How To BYC Upper Control Arm Install - S-10 Forum
Old 02-23-2006, 04:14 AM   #1
There's a new story entry added:
This HowTo will basically cover the install of a Barnyard Customs upper control arm for an s10. However many of the practices are the same with other control arms from other manufactures so it may be a good reference for you.
Old 03-03-2006, 11:54 PM   #2
mine drags on the ground
whitey97's Avatar
don't you need to recieve goods before you can install them? not only that, but does anyone really trust these things?
Old 03-14-2006, 11:16 PM   #3
pictures have been rehosted so that guests can view as well. also hosted as thumbs to help save bandwidth.
Old 06-17-2007, 09:18 PM   #4
slowly learning..
dart_06's Avatar
Re: How To BYC Upper Control Arm Install
why wouldnt they b trustable?? whats wrong w them??
Old 07-08-2007, 04:25 PM   #5
imknotright's Avatar
A few things about this install that are safety concerns.
  1. Make sure you support the lower control arm befor starting other wise the spring will give you a nice suprise.
  2. When installing the boot for the upper ball joint you will notice the hole for the shaft has a notch. this notch shound be pointed away from the brake rotor when installed so grease doesnt get on the brakes.
  3. It is NOT acceptable to mount the ball joint to the bottom of the control arm. If you mount it to the bottom, the small bolts that hold it on will eventually snap & the ball joint will seperate from the control arm causing you to loose control. By mounting it through the top as it should be, the lip of the ball joint will stay in the control arm if the bolts do break.
Old 07-14-2007, 11:56 AM   #6
I have the disease
blazerlow's Avatar
yo
Old 07-18-2007, 02:14 PM   #7
whitey97's Avatar
wow, was this brought out from the dead
Old 05-04-2008, 10:08 PM   #8
Angry Re: How To BYC Upper Control Arm Install
how do i take off the front differentail and axles?
Old 02-28-2009, 12:49 AM   #9
Twisted Intentions (Ky)
ky_sk8erpunk's Avatar
does any one have any pics of the BYC lower Control Arm installed because i got a set and have them on but the air bag is offset off the mounting plate and i didnt know if i just installed it on the wrong side or what but any pics of the lower control arm installed would probly help me
Old 03-24-2009, 12:02 PM   #10
try suicide
so how did it ride with the stock cross shafts
Old 03-24-2009, 01:35 PM   #11
Afterhours Admin
AVTekk's Avatar
ride will not be affected by the cross shafts
Old 04-01-2009, 12:11 AM   #12
narrow 9 inch ford
i need to know how to narrow a 9 inch 2 inchs
shorter than stock so that i have the pinion
like the stock rear my truck is a 1986 model
thanks dragtrack
Old 04-01-2009, 06:16 AM   #13
fiveinchbodydrop's Avatar
wtf....
Old 04-01-2009, 02:00 PM   #14
2legit2quit
iLLblazer's Avatar
lmao.. apparently this is the random ass question thread?
Old 04-01-2009, 07:05 PM   #15
*LO4U2NV*'s Avatar
Ok, back on the subject, I ordered a set of BYC uper and lowers about 5 years ago. They are sitting in a box in the garage. I just got myself another 2wd blazer. Should I use the BYC stuff or get something different? Was there anything wrong with the BYC stuff?
Thanks, Brian P.
Old 04-01-2009, 07:08 PM   #16
NO REGRETS
purplepassion's Avatar
i was thinking the same thing
Old 05-07-2013, 02:28 PM   #17
alright im new to this and this site hopeing someone can help.....bought a sweet bagged sonoma and when I drop it after a while I go out and it has picked its self back up whats wrong how do I fix it
Old 05-07-2013, 10:02 PM   #18
Vandelay Industries
cruisinlows10's Avatar
Your air valve is sticking open,or it has a bad diaprhagm. It probably has some sort of debris/trash inside the valve. Nice bump of a entirely unrelated topic. Welcome to s10forum
http://www.s10forum.com/forum/f125/s...how-to-237585/
taken from
http://www.s10forum.com/forum/f125/h...-first-258384/
Old 05-09-2013, 01:46 AM   #19
Patawick's Avatar
At least he searched by not sure why he went here lol
Old 05-09-2013, 01:47 AM   #20
Patawick's Avatar
Never mind, I see.
