bonus: electric or belt driven? - S-10 Forum
post #1 of 29 Old 01-28-2013, 07:55 PM Thread Starter
nineninedime's Avatar
User is: nineninedime is offline
Ok so I just got a nice suprise today in the mail and i got a bonus check so naturally I thought more parts. I was originally going to wait until this spring and see if i could find a decent york 210 in a junkyard but with this new found bonus decided i would treat myself early. So here's the question first off I have a viair 480 and two other off brand compressors right now but am really wanting to go with beltdriven and wire those as back up. So what are your thoughts as far as belt over electric and where is a decent place to pick up a york 210 or something similiar.(other than ebay) i've seen rebuilt ones all over ebay but anywhere else?
1997 Chevrolet s10 4.3 auto standard cab. Re7 slams all the way around, custom 5 link. shaved handles, antenna, third brake light, massa ms50 24x9s. tubbed wall, tubular uppers, Full backhalf, needless to say its a pile of parts being tore up ad welded together right now! PROJECT: Poison Ivy
1999 chevrolet s10 2.2 5spd ext cab. Daily minor work done.
post #2 of 29 Old 01-28-2013, 08:28 PM
Ol' Sparky
Prime's Avatar
User is: Prime is offline
Re: bonus: electric or belt driven?
I got my rebuilt 210 off ebay and it has been in my truck since June 2009 and has seen alot of miles. So far she has been rock solid and in all the gallons upon gallons of air she has pumped she is only 1.6 seconds slower now than she was when new. I just check the oil regularly and add more when needed. Only mod to it is the crank case breather. After having a EDC I could never go back to only electrics. I do have a pair of 450s for back up though.
Prime is offline
post #3 of 29 Old 01-28-2013, 08:36 PM Thread Starter
cool good to know, now I have been researching these a lot and i have heard many different things about this crank case breather. any benefit with this because I've also read its not needed?
post #4 of 29 Old 01-28-2013, 11:11 PM
Ol' Sparky
Prime's Avatar
I know it cuts down on blow by, plus Doug said from his testing it is the best mod so....
Prime is offline
post #5 of 29 Old 01-29-2013, 07:06 PM
ELTC
Gimp's Avatar
User is: Gimp is offline
York 209 or 210 can be found all over ebay for real cheap if you spend some time looking hard. Generally you'll find them for $150+ ut if you keep browsing through pages you will def find them with starting bids of $50. Ive picked up all style remanned 206's, 209's and 210's for $70-90 shipped and still run a 209 in my truck going on two yrs that came from ebay.
installing a 210 this spring. as for the crankcase breather i have one on mine as well and i cant really tell the difference on blow by honestly. Even running two water/oil seperators. I mainly run it to vent the crankcase and disipate heat.
Ive had two 380's for backup forever and after running EDC i would never go back to electric air.. never
2003 GMC Sierra 6/8
1989 Chevy S10 V8 5/6
Gimp is offline
post #6 of 29 Old 01-29-2013, 08:17 PM
adam101's Avatar
User is: adam101 is offline
i have a york 209. it passes so much oil i just gave up on using it. works great but i felt like i was filling it daily. im debating wether to put it back on or just stick with my 480s.
01 blazer x bagged
03 blazer x (wifes)
07 silverado lbz 5 inch turbo back, 120 hp tune
Blazer build here~~~~} http://www.s10forum.com/forum/f125/0...10/index5.html
adam101 is offline
post #7 of 29 Old 01-29-2013, 11:36 PM
ELTC
Gimp's Avatar
Is it a junkyard 209 or is it an ebay remanned york. Do you fill it past 12-14oz ? U could always sell it to me adam i wouldnt mind throwing a backup on the shelf
2003 GMC Sierra 6/8
Gimp is offline
post #8 of 29 Old 01-30-2013, 12:04 PM
Ol' Sparky
Prime's Avatar
Thats nuts. Mine uses next to no oil, about 1-1.5oz during a month of hard use.
Prime is offline
post #9 of 29 Old 01-30-2013, 12:56 PM Thread Starter
When I ordered my 210 today so hopefully all goes well. Once I get my firewall done I will be posting up a build thread of the whole deal and the finish.
post #10 of 29 Old 01-30-2013, 01:41 PM
adam101's Avatar
yea man i was thinking about getting rid. i bought it from airlift. or suicide . i dont remember. ill keep you in mind.
01 blazer x bagged
03 blazer x (wifes)
adam101 is offline
post #11 of 29 Old 01-30-2013, 10:42 PM
resident crybaby
mesterz2889's Avatar
User is: mesterz2889 is offline
ive had my 210 on for months now and havent had ANY issues despite all the torment. i put a sight glass on the side of mine and havent had to put any oil at all in it
98 sonoma sd 3 link_show ---> soon to be 5.3/c4 irs...
