How do I wire up this AVS digital gauge? - S-10 Forum
Old 03-28-2012, 10:59 PM   #1
kid kaoz's Avatar
Ok so I picked up a used AVS digital gauge. The sensors have 3 wires coming off of them. Red, black and white. I assume that the red is positive the black is ground and the white is the data wire.
I wanted to test the sensors. So I hooked them up to my shop compressor line which has 150PSI in it. The gauge read "000".
Is this thing busted or do I have the wiring messed up somehow?
Any help would be great. Thanks.
Old 03-29-2012, 02:36 AM   #2
gettin layed
Dmbh09's Avatar
Re: How do I wire up this AVS digital gauge?
Hope this helps
Old 03-29-2012, 02:32 PM   #3
kid kaoz's Avatar
Thanks! I must have some bad sensors or something. Cuz I have it hooked up right according to the instructions. Oh well.
Old 03-29-2012, 02:40 PM   #4
REMOTIVATED
Elixur's Avatar
All of your sensors aren't reading?
I had two not work on mine first one was a bad sensor. The second was a wire pulled out of the harness. The sensors AVS sent me a new one after mine was tested and the harness I just put a new end on and they work fine since.
Old 03-29-2012, 04:20 PM   #5
kid kaoz's Avatar
I only had a chance to test one of the sensors. I will test the others tonite. I am hoping that it is just a bad sensor.
Old 03-29-2012, 06:58 PM   #6
gettin layed
Dmbh09's Avatar
i installed a set on my friends truck and they are off and on one min your at 60psi 10 min later your at 20psi stop get a drink drive off and your and you get the 000 flashing and beeping... seem like the sensors go out way to often...
