how to set up a 4 link ? - S-10 Forum
post #1 of 7 Old 11-12-2008, 08:05 PM Thread Starter
anyone want to help?
ntloenf's Avatar
User is: ntloenf is offline
Wondering if there is any one who want to tell me how to set up a triangulated 4 link ? i know i can just buy a specific link kit but i want to save some money and just get a universal kit and make it work on my truck. I know you have to measure for your pinion angle but thats about it? some one please give me the run down.
ntloenf is offline
post #2 of 7 Old 11-12-2008, 08:20 PM
Stock tires with 5.7
TuckaBlaze's Avatar
User is: TuckaBlaze is offline
Send a message via AIM to TuckaBlaze Send a message via Yahoo to TuckaBlaze
Re: how to set up a 4 link ?
From what i have read.
Bottom bars need to be parallel with the top bars as if you was looking for the side. The triangulated bars need at least 40 degree angle. The top and bottom bars need to be mounted as close as possible to the same distance of the axel. Pinon set at ride height.
If i think of anything else I will come back and post. I do feel like i am forgetting something.
post #3 of 7 Old 11-12-2008, 08:52 PM Thread Starter
ntloenf's Avatar
thanks, now i have some basic info
ntloenf is offline
post #4 of 7 Old 11-12-2008, 08:52 PM Thread Starter
ntloenf's Avatar
does the bar length matter? or which bars are longer? or how long should the bars be?
ntloenf is offline
post #5 of 7 Old 11-12-2008, 08:56 PM
TuckaBlaze's Avatar
Longer the better. they need to be mounted about the same distance from the axle to the frame.
If anything the uppers can be mounted a lil closer from the axle... it will just cause pinon to turn down when u lay it out. (being it is a forward facing 4link)
that is what i am gonna end up having to do on mine.
post #6 of 7 Old 11-12-2008, 09:57 PM
DELIBERATE DESIGNS
GET_LOW's Avatar
User is: GET_LOW is offline
Hes sorta right.
(Side View)
Bottom bars are suposed to be parallel with the ground at ride height. to minimize steering roll.
The uppers are suposed to angle down a little towards the front to change your anti squat.
You are right on the part about the uppers. The uppers should have as much triangulation as possible on the top side. This holds your rear end from skating around side to side whule you drive.
The longer the bar the better. The longer bars provide less your pinion angle should change if it is set up right. And longer bars also minimize the moviment of the driveshaft by not pulling it out or pushing it into the tranny.
PIC:
Good video on how the links and bar lenghts effect your pinion change.
http://www.youtube.com/watch?v=YoAu-gPPktQ
Jordan (JJ, Gordo)
facebook.com/DeliberateDesignsLLC
~PROJECT THREAD~
GET_LOW is offline
post #7 of 7 Old 11-12-2008, 10:40 PM
Afterhours Admin
AVTekk's Avatar
User is: AVTekk is offline
http://www.s10forum.com/forum/f125/c...5/#post5737880
Serving the Tri-state: New Jersey - New York - Pennsylvania[/center]
AVTekk is offline
You may post new threads
You may post replies
