failed emissions test? - S-10 Forum
post #1 of 17 Old 02-14-2006, 03:18 PM Thread Starter
dun4sho
david owens's Avatar
User is: david owens is offline
i have a2001 2.2 4cyl. ok just bagged the truck a month ago i relocated the evap canister and purge sylinoid . now i went thru emissions testing and failed it said the readiness monitors arent ready . i have no check engine lights on. the chevy dealer said to drive the truck and they will reset. just wondering if anyone else had this problem and long does it take to reset?
post #2 of 17 Old 02-14-2006, 03:38 PM
5 inch bodydrop bitches
sdimelayenframe's Avatar
User is: sdimelayenframe is offline
Send a message via AIM to sdimelayenframe Send a message via MSN to sdimelayenframe
Re: failed emissions test?
we dont have emisions tests here
95 S10 4x4
96 Sonoma - doored shaved and for sale
86 Toyota - flat pepto bismol pink and crushed on 19s
87 Suburban - the "meat machine" also for sale
post #3 of 17 Old 02-14-2006, 03:39 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
WHat the chevy dealer said is true. It means that the computer once saw a fault (probably durring relocation) and no longer sees the fault. It will take some time now as the computer scans and readys the system back out. Just drive the truck. If there are no more faults then the system will reset itself and you will pass
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #4 of 17 Old 02-14-2006, 03:47 PM
thepunkerguy's Avatar
User is: thepunkerguy is offline
I don't know if it works like the check engine light and all, but did you try unhooking your battery for a few hours and then putting it back in to reset the computer? That would probably do it as long as there is no more faults
- Mike
- Mike
post #5 of 17 Old 02-14-2006, 03:48 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
- Mike
That does not work on OBDII vehicles (96+)
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #6 of 17 Old 02-14-2006, 03:53 PM
Ok, just an idea. My truck is a 98 and I have a bad connection on the sensor on the top of my gas tank and it keeps popping my check engine light on every now and again, if i take out the battery for a bit then it clears the code and the light goes off. Thats why i figured it might work for him.
- Mike
- Mike
post #7 of 17 Old 02-14-2006, 04:29 PM
Hoods are overrated
sadexcuse4s10's Avatar
User is: sadexcuse4s10 is offline
Send a message via AIM to sadexcuse4s10
drive the truck for about 500 miles, the computer takes that long to fully read the EVAP system, charcoal box, and O2 sensors, and air injection
Project '86 *Shame to Fame* FOR SALE, wife expecting baby. No engine or trans.
'93 Honda XR650L rebuild
post #8 of 17 Old 02-14-2006, 04:36 PM
forum idiot
orangesonoma's Avatar
or get a scanner and clear the codes...
i used to pull out my ecu fuse in my 96 sonoma and that would reset the check engine light...
Brian
orangesonoma is offline
post #9 of 17 Old 02-14-2006, 04:42 PM
!! TALK NOW !!
drps10's Avatar
User is: drps10 is offline
Send a message via AIM to drps10
i would unhook my ground cable for a few hrs.. that seem to reset it when i needed it... and if you still can't pass.. get Truck plates.. rate the truck at a GVW over 10,000 lbs and u get truck plates... no need for emissions or anything.. just little more expensive. that is what i have done and will always need to do
-- Anthony --
__________________________________________________ _____
SMM ??
PhotoBucket B/D
CarDomain B/d
Stock Floor Body Drop.... Check it
**R.I.P. "Freddy".. you will be missed 7/2/06**
drps10 is offline
post #10 of 17 Old 02-14-2006, 05:50 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
More details?
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #11 of 17 Old 02-14-2006, 06:02 PM
!! TALK NOW !!
drps10's Avatar
well where I live, you can get truck plates for anything with a GVW over 10,000 lbs. ( i think that is the right weight) If you open your door. the sticker should show the GVW. If you actually use that, you won't get the plates. We did it with a dually because were were 100 lbs short of it and we tow alot of things. So dad just wrote down 10,100 lbs as the GVW and we got the TRUCK plates. That is what i will do with my s10 cuz it won't pass Echeck.. I can ask him more about it, if you have to do anything else with it. But i think that is it.. NO emissions needed
-- Anthony --
SMM ??
PhotoBucket B/D
CarDomain B/d
drps10 is offline
post #12 of 17 Old 02-14-2006, 07:19 PM
fiveinchbodydrop's Avatar
User is: fiveinchbodydrop is offline
i swap my tags from my corolla to whatever wont pass. in tenn you can take a vaild tag off a car transfer it to the "bad" vehicle, then in a week or so go back and test your good car and re-tag it. pretty easy...
CHRIS
"....deaf and blind and dumb and born to follow, what you need is someone strong to guide you....." -Opiate
post #13 of 17 Old 02-14-2006, 09:20 PM Thread Starter
dun4sho
i dont think i will put 500 miles on there between now and march thats when my tags expire . i only have 28000 on it now its a 2001 lol
post #14 of 17 Old 02-14-2006, 09:56 PM
AWESOOOOOOOOOOOOOOME
bzzzt's Avatar
User is: bzzzt is offline
Seriously though, that's all you can do, i know exactly what you're talking about.. It's not a problem with the job you did relocating the evap, if it was that your MIL would be on, which it isnt. It's because the evap monitor takes FOREVER to become "ready" resetting the ecu will only make it take longer most likely, there's no "code" to clear, the answer is to just drive the shit out of it. Mine had to be driven about 20 miles before the evap system showed as ready the last time i got a smog check.
bzzzt is offline
post #15 of 17 Old 02-14-2006, 10:09 PM
62 Impala member
lilbluetruck98's Avatar
User is: lilbluetruck98 is offline
Send a message via AIM to lilbluetruck98 Send a message via Yahoo to lilbluetruck98
every time the battery is dissconnected it clears the memory in the on board computer(s) when reconnected they will have to go through a re-learn process your has not fully finished goin through the re-learn process thats why its NOT READY do not disconect your battery or ground cables all of this will prolong the process of getting your truck passed i dont know what state you are in but in nc when a vehicle is not ready it doesnt issue a fail it only issues a rejection based on what the readines monitors say 96-00 are allowed 2 not ready codes(not dtc's) 01 and up are only allowed 1 not ready code in order to reset the readiness codes all you hafe to do is drive it some take 10 miles others take 500 miles the dealer can reset them by doing what i think is called a drivecyle relearn dont know how much it costs or even if they will do it but they do have the info to speed up the process
Myspace
Outkast Kustoms
Originally Posted by scrubz739 View Post
it was. after he saved it about 3 times from hitting walls, he got out and pumped his fist in the air. honestly it was a hell of a sight.
post #16 of 17 Old 02-15-2006, 12:31 AM
Headturners
2002ZQ8's Avatar
User is: 2002ZQ8 is offline
Send a message via AIM to 2002ZQ8
i was just in the same boat i disconnected the batter for a few minutes then drove it about 80 miles and it was good to go but what a PITA
___________
MY GALLERY .......................................... MY GARAGE
2002ZQ8 is offline
post #17 of 17 Old 02-15-2006, 07:39 AM
!! TALK NOW !!
drps10's Avatar
also. my Echeck will give you 30day tags if you tell them you need the tags so you can drive it around after you fix the problem. I did that for 2 mths in a row..
-- Anthony --
SMM ??
PhotoBucket B/D
CarDomain B/d
drps10 is offline
