Chassis Sag/flex fix?? - S-10 Forum
post #1 of 9 Old 06-11-2012, 04:35 AM Thread Starter
User is: Alan D Moore is offline
It isn't that bad but it bothers me. When I air up the chassis flex seems a little extreme when looking at the gap between the cab and bed.
I want to know, or get some opinions on, if it would be worth it to box in the c (channel) sections of the frame rails in the rear? Will the frame flex be reduced enough to make the work.. worth it?
I have a feeling it will greatly reduce the chassis sag/flex?
I'm hoping for a Civil Engineer to post some easy to understand formulas or a chart or rule of thumb?
post #2 of 9 Old 06-11-2012, 04:39 AM
whitelowereddime's Avatar
User is: whitelowereddime is offline
Re: Chassis Sag/flex fix??
What kind of bag set up do you have
post #3 of 9 Old 06-11-2012, 05:01 AM Thread Starter
I have the bags on rear bars so the lift is at the far rear of the chassis, that probably is why I have so much flex.
Pics of the setup in my project thread.
post #4 of 9 Old 06-11-2012, 05:13 AM
Ah I see. Which way is it flexing? When you air up the bed tilts forward?
post #5 of 9 Old 06-11-2012, 05:51 AM Thread Starter
Ya, the bed tilts forward. When the truck is sitting on the ground or up the tilt isn't bad enough to destroy body lines but when I air up it bounces flexing. I don't notice but would assume that if it will tilt toward the cab that it also twists/rolls the frame when turning.
post #6 of 9 Old 06-11-2012, 03:05 PM
Afterhours Admin
AVTekk's Avatar
User is: AVTekk is offline
The s10 frame is quite flexible, and youre right, boxing it in will help quite a bit. In fact, as generations progressed, you see a lot more frame is boxed in the later trucks, but just under the cab. They cant box it past there because of the gas tank mounting.
Serving the Tri-state: New Jersey - New York - Pennsylvania[/center]
AVTekk is offline
post #7 of 9 Old 06-11-2012, 03:12 PM
I boxed mine in aNd it helped a lot also. At the gas tank mounting bracket I boxed in front and behind it
post #8 of 9 Old 06-11-2012, 03:37 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
all the trucks i have seen sag/flex while airing up are very poorly done setups(notches not fully welded in and what not).i must have got lucky when i done mine because its got perfect gaps aired up or down.
tohoopty is offline
post #9 of 9 Old 06-11-2012, 03:45 PM
Petitioning Low Rollers
mazdawg09's Avatar
User is: mazdawg09 is offline
i saw a thread on here before but i cant find it now. heres a chart i found in another thread it might help
Check out Lowrollers.com
PROJECTS:
white 01 2.2 ext cab(on air)
orange 91 mazda b2600(also on air)
WTB:
00 envoy front bumper