89 iroc-z 350/t56_go ---> soon to be S/C 383/t56...
91 300zx_daily 400+hp twin turbo goodness
...by soon i mean not soon
post #12 of 29 Old 02-04-2013, 04:40 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
If you do the intake oil passage plug, be sure to vent the crank case. Removing the crank case pressure helps prevent oil from being blown past the ring.
These compressors on have one ring per piston, no real oil control ring. So any little bit helps.
Also straight weight 30 oil is a must, 10w30 just will not work.
Redline Race SAE30 non foaming non detergent is about the best, but a bit expensive to be passing through your compressor.
Well that and old compressors have old rings, and there may be a reason they ditched it as an AC compressor so lack of compression is a good sign it will pass allot of oil.
I have been inside up in and around these things for years, any odd questions let me know happy to help out.
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #13 of 29 Old 02-04-2013, 04:42 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
That and the Airlift SC209 I have in my truck has been run HARD for 9 years now!
If you have the money the Airlift 209's are special made by CCI ( climate control inc. ) with cast iron bits to allow them to live longer as Air compressors. For as an AC compressor they where continuously lubed by the freon in a dry no moisture system. As well had PAG oil.
DJDAudio is offline
post #14 of 29 Old 02-04-2013, 05:35 PM
ELTC
Gimp's Avatar
Hi Doug!!
2003 GMC Sierra 6/8
Gimp is offline
post #15 of 29 Old 02-04-2013, 06:04 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Hi, Scotty , not been in here in a while....
DJDAudio is offline
post #16 of 29 Old 02-04-2013, 06:05 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I need to find the time to take the junk one I have and do a cutaway model to show people what the 'mysterious' oil passage is , how it works and what to do about it.
DJDAudio is offline
post #17 of 29 Old 02-04-2013, 06:47 PM
ELTC
Gimp's Avatar
or sell me one of those V-twin models you have and let me do it
2003 GMC Sierra 6/8
Gimp is offline
post #18 of 29 Old 02-04-2013, 10:19 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I still want to see what one of those is capable of!
And I still have the grand daddy sitting on the floor in the shop, an engine coolant cooled V4 piston compressor from a BUS! lol
DJDAudio is offline
post #19 of 29 Old 02-04-2013, 11:30 PM
ELTC
Gimp's Avatar
Dont know if ive ever seen one of those before.
2003 GMC Sierra 6/8
Gimp is offline
post #20 of 29 Old 02-05-2013, 12:21 PM
xmb63's Avatar
User is: xmb63 is offline
Send a message via AIM to xmb63
Is that the one I gave you?
Joe
Exceeding Limits Pittsburgh chapter
95 Nissan hardbody doored <-sold
96 Ex cab bodydrop project
xmb63 is offline
post #21 of 29 Old 02-05-2013, 01:26 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Sure is! haha
DJDAudio is offline
post #22 of 29 Old 02-07-2013, 12:52 PM
xmb63's Avatar
That compressor was huge. I bet you could get it under the hood of a full size truck.
Joe
xmb63 is offline
post #23 of 29 Old 02-07-2013, 07:48 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Thing is like one cubic foot haha
DJDAudio is offline
post #24 of 29 Old 02-07-2013, 07:54 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I think it is the old vr of this,
it is big lol
DJDAudio is offline
post #25 of 29 Old 02-07-2013, 08:39 PM
ELTC
Gimp's Avatar
^^ holy shitzu!!
2003 GMC Sierra 6/8
Gimp is offline
post #26 of 29 Old 02-07-2013, 09:34 PM
will detail for food
Tex Star's Avatar
User is: Tex Star is offline
that thing have valve covers? lol
'92 Ext. Cab S10- 4.3/Auto
They call me, Sir-Wax-A-Lot.
Tex Star is offline
post #27 of 29 Old 02-08-2013, 11:23 AM
Proud Canadian
Lutz's Avatar
User is: Lutz is offline
That thing is monstrous! But I bet it pumps out a shit ton of air
'03 S10 Xtreme Build
4.3L Automatic; Bagged on 2500's; Turbo 5.3/4L60e in the works..
Lutz is offline
post #28 of 29 Old 02-08-2013, 11:45 AM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I think it pulls 10HP when running as well
DJDAudio is offline
post #29 of 29 Old 02-08-2013, 01:50 PM
Dems 22s
mattadams13's Avatar
User is: mattadams13 is offline
I had the airlift kit on my truck. I recently sold it. If you are going to play with the switches a lot then yeah you need an edc. Im over all that stuff now. Im going to run 2 480s with a 7 gallon tank. that will be plenty for me.
Matt Adams
Project thread: Laying on billet 22s http://www.s10forum.com/forum/f30/si...thread-486853/
You may post new threads
You may post replies
