Help again (
Old 11-10-2009, 07:42 AM   #1
Help again (
sorry for all the ? but should i hear air from what seems to be my compressor right after they shut off from filling my tank?i lifted my truck up to 125psi front and back and im going to check them in 2hrs and see which has lost pressure...thanks again
Old 11-10-2009, 07:48 AM   #2
Afterhours Admin
AVTekk's Avatar
Re: Help again (
Might have a leaky checkvalve in the comps leader hose, you shouldnt hear anything..
Old 11-10-2009, 02:25 PM   #3
VIAIR Corp
lance_martz's Avatar
Re: Help again (
Kind of confusing when you have two threads going about the same issue.
Again, a leaking check valve on a compressor would not be causing your vehicle to drop up front...
