Having problems and need help - S-10 Forum
post #1 of 6 Old 11-20-2012, 12:34 PM Thread Starter
User is: PocketAces is offline
i can't seem to figure out what is going on with my tank and compressors. I am running a pair of viair 444's and a 5 gal tank... i know i have a couple of leaks in the system, but nothing horrible... for some reason now i can't get the pressure in the tank over about 90psi, and this is after letting the compressors run for over 20 minutes... any suggestions?
thanks in advance for the help
post #2 of 6 Old 11-20-2012, 04:02 PM
Kyle
bushwickbill94's Avatar
User is: bushwickbill94 is offline
Re: Having problems and need help
are they both getting 12 volts? are the comps old? and after you turn the comps off do you quickly lose the 90 psi?
Originally Posted by cruisinlows10 View Post
you are probably going to have to overnight parts from japan
post #3 of 6 Old 11-20-2012, 08:26 PM
REMOTIVATED
Elixur's Avatar
User is: Elixur is offline
Check the air filter and see if its leaking back out of there. Id think checkvalve in the leader hose is bad.
97ext cab - fbss, 1/2 danz, sd 5 link & arms, re7s up front re8s rear, 2 5gal tanks, shocks frnt&rear,swaybar, dual 480s/sanden edc,avs switch box, train horn, hydro boost, tubbed, shaved,
Elixur is offline
post #4 of 6 Old 11-20-2012, 09:59 PM
whitelowereddime's Avatar
User is: whitelowereddime is offline
sounds like seals in the comps are bad
post #5 of 6 Old 11-24-2012, 08:52 PM
Registered Asshole
rstadelmaier's Avatar
User is: rstadelmaier is offline
^^^ this. same issue with mine, but it's a 120psi. my cylinder head is shot
because i just can't be normal>>> http://www.s10forum.com/forum/f125/p...ckhalf-488914/
post #6 of 6 Old 11-24-2012, 09:04 PM
I don't feel tardy
joedoh's Avatar
User is: joedoh is offline
check the tank for water. I thought I had bad compressors and it turns out the tank had better than a quart of water in it, it was funking up the check valves.
my embarrassing 2.2l 5 spd 1965 fullsize http://www.s10forum.com/forum/f30/frankendime-458726/
my 49 chevy s10 swap 4.3 auto http://www.s10forum.com/forum/f30/49.../#post10592042
joedoh is offline
You may post new threads
You may post replies
