F/B to FBSS help? - S-10 Forum
F/B to FBSS help?
Old 04-30-2012, 12:52 PM   #1
F/B to FBSS help?
I know the general concept of this, but a little clarification would really help. From my tank, I have 1/2" air lines that runs to a T fitting into 3/8" lines... One for the front and back. I know I would need 4 more valves, but how would I go about running the air lines and wiring? Does anyone have any wiring diagrams or FBSS diagrams?
Old 04-30-2012, 01:20 PM   #2
Negative 10
illest G's Avatar
Re: F/B to FBSS help?
the easiest way would be to just ditch the airline you already have. then run 4 strands of airline coming off the tank. 1 for each corner. to wire it. you just ground all the grounds and run the possitive of all the valves to the proper wire on the switchbox
Old 04-30-2012, 09:16 PM   #3
Thanks! and in terms of making sure all the bags are evenly filled, would i need a digital management set up? or would the bags just naturally fill to the same pressure? (obviously when hitting a switch wired to more than one bag)
Old 04-30-2012, 09:16 PM   #4
Old 05-02-2012, 02:15 PM   #5
'Stevie Joe'
HighrollerII's Avatar
digital or just use 2 dual needle gauges.....they'll be close but mine never filled the same on the drivers side cause of me and the gas tank all on that side....always had to tweak it a bit
Old 05-02-2012, 03:56 PM   #6
Negative 10
illest G's Avatar
best way to make sure the 2 fronts are evenly filled is to make sure the airline coming from the valves to the bags is the EXACT same length. and same for the 2 rears. and then if you run gauges that will just verify that everything is where you want it to be
Old 07-13-2012, 03:51 AM   #7
i got the same problem i just got a bagged sdime with 2 380 compressers 5 gallon tank and has 2 valves im want to know how many switches i can add
Old 07-13-2012, 10:21 AM   #8
2 valves? Do you only have the front or rear bagged? If so then just 1 up/down
Old 07-13-2012, 12:29 PM   #9
yep bagged front and back and the bitch lays frame and just 2 valves. i dunno nothin i just baught it like that lol
Old 07-13-2012, 01:57 PM   #10
Nathan7419's Avatar
Are you sure there's only two? I couldn't imagine only have all up and all down. Can you make the front and the rear dump/fill independently?
Old 07-13-2012, 04:49 PM   #11
MajesticLT03's Avatar
2 valves??? how is that even possible?
Old 07-13-2012, 05:32 PM   #12
resident crybaby
mesterz2889's Avatar
you have 2 "pairs" of valves. do your homework. you can add as many switches as you want depends on what your wanting to achieve, but again do your homework.
