer builds too. Some stuff will be a little different but they similar enough to get a great idea of what space will allow
or do an underlsung... would be different and probably the diff would only come 4-5"s into the truck.
I have the disease
I don't have a thread either, so I'll just whore it up a little here. I'm probably not much help though. I'm bodied 4 1/2" and not keeping the rear seat. Plus I'm building a whole new floor and firewall.
![]() ![]() I went with a universal triangulated 4 link and built my own brackets. Last edited by blazerlow : 07-27-2009 at 09:34 PM. |
looks like it will turn out killer
Location: Lovely Imlay City, Michigan User is: OffLine |
http://www.s10forum.com/forum/f125/b...blazer-325121/
It's a 4 door but it may give you some ideas... |
Its that dam ADD!
Im still needing ideas!
Definite Obsessions
it's not finished yet, still needs shocks put on
That set up looks nice, but seems like it might be a bit big for a backseat.
Definite Obsessions
Just Because
