#51 |
Re: Greasing a sanden
#52 |
#53 |
Moved on to Mazdas
#54 |
Moved on to Mazdas
That was the only hole i saw, i plugged at and removed the tube
#55 |
Moved on to Mazdas
Ok, well i got mine done....here's some pics... I even got my girl to help
I gotta get a couple things before i can put it on and check it out but its done for now....![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#56 |
Location: Pittsburgh PA User is: Online ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#57 |
V8 with bags
damnit i hate seeing these edc threads. Im nearly 100% positive i can cram a sanden where my stock ac went on my truck. And that grese mod looks nice. After you grease it all down, and put it back together should you put a zerk on it and fill it completely or what?
#58 |
i think you tap the oil plug hole to fit a zerk fitting. good question about how much grease though. i've never heard if you fill it or just put a few pumps
#59 |
Moved on to Mazdas
No, the grease isn't goin anywhere. Its high performance grease that stays where you put it
Its high shock, high pressure, high tempurature, it resists centrifugal seperation, haha |
#60 |
looks good man. hope it works good for ya. keep us updated and when you get it goin, give us some fill times
#61 |
Moved on to Mazdas
will do, i was gonna get a check valve for it, i don't know if its like a regular compressor or not..... Do i need one???
#62 |
V8 with bags
so once you put in that grease your done, as in no more adding to it, or should you disassemble and regrease periodically
#63 |
Moved on to Mazdas
Well the guy that started this thread has had his for quite some time now and as far as i know from this thread, he still hasn't had to regrease it and the grease wasn't showin signs of burnin up. Jus make sure not to skimp on the grease you use, spend the extra money and get higher performance grease
#64 |
.:|Hustlin4life|:.
#65 |
Moved on to Mazdas
Ok, i got an smc water trap, i was gonna mount the check valve ON the tank too... Thanks for the info man
#66 |
V8 with bags
awesome, thanks for the info, what grease are you guys running
#67 |
Moved on to Mazdas
I used this......
![]() You can get it froms Autozone for like 9 bucks |
#68 |
Spectacle VP
I've got my truck tore apart to replace an exhaust manifold, so I have the comp off. I'm gonna take it apart and check it out again, hopefully w/ some pics. |
#69 |
Spectacle VP
#70 |
Moved on to Mazdas
^^^ Ya, do you jus drill a hole in the case?! That seems a bit odd to me... And ya, pharacyde, pics would be awesome, i'm curious to see how yours is doin. How does mine look??? Everything look ok to you???
And what did you use for the output line to the tank??? I'm thinkin bout doin stainless tubing. I don't really wanna use big ass ugly hydaulic line, ya know? |
#71 |
Moved on to Mazdas
#72 |
Moved on to Mazdas
#73 |
Moved on to Mazdas
#74 |
Moved on to Mazdas
wow..... It kept sayin failed posting or some shit.... I guess it didn't fail afterall, haha
#75 |
Spectacle VP
HOLY QUAD POST!!!!
Yours looks fine to me. I can't say how the SD7 is gonna do because mine's a 5, the rubber piston rings may react different for better or worse. I'll get pics up this afternoon after work. |
#76 |
Moved on to Mazdas
Cool, well i'll be the test dummy for the 7 then haha. I hope it works out good
#77 |
SOME 1 BUY MY BIKE
will lucas "Red "N" Tacky #2"
it says Multy-Purpose EP Grease Fortified with "Anti-Seze" For maximum Surface Protection 540 Degere drop point |
#78 |
i just picked up a 508 today
i'll probably start tearing it apart within the next couple of days. i'll make sure to take plenty of pics and post. |
#79 |
Moved on to Mazdas
I decided against the Lucs grease... cuz it said tacky, i don't know if that jus meant it stays in place or what but i know its high performance, I'm sure it would work jus fine...
#80 |
hey flgatorsrule. in this pic with the wobble plate/clutch assembly, did you take it apart or leave it like that? if you left it, how did you go about cleaning the old oil out and getting the new grease around what i assume is a bearing under the wobble plate?
#81 |
Moved on to Mazdas
i left it together... I couldn't figure out how to take it apart... I soaked all the parts in gas to clean em and for that part, i jus held the clutch part out of the gas and rotated it back and forth cleanin all the oil out... Then i jus kept shovin grease in everywhere i could see till i felt comfortable with it. You can feel when its gettin lubed up good. And i put alot of extra grease in that part of the compressor as a whole and in the holes in that wobble plate...
#82 |
Moved on to Mazdas
the piece in the top right of that picture is the only piece i didnt SOAK in gas... I cleaned it with gas but i didn't soak it like the rest, cuz it has rubber gaskets on it and i didn't wanna screw em up. Hope that helps
#83 |
