Drag blocks!
I need help, does anyone know the difference between side mount and under-frame mounts? Also, I'm not layin frame, will the blocks be able to reach the ground? Or will I have to modify them to work?
Registered Asshole
Re: Drag blocks!
You just said the difference
Negative 10
Re: Drag blocks!
well the side mounts. mount to the side of the frame. and the under frame mounts...mount on the underside of the frame. and how far are you from laying? typically drag blocks will either hold people up from laying frame. (that already do normally lay frame) since it sits lower than the frame. or they mount them in the back of the truck so that they only touch the ground when the front is aired up and the rear is dumped. personally i would get the truck laid out first. atleast the rear. before i thought about dragging
Re: Drag blocks!
I'm about an inch and a half off the ground. I do plan on laying frame when i get the money, but not yet. would it make more sense to get the side mount blocks so I could lower the blocks a bit more?
So JDM my blood type is R
![]() Age: 20
Re: Drag blocks!
It would make more sense to worry about laying the truck out the right way first, then use whichever works better for your particular application in the back. From the few trucks I've done, front mount makes it way too sketchy trying to steer.
Personally, I prefer frame plating over blocks. Think about what the block is doing. Say your truck weighs 4000lbs, and that you have a perfect 50/50 distribution(just to make it easier) if you drag the rear frame itself, you are dragging 2000lbs on a say a 1.5ft by 3in rail, on both sides. If you drag blocks, you are concentrating that same 2000lbs on two 2"x4" sections. That equates to more stress on the blocks, the mounts, and the frame itself. More sess increases the likelyhood of a part failure, and when your talking bout a 4-7lb chunk of steel, shite gets real dangerous, real fast. The last thing we need as a mini community is more people doing thing in a dangerous manner. Just my .02, I am open to positive and negative critisim, differing opinions, points of view |
Re: Drag blocks!
where would be the best place to mount the frame plates/what kind of metal do you prefer? I'm Latin frame and really want to throw some dope color sparks
![]() Age: 20
Re: Drag blocks!
you plate whatever part of the frame you drag. if you drag under the doors, plate under the doors, if you drag under the bed, plate that. what ever you drag most, plate it up. i used 1/4 plate, cause if i was drivin, most of the time, i was draggin.
different metals will give different color sparks, but imo, titanium is the best looking. its like 4th of july weekend behind you, and its bright white. hella expensive and doesnt last long though. also, hard to weld for plating. |
Re: Drag blocks!
Dope! I'm def looking further into the frame plates thanks man for the info and that video is sick! didn't mean to highjack your thread @Mikeh it just
makes more sense to do frame plates instead of drag blocks I'm thinking. plus less o a chance of owing somebody for body work or a windshield for a chunk of metal blasting through a car behind ya |
Registered Asshole
Re: Drag blocks!
only reason i'd prefer drag blocks is that they can last alot longer, especially if you make them adjustable as they wear. 1/4" plates are fine, but you gotta make sure you check them all the time so you're not worn through. titanium is awesome, magnesium too, but for the price, and you're just dragging them off. my opinion it's not worth the sparks.
![]() Age: 20
Re: Drag blocks!
I would not do magnesium, since it is a flammable metal.
Just my opinion though |
Re: Drag blocks!
Where is the best place to buy the under frame titanium blocks? Having a hard time finding them- would prefer to order from a well known/reputable online shop.
Re: Drag blocks!
It's all good, I was just hoping for an inexpensive way to drag until I can afford the notch and 4link set up
Pneumatic Fanatic
Re: Drag blocks!
<SEVERED TIES>
Re: Drag blocks!
Re: Drag blocks!
am I the one 1 who realized its cheaper to buy the blocks and mounts seperately from Custom Connection.... isnt it usually the other way around?
Pneumatic Fanatic
Re: Drag blocks!
You got it backwards man. It IS cheaper to buy the complete set than to buy it all separate. The blocks are sold individually as stated on the website. $50 bucks for complete set
Re: Drag blocks!
I was going off the $60 price. The separate components are $52.
Petitioning Low Rollers
Re: Drag blocks!
i saw somewhere that copper thows some sick sparks i tried looking for a video but i couldnt find one
Pneumatic Fanatic
Re: Drag blocks!
Re: Drag blocks!
O I C. WAY off on the price then. Holy crap.
Re: Drag blocks!
Pneumatic Fanatic
Re: Drag blocks!
Ti blocks dont last very long and are more $$ so we dont build them. I have had a few guys ask for them lately so I'm thinking about doing them in the future. If you can round up a few buddys and get at least 3-4 others on board I will go ahead and get some ti and start on them. As for the 15th...That would be pushing it
Re: Drag blocks!
doesnt copper make green sparks? im pretty sure that would be cooler than white ones
#24 |
Re: Drag blocks!
I don't see copper sparking very well. It is so soft, it would grind off as soon as it hit the road too. Not to mention, it got SPENDY in the last couple years...
#25 |
y'all suck dicks
Re: Drag blocks!
#26 |
I drive
Re: Drag blocks!
A+++ response..will read again... |
#27 |
Re: Drag blocks!
#28 |
Finally Bagged!!!
Re: Drag blocks!
I know i'm a bit late but it still needs saying...
I Love the whole magnesium thing... I know some people get it mixed up with titanium(or just don't know) but i always get the mental image of someone draggin magnesium in the rain... rofl! |
#29 |
Pneumatic Fanatic
Re: Drag blocks!
#30 |
Re: Drag blocks!
Check out waylayedinc.com. They sell some titanium blocks, pretty sick!
#31 |
Re: Drag blocks!
| Sponsored Links | |
Advertisement | |
